If the Isaac ROS packages aren’t maintained anymore that’s one thing, but removing the whole ROS2 Humble prebuild package ecosystem for Focal is more extreme. We would be forced to build all of ROS2 humble from source for Focal (20.04) if this apt repo is removed, until we can update to Jetpack 6, which will take time while waiting for custom kernels we use to be updated. ROS2 Humble is only compatible with Jammy (22.04), so we cant use the OSR buildfarm. This apt repo is for anyone running jetpack 5.x on a Jetson device regardless of the use of Isaac ros packages specifically.
Thank you, @henry.fuller. As you mentioned, the Isaac ROS 2.1 packages are no longer being maintained. Currently, the only options available are to either rebuild all packages from our source or upgrade to the latest version of Isaac ROS.
