Hi!
System: ubuntu 22.04 (lxd vm, not container), pci passthrough-ed 4090.
Task: simple GAN
Always see P2 on nvidia-smi:
| NVIDIA-SMI 525.89.02 Driver Version: 525.89.02 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:06:00.0 Off | Off |
| 44% 66C P2 391W / 450W | 5784MiB / 24564MiB | 98% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 611675 C ...ep/jupyterlab/bin/python3 5782MiB |
dmon show clock changing (boosting, if i use this term in right way) during task run:
gpu pwr gtemp mtemp sm mem enc dec mclk pclk
Idx W C C % % % % MHz MHz
0 393 65 - 98 36 0 0 10251 2550
0 393 63 - 97 36 0 0 10251 2490
0 394 64 - 97 35 0 0 10251 2550
0 395 66 - 97 35 0 0 10251 2595
0 393 66 - 98 37 0 0 10251 2640
0 395 64 - 98 37 0 0 10251 2310
0 395 64 - 98 37 0 0 10251 2490
0 395 65 - 97 36 0 0 10251 2640
0 396 67 - 97 36 0 0 10251 2655
0 397 67 - 98 36 0 0 10251 2490
0 395 65 - 98 36 0 0 10251 2505
0 396 64 - 98 36 0 0 10251 2610
0 394 65 - 98 36 0 0 10251 2610
0 394 67 - 98 35 0 0 10251 2670
0 395 68 - 98 36 0 0 10251 2670
0 394 64 - 98 36 0 0 10251 2295
0 391 65 - 97 35 0 0 10251 2310
0 391 66 - 97 35 0 0 10251 2505
0 391 65 - 97 35 0 0 10251 2445
0 394 64 - 97 33 0 0 10251 2430
0 394 65 - 97 33 0 0 10251 2550
0 394 64 - 97 33 0 0 10251 2550
0 395 67 - 98 37 0 0 10251 2640
0 398 66 - 98 38 0 0 10251 2640
I want to set clock permanently to, for example, 2640.
Tried different ways (without attempt to deeply understand what i exacly do) to change to P0 or fix mem+gpu clock via nvidia-settings, no luck.
Question: Is there a step-by-step guide “how to fix frequencies”?
I understand that there can be lots of tricky cases and i “need to better discover the topic”, but maybe there is a “common set of instructions that can help to understand how to fix freqs” that “usually should work” (i.e. without deeper debug of particular problems that can prevent frequencies of my exact system+card to be fixed)
