Ubuntu 22.04 installation driver error
Using VMWare7.0 virtual machine, GPU A40, direct to virtual machine, virtual machine system ubuntu22.04.1,The kernel version is 5.15.0, and the installed driver version is 525. After the driver installation is completed, execute the nvidia smi command to report an error,
This is the error message:
NVIDIA-SMI has failed because it could not communicate with the NVIDIA driver Make sure that the latest NVIDIA driver is installed and running
log file:
nvidia-bug-report.log.gz (343.9 KB)
Incorrectly created VM. Please delete it and create a new one, explicitly selecting EFI boot intead of BIOS boot.
Okay, I will try to recreate the virtual machine started by EFI later, and then install the driver. Did you draw the conclusion from reading the logs?
Yes, dmesg says this:
[    2.059673] kernel: NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
                       NVRM: BAR1 is 0M @ 0x0 (PCI:0000:0b:00.0)
[    2.063203] kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
[    2.063606] kernel: NVRM: None of the NVIDIA devices were initialized.
and lspci says this:
0000:0b:00.0 3D controller [0302]: NVIDIA Corporation GA102GL [A40] [10de:2235] (rev a1)
	DeviceName: pciPassthru0
	Subsystem: NVIDIA Corporation GA102GL [A40] [10de:145a]
	Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: Memory at <unassigned> (64-bit, prefetchable)
	Region 3: Memory at e4000000 (64-bit, prefetchable) [size=32M]
which points to the wrong boot method used.
After changing the startup method, nvidia smi can output normally. Thank you very much. This solution is effective
