It’s been running fine until Ubuntu installed kernel 5.4 around 6/15. Since then no upgrade/downgrade/swapping TREX into another PCI slot helps. I upgraded to Ubuntu 22.04 and installed the 515 driver – still nothing.
lspci shows the card 01:00.0 VGA compatible controller: NVIDIA Corporation TU102 [TITAN RTX] (rev a1)
but Nvidia-smi reports No devices were found.
I admit I have not tried that. Is there any specific kernel version I’d have to use with the 470 driver? I noticed that the RmInitAdapter failed! only showed up after the kernel upgraded on or around 6/15/22.
Just tested with 470 diver - same result. The same happens if I remove the power cables: lspci still detects the card but is unable to load the driver. I wonder if this might be a power issue.
pls 1. do a clean install ubuntu 18.04.6LTS
2 disable nouveau
3. update-initramfs -u
3. apt install build-essential
4. install one of these drivers manually: 470.82.0/ 460.91.03
there shouldnt be any problem!!
