Xavier AX dev kit
jetpack4.3
Deepstream 4
Is there a list of all the ubunutu bloatware that can be safely removed from the Xavier AGX dev kits?
Using the system for a deepstream app
Thanks Chris
Xavier AX dev kit
jetpack4.3
Deepstream 4
Thanks Chris
I posted this over at the Nano section but it could correct the heavy desktop issue.
is desktop
FYI: run "sudo apt list --installed " to see what is on the system.
Thanks, I’ll take a look at this.
I keep getting random “unity-panel-ser” failures so changing away from unity might help
For running only Deep Streak SDK, you may refer to this post:
DS app running on SD, not running on eMMC - Part II - #5 by DaneLLL
We verify it on JP4.5.1. You may give it a try on JP4.3.
