Hi
I run ubuntu desktop on a laptop. After the updates installed using the gui i can not log back in.
in the logs i can see nvidia related errors.
i reinstalled all drivers following: https://ubuntu.com/server/docs/nvidia-drivers-installation
same problem
it works when i choose ubuntu wayland.
logs
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: Received signal 15
Dez 04 11:05:34 wm-nb002 systemd[1]: Stopping nvidia-persistenced.service - NVIDIA Persistence Daemon...
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: Socket closed.
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: PID file unlocked.
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: PID file closed.
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11661]: Shutdown (11661)
Dez 04 11:05:34 wm-nb002 systemd[1]: nvidia-persistenced.service: Deactivated successfully.
Dez 04 11:05:34 wm-nb002 systemd[1]: Stopped nvidia-persistenced.service - NVIDIA Persistence Daemon.
Dez 04 11:05:34 wm-nb002 systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11742]: Verbose syslog connection opened
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11742]: Now running with user ID 122 and group ID 124
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11742]: Started (11742)
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11742]: device 0000:01:00.0 - registered
Dez 04 11:05:34 wm-nb002 nvidia-persistenced[11742]: Local RPC services initialized
Dez 04 11:05:34 wm-nb002 systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
driver
| NVIDIA-SMI 535.183.01 Driver Version: 535.183.01 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1650 ... Off | 00000000:01:00.0 On | N/A |
| N/A 55C P8 3W / 35W | 43MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 4877 G /usr/bin/gnome-shell 41MiB |
specs
Operating System: Ubuntu 24.04.1 LTS
Kernel: Linux 6.8.0-49-generic
Architecture: x86-64
Hardware Vendor: Lenovo
Hardware Model: ThinkPad X1 Extreme Gen 3
Firmware Version: N2VET47W (1.32 )
Firmware Date: Thu 2024-03-21
Firmware Age: 8month 2w
thanks for your help in advance
