Ubuntu’s Port forwarding is not working properly on Nvidia Jetson Xavier
I am trying to set up port forwarding on my Nvidia Jetson device with Ubuntu installed.
I am trying to forward traffic going to IP 172.16.0.100 and port 81 to forward to IP: 192.168.0.200 and port 554.
I am using IPTABLES to setup the forwarding. I have used the following rules:
sudo iptables -t nat -A PREROUTING -p tcp --dport 81 -j DNAT --to-destination 192.168.0.200:554
sudo iptables -t nat -A POSTROUTING -p tcp -d 192.168.0.200 --dport 554 -j SNAT --to-source 172.16.0.100
Adding these rules does not work. I cannot access 192.168.0.200 on port 554. I’ve tested these rules on a different PC running the same version of Ubuntu and it worked perfectly.
I’ve also tried a combination of NAT and Firewall rules, like:
sudo iptables -I FORWARD 1 -m state -p tcp -d 192.168.88.207 --dport 81 --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -t nat -A POSTROUTING -j MASQUERADE
iptables -t nat -A POSTROUTING -s 172.168.88.207 -j MASQUERADE
But nothing seems to work.
I ran a TCPDUMP on the Nvidia device to see what happens with the traffic:
####@Ubuntu:~$ sudo tcpdump -n --interface=tun0 port 81
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on tun0, link-type RAW (Raw IP), capture size 262144 bytes
13:18:41.533140 IP 172.16.0.1.56502 > 172.16.0.100.81: Flags [S], seq 1758976221, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:18:42.538221 IP 172.16.0.1.56502 > 172.16.0.100.81: Flags [S], seq 1758976221, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:18:44.523913 IP 172.16.0.1.56502 > 172.16.0.100.81: Flags [S], seq 1758976221, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:18:48.539027 IP 172.16.0.1.56502 > 172.16.0.100.81: Flags [S], seq 1758976221, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:18:56.540632 IP 172.16.0.1.56502 > 172.16.0.100.81: Flags [S], seq 1758976221, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
####@Ubuntu:~$ sudo tcpdump -n --interface=enp0s3 port 554
listening on enp0s3, link-type EN10MB (Ethernet), capture size 262144 bytes
13:20:01.713725 IP 172.16.0.1.56509 > 192.168.0.200.554: Flags [S], seq 1737771977, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:20:02.705634 IP 172.16.0.1.56509 > 192.168.0.200.554: Flags [S], seq 1737771977, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:20:04.694546 IP 172.16.0.1.56509 > 192.168.0.200.554: Flags [S], seq 1737771977, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:20:08.694197 IP 172.16.0.1.56509 > 192.168.0.200.554: Flags [S], seq 1737771977, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:20:16.703544 IP 172.16.0.1.56509 > 192.168.0.200.554: Flags [S], seq 1737771977, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
The traffic is being received and forwarded to the correct IP and port. But there is no reverse NAT happening.
Here I ran TCPDUMP on the Ubuntu PC with the same rules, which was working:
13:21:39.705604 IP 172.16.0.1.56517 > 172.16.0.100.81: Flags [S], seq 448973759, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:21:39.722259 IP 172.16.0.100.81 > 172.16.0.1.56517: Flags [S.], seq 237888001, ack 448973760, win 65535, options [mss 1460], length 0
13:21:39.896538 IP 172.16.0.1.56517 > 172.16.0.100.81: Flags [.], ack 1, win 64240, length 0
13:21:42.259338 IP 172.16.0.1.56517 > 172.16.0.100.81: Flags [P.], seq 1:3, ack 1, win 64240, length 2
13:21:42.259562 IP 172.16.0.100.81 > 172.16.0.1.56517: Flags [.], ack 3, win 65535, length 0
13:23:21.862358 IP 172.16.0.100.56535 > 192.168.0.200.554: Flags [S], seq 3200998178, win 64240, options [mss 1351,nop,wscale 8,nop,nop,sackOK], length 0
13:23:21.879541 IP 192.168.0.200.554 > 172.16.0.100.56535: Flags [S.], seq 250752001, ack 3200998179, win 65535, options [mss 1460], length 0
13:23:22.044519 IP 172.16.0.100.56535 > 192.168.0.200.554: Flags [.], ack 1, win 64240, length 0
13:23:24.314366 IP 172.16.0.100.56535 > 192.168.0.200.554: Flags [P.], seq 1:3, ack 1, win 64240, length 2: RTSP
13:23:24.314601 IP 192.168.0.200.554 > 172.16.0.100.56535: Flags [.], ack 3, win 65535, length 0
Both devices have a fresh install of Ubuntu with the exact same NAT rules.
Does anybody know what the issue might be?
We don’t have much experience in the use-case. Would need other user to share suggestion.
For Xavier NX, the two latest releases are Jetpack 4.6.3 and 5.1.1. You may try the releases and see if either one works.
