Ubuntu20.04 setted BaseMosaic on,screens have no signal
I have a workstation with 4 graphics cards, QUADRO RTX 4000. Every graphics card connected to a 4K monitor using dp interface.
My OS is ubuntu20.04 lts, when i installed my os,I executed the following command:
sudo apt update
sudo apt upgrade
sudo ubuntu-drivers auto install
sudo reboot
After system restart,i run the command sudo nvidia-settings. In primary screen,I enable BaseMosaic ,and enabled other monitor with “Configuration : x screen 0”,then i apply settings and saved it in xorg.conf.
A part of my xorg.conf like this :
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “Stereo” “0”
Option “nvidiaXineramaInfoOrder” “DFP-2”
Option “metamodes” “GPU-772965d4-80c2-2c14-d5b2-4be8a7c3a43c.DP-2: nvidia-auto-select +0+0, GPU-b16ec084-0226-c21e-496a-193149a3140f.DP-1-2: nvidia-auto-select +3840+0, GPU-09d00272-fc4b-903f-38f8-3713733003f1.DP-2-2: nvidia-auto-select +7680+0, GPU-db7986d6-56d3-01aa-a1f3-7e520697fcbc.DP-3-2: nvidia-auto-select +11520+0”
Option “MultiGPU” “Off”
Option “SLI” “off”
Option “BaseMosaic” “on”
SubSection “Display”
Depth 24
Then i reboot again,After the restart, the displays (four monitor) all have no signal.But use other computer , i can connect the workstation with ssh.In /var/log/syslog ,i found this:
(EE) NVIDIA(GPU-0): Failed to select a display subsystem.
Fatal server error:
May 12 16:56:15 hengda172 /usr/lib/gdm3/gdm-x-session[2186]: (EE) no screens found(EE)
Error: can’t open /lib/modules/5.8.0-53-generic/updates/dkms
in /var/lib/gdm3/.local/share/xorg/Xorg.0.log, it shows :
[ 714.076] compiled for 1.6.99.901, module version = 1.0.0
[ 714.076] Module class: X.Org Server Extension
[ 714.076] (II) NVIDIA GLX Module 460.73.01 Thu Apr 1 21:35:16 UTC 2021
[ 714.076] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 714.079] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[ 714.080] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[ 714.080] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[ 714.080] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:3:0:0 is part of an active SLI
[ 714.080] (EE) NVIDIA(GPU-0): configuration and is currently unavailable for single GPU
[ 714.080] (EE) NVIDIA(GPU-0): rendering. Please see Chapter 30: Configuring SLI and
[ 714.080] (EE) NVIDIA(GPU-0): Multi-GPU Mosaic in the README for troubleshooting
[ 714.080] (EE) NVIDIA(GPU-0): information.
[ 714.080] (EE) *** Aborting ***
[ 714.080] (EE) NVIDIA(0): Failing initialization of X screen
[ 714.080] (II) UnloadModule: “nvidia”
[ 714.080] (II) UnloadSubModule: “glxserver_nvidia”
[ 714.080] (II) Unloading glxserver_nvidia
[ 714.080] (II) UnloadSubModule: “wfb”
[ 714.080] (II) UnloadSubModule: “fb”
[ 714.080] () NVIDIA(G0): Depth 24, (–) framebuffer bpp 32
[ 714.081] (==) NVIDIA(G0): RGB weight 888
[ 714.081] (==) NVIDIA(G0): Default visual is TrueColor
[ 714.081] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 714.081] (II) Applying OutputClass “nvidia” options to /dev/dri/card2
[ 714.081] (
) NVIDIA(G0): Option “Stereo” “0”
[ 714.081] () NVIDIA(G0): Option “nvidiaXineramaInfoOrder” “DFP-2”
[ 714.081] (
) NVIDIA(G0): Option “SLI” “off”
[ 714.081] () NVIDIA(G0): Option “MultiGPU” “Off”
[ 714.081] (
) NVIDIA(G0): Option “BaseMosaic” “on”
[ 714.081] () NVIDIA(G0): Option “AllowEmptyInitialConfiguration”
[ 714.081] (
) NVIDIA(G0): Stereo disabled by request
[ 714.081] () NVIDIA(G0): NVIDIA SLI disabled.
[ 714.081] (
) NVIDIA(G0): NVIDIA Multi-GPU disabled.
[ 714.081] (WW) NVIDIA(G0): Base Mosaic is available only on screen 0. Disabling Base
[ 714.081] (WW) NVIDIA(G0): Mosaic.
[ 714.081] (EE) NVIDIA(G0): Only one X screen is supported when Base Mosaic is enabled.
[ 714.081] (EE) NVIDIA(G0): Disabling this screen.
[ 714.081] (EE) NVIDIA(G0): Failing initialization of X screen
[ 714.081] (II) NVIDIA(G1): (GPU-2) already has an X screen assigned; skipping this GPU
[ 714.081] (II) NVIDIA(G1): screen
[ 714.081] (EE) NVIDIA(G1): Failing initialization of X screen
[ 714.081] (II) NVIDIA(G2): (GPU-3) already has an X screen assigned; skipping this GPU
[ 714.081] (II) NVIDIA(G2): screen
[ 714.081] (EE) NVIDIA(G2): Failing initialization of X screen
[ 714.081] (II) UnloadModule: “nvidia”
[ 714.081] (II) UnloadSubModule: “wfb”
[ 714.081] (II) UnloadSubModule: “fb”
[ 714.081] (EE) Screen(s) found, but none have a usable configuration.
[ 714.081] (EE)
Fatal server error:
[ 714.081] (EE) no screens found(EE)
[ 714.081] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 714.081] (EE) Please also check the log file at “/var/lib/gdm3/.local/share/xorg/Xorg.0.log” for additional information.
[ 714.081] (EE)
[ 714.087] (EE) Server terminated with error (1). Closing log file.
Use ssh i sudo vi /etc/X11/xorg.conf , changed Option “BaseMosaic” “on” to Option “BaseMosaic” “off”,and reboot,then all four monitors have signal,
I mean, when I make BaseMosaic on in xorg.conf, there will be no signal on the displays after ubuntu startup, and when I turn off this configuration, there will be signal on the displays after startup.
Please how to solve this problem?thanks!!
Did you read the README the Xorg log points you to:
https://download.nvidia.com/XFree86/Linux-x86_64/455.38/README/sli.html
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (1.2 MB)
Thank you very much!!
Please disable the onboard server graphics in bios and replace your xorg.conf with just:
Section "Device"
    Identifier     "nvidia"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BusID          "PCI:3:0:0"
    Option        "BaseMosaic" "true"
    Option         "AllowEmptyInitialConfiguration"
EndSection
Thanks!!!
If I use ubuntu18.04,this way works!
But when I install Ubuntu 20.04, the problem still exists…
Can you help me analyze this problem again?
There is no integrated graphics card on the main board of this workstation,In the BIOS configuration, I didn’t find the configuration of on-board graphics card.
thank you very much for your help!!
oh,by the way,in ubuntu20.04,i found this:
hengda@hengda-Z10PE-D8-WS:~$ lspci | grep VGA
03:00.0 VGA compatible controller: NVIDIA Corporation TU104GL [Quadro RTX 4000] (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation TU104GL [Quadro RTX 4000] (rev a1)
0a:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 30)
81:00.0 VGA compatible controller: NVIDIA Corporation TU104GL [Quadro RTX 4000] (rev a1)
82:00.0 VGA compatible controller: NVIDIA Corporation TU104GL [Quadro RTX 4000] (rev a1)
What’s this “ASPEED xxx"? Is that the problem?
@generix
Is there anything else I can do or try?This is really important to me.Thank you!!
@Mart
yes i do,but my english is not very good.
I use the translation software, but it brings more confusion…
Can you help me to point out the key points? This question is really important to me. Thank you very much!!
