Ubuntu22.04 + r32.7.2 build dtbs error
Hello, when i use ubuntu22.04 + r32.7.2 build dtbs error !
tr@tr:~/workdir/jetson/r32.7.2/Linux_for_Tegra/source/public/kernel/kernel-4.9$ make CROSS_COMPILE=/home/tr/workdir/jetson/r32.7.2/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
make[1]: 进入目录“/home/tr/workdir/jetson/r32.7.2/Linux_for_Tegra/source/public/kernel/kernel-4.9/TEGRA_KERNEL_OUT”
  CHK     include/config/kernel.release
  GEN     ./Makefile
  UPD     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
  Using .. as source for kernel
  CHK     scripts/mod/devicetable-offsets.h
../arch/arm64/boot/dts/Makefile:119: 目标“arch/arm64/boot/dts/_ddot_”在同一个规则中给出了多次
../arch/arm64/boot/dts/Makefile:133: 警告:覆盖关于目标“arch/arm64/boot/dts/_ddot_”的配方
../arch/arm64/boot/dts/Makefile:120: 警告:忽略关于目标“arch/arm64/boot/dts/_ddot_”的旧配方
../arch/arm64/boot/dts/Makefile:132: 目标“arch/arm64/boot/dts/_ddot_”在同一个规则中给出了多次
make[2]: *** 没有规则可制作目标“arch/arm64/boot/dts/..//hardware/nvidia/platform/t19x/mccoy/kernel-dts/tegra194-p2888-0004-e3900-0000.dts”,由“arch/arm64/boot/dts/_ddot_//hardware/nvidia/platform/t19x/mccoy/kernel-dts/tegra194-p2888-0004-e3900-0000.dtb” 需求。 停止。
make[2]: *** 正在等待未完成的任务....
  DTC     arch/arm64/boot/dts/_ddot_
cc1: 致命错误: arch/arm64/boot/dts/..:没有那个文件或目录
编译中断。
make[2]: *** [../arch/arm64/boot/dts/Makefile:133:arch/arm64/boot/dts/_ddot_] 错误 1
make[1]: *** [arch/arm64/Makefile:154:dtbs] 错误 2
make[1]: 离开目录“/home/tr/workdir/jetson/r32.7.2/Linux_for_Tegra/source/public/kernel/kernel-4.9/TEGRA_KERNEL_OUT”
make: *** [Makefile:171:sub-make] 错误 2
Looks like an old issue.
Hello WayneWWW,
my kernel is Manually Downloading , and then
TEGRA_KERNEL_OUT=./TEGRA_KERNEL_OUT
export CROSS_COMPILE=/home/cz/CZI/C30N/r32.7.2/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export LOCALVERSION=tegra
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
Does this code exist in your codebase?
yes
arch/arm64/boot/dts/…//hardware/nvidia/platform/t19x/mccoy/kernel-dts/tegra194-p2888-0004-e3900-0000.dts”
Is this path really correct one? This is from your make log.
Hello WayneWWW,
这个路径是错误的,他是由于make执行错误得到的
我的問題就是說那在你那邊的目錄結構是長怎樣?
聽起來你不止這一個路徑會有問題 你應該全部的dtb路徑都沒對上吧?
我的目录结构是由官方的包解压出来的,是对的上的,它在ubuntu20.04上面编译是正常的,但是在ubuntu22.04和24.04上面它失败了
那請你就使用ubuntu20.04.
32.7.2這一整包的開發環境就只有在Ubuntu18.04驗過. 20.04/22.04/24.04都已經沒有在驗證rel-32了
