In case this helps future HPC SDK releases: The UCX 1.21.0 in the bundled HPC-X 2.50 computes 0/0 during MPI_Init. With the default FP environment this is harmless. But a program built with FP traps enabled, e.g. -Ktrap=fp to debug floating-point exceptions, stops with SIGFPE before any user code runs.
A minimal example:
#define _GNU_SOURCE
#include <fenv.h>
#include <mpi.h>
#include <stdio.h>
int main(int argc, char **argv) {
feenableexcept(FE_INVALID | FE_DIVBYZERO | FE_OVERFLOW);
MPI_Init(&argc, &argv);
printf("MPI_Init returned\n");
MPI_Finalize();
return 0;
$ mpicc fptrap_mpi_init.c && mpirun -np 1 ./a.out
Signal: Floating point exception (8)
Signal code: Invalid floating point operation (7)
[ 1] .../hpcx-2.50/ucx/mt/lib/libucp.so.0(ucp_worker_iface_open+0x4ab)
[ 3] .../hpcx-2.50/ucx/mt/lib/libucp.so.0(ucp_worker_create+0x71c)
A Fortran MPI program built with mpifort -Ktrap=fp stops at the same place. Without UCX (OMPI_MCA_pml=ob1 OMPI_MCA_btl=self,sm OMPI_MCA_osc=^ucx OMPI_MCA_coll=^ucc,hcoll), both run normally.
The faulting instruction is the division in ucp_worker_iface_port_speed (src/ucp/core/ucp_worker.c):
ratio = perf_attr.bandwidth.shared / wiface->attr.bandwidth.shared;
This is 0/0 for an interface with zero shared bandwidth. Upstream UCX has already fixed it, in commit 6ef510d (“UCP/CORE: Skip port speed for zero shared bandwidth”, PR #11672, July 2026). The fix is in the UCX 1.23.0 release candidates, but not in 1.22.0. So it might be worth picking up the patch, or UCX 1.23, in a future HPC-X.
Until then, users can disable UCX for debug runs with FP traps (on a single node, as above), or enable the traps only after MPI_Init.
Environment: NVIDIA HPC SDK 26.9, bundled HPC-X 2.50 (Open MPI 5.0.10rc2, UCX 1.21.0), Ubuntu 26.04.1 LTS, Intel Xeon W-2223.
Thank you in advance!
Pedro
Written with the help of Claude Code.
