Hi everyone:
We are using jetpack3.2.1 on tx1, we have two network interface: the tx1’s r8152 and a pcie netcard r8169 .Inorder to set the r8152 as eth0 and r8169 as eth1 we add the /etc/udev/rules.d/70-persistent-net.rules as following:
SUBSYSTEMS=="pci", ACTION=="add", DRIVERS=="?*", ATTR{type}=="1", KERNEL=="eth*", NAME="eth1"
SUBSYSTEMS=="usb", ACTION=="add", DRIVERS=="?*", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
Most of the time is works well, but we found that at a very rare case, the udev will failed to rename the network interface name correctly.The wrong ifconfig info as follws:
docker0 Link encap:Ethernet HWaddr 02:42:38:5b:41:a9
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:00:00:00:00:05
collisions:0 txqueuelen:1000
eth0:avahi Link encap:Ethernet HWaddr 00:00:00:00:00:05
inet addr:169.254.1.26 Bcast:169.254.255.255 Mask:255.255.0.0
l4tbr0 Link encap:Ethernet HWaddr 3a:04:6a:62:ec:3e
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::b4cf:82ff:fe16:a0ce/64 Scope:Link
TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:430 (430.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:41141 errors:0 dropped:0 overruns:0 frame:0
TX packets:41141 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2951366 (2.9 MB) TX bytes:2951366 (2.9 MB)
rename10 Link encap:Ethernet HWaddr 00:04:4b:a4:c3:be
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10900 errors:0 dropped:0 overruns:0 frame:0
TX packets:934 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:655262 (655.2 KB) TX bytes:156204 (156.2 KB)
usb0 Link encap:Ethernet HWaddr 6a:9e:11:3e:7d:f9
usb1 Link encap:Ethernet HWaddr 3a:04:6a:62:ec:3e
wlan0 Link encap:Ethernet HWaddr 00:04:4b:a4:c3:bc
In the syslog we found the following message of udev:
May 9 06:44:35 tegra-ubuntu systemd-udevd[272]: error changing net interface name 'eth0' to 'eth1': Device or resource busy
May 9 06:44:35 tegra-ubuntu systemd-udevd[272]: could not rename interface '6' from 'eth0' to 'eth1': Device or resource busy
May 9 06:46:07 tegra-ubuntu systemd-udevd[271]: could not rename interface '10' from 'eth1' to 'eth0': File exists
May 9 06:46:07 tegra-ubuntu NetworkManager[456]: <info> [1557384367.4947] device (rename10): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
May 9 06:46:07 tegra-ubuntu systemd[928]: sys-subsystem-net-devices-eth0.device: Dev sys-subsystem-net-devices-eth0.device appeared twice with different sysfs paths /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/eth1 and /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/rename10
May 9 06:46:07 tegra-ubuntu ofonod[427]: plugins/udev.c:udev_event() subsystem net move
May 9 06:46:07 tegra-ubuntu collect[680]: [+] Download failed: http://192.168.13.6/onvif-http/snapshot?Profile_1 admin admin123
May 9 06:46:07 tegra-ubuntu systemd[2269]: sys-subsystem-net-devices-eth0.device: Dev sys-subsystem-net-devices-eth0.device appeared twice with different sysfs paths /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/eth1 and /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/rename10
May 9 06:46:07 tegra-ubuntu ofonod[427]: plugins/udev.c:udev_event() subsystem net finished
May 9 06:46:07 tegra-ubuntu systemd[1]: sys-subsystem-net-devices-eth0.device: Dev sys-subsystem-net-devices-eth0.device appeared twice with different sysfs paths /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/eth1 and /sys/devices/70090000.xusb/usb2/2-1/2-1:1.0/net/rename10
May 9 06:46:07 tegra-ubuntu kernel: [ 105.183896] IPv6: ADDRCONF(NETDEV_UP): rename10: link is not ready
We want to know the reason why did it happen ?
We want to set the two netcard as fixname. Is there anyway to solve it or workaroud it ?
Thanks a lot !
