I’m experiencing issues with Nsight Perf SDK integration in Unreal Engine 5. I tried to use HTMLReport and I inserted code like this
void FD3D12DynamicRHI::RHIEndFrame_RenderThread(FRHICommandListImmediate& RHICmdList)
// Close the GPU profiler frame
#if (RHI_NEW_GPU_PROFILER == 0)
RHICmdList.EnqueueLambdaMultiPipe(GetEnabledRHIPipelines(), FRHICommandListBase::EThreadFence::Enabled, TEXT("D3D12 EndFrame"),
[this](FD3D12ContextArray const& Contexts)
for (auto& Adapter : ChosenAdapters)
for (auto& Device : Adapter->GetDevices())
Device->GetGPUProfiler().EndFrame();
#if WITH_NVPERF
// NVPerf: OnFrameEnd - called after GPU Profiler EndFrame
if (FNVPerfIntegrationModule::IsAvailable())
FNVPerfIntegrationModule& NVPerfModule = FNVPerfIntegrationModule::Get();
NVPerfModule.OnFrameEnd(); //a warpper, it call nv::perf::profiler::ReportGeneratorD3D12::OnFrameEnd() inside
#endif
#endif
Adapter->GetFrameFence().AdvanceTOP();
// Base implementation flushes all prior work and results in a bottom-of-pipe call to RHIEndFrame() on the RHI thread.
FDynamicRHI::RHIEndFrame_RenderThread(RHICmdList);
RHICmdList.EnqueueLambdaMultiPipe(GetEnabledRHIPipelines(), FRHICommandListBase::EThreadFence::Enabled, TEXT("D3D12 BeginFrame"),
Device->GetDefaultBufferAllocator().BeginFrame(Contexts);
Device->GetTextureAllocator().BeginFrame(Contexts);
#if D3D12_RHI_RAYTRACING
// @todo dev-pr - explicit use of graphics context - nothing is synchronizing async compute - needs refactor
Device->GetRayTracingCompactionRequestHandler()->Update(*Contexts[ERHIPipeline::Graphics]->GetSingleDeviceContext(Device->GetGPUIndex()));
#endif // D3D12_RHI_RAYTRACING
Device->GetGPUProfiler().BeginFrame();//a warpper, it call nv::perf::profiler::ReportGeneratorD3D12::OnFrameStart() inside
#endif
#if WITH_NVPERF
// NVPerf: OnFrameStart - called after GPU Profiler BeginFrame
ID3D12CommandQueue* CommandQueue = this->RHIGetCommandQueue();
if (CommandQueue)
NVPerfModule.OnFrameBegin(CommandQueue);
#endif
StartCollectionOnNextFrame was called by a console command at runtime.
however, I encountered such error:
Cmd: r.NVPerf.CaptureReport
LogNVPerf: Display: NVPerf HTML report capture started. Report will be generated on next frame.
LogNVPerf: Error: [NVPERF|ERR|] nv::perf::profiler::ReportGeneratorD3D12::BeginSessionWithOptions: sessionOptions == m_defaultSessionOptions
LogNVPerf: Error: [NVPERF|ERR|] nv::perf::profiler::RangeProfilerD3D12::BeginSession: NVPW_D3D12_Profiler_Queue_BeginSession , numTraceBuffers = 5, traceBufferSize = 90112, maxRangesPerPass = 128, maxLaunchesPerPass = 128
LogNVPerf: Error: [NVPERF|ERR|] nv::perf::profiler::RangeProfilerD3D12::BeginSession: Failed to start profiler session: unknown error, nvpaStatus = NVPA_STATUS_INVALID_CONTEXT_STATE(UNUSED) (18)
LogNVPerf: Error: [NVPERF|ERR|] nv::perf::profiler::ReportGeneratorD3D12::BeginSessionWithOptions: m_reportProfiler.rangeProfiler.BeginSession failed
LogNVPerf: Error: [NVPERF|ERR|] nv::perf::profiler::ReportGeneratorStateMachine::OnFrameStart: BeginSession failed
I have redirected the SDK’s internal output to the UE log and added some additional debug logging to help trace the issue. I’ve also tried moving the logic to different parts of the frame lifecycle, but it had no effect.
I am currently using UE 5.6.1. Any help or insights would be greatly appreciated.
