I just tried the debian based update procedure on my Jetson Xavier NX and there seems to be an issue. After following the steps described in the document and doing the power cycle, the UEFI bios starts up, shows an upgrade progress bar, which gets to 11% and then stops, seems to reboot to the normal UEFI bios startup screen, which then boots into Ubuntu. But when it gets there I get a GUI that tells me that in order to complete the update process, I have to reboot.
When I do this I again get the UEFI update screen, which gets to 11% etc.
This seems to loop around forever, so I assume that there is an issue with the UEFI update side of things.
Does anybody have any information how to complete the upgrade process to Jetpack 5.1.2 successfully.
This is on a Jetson Xavier NX dev kit with the system booting from an NVME SSD, not the SD card.
I previously installed Jetpack 5.1.1 via SDK Manager, but I was loath to follow this route again as it should also update via the Debian route.
BTW: The date for the used UEFI bios on the UEFI bios screen shows a march date. I assume that this means that it is still running the old UEFI bios, not the new one.
Update: Just tried to do the update using SDK Manager and now I have a different issue: The installation seems to ignore the size of my SSD (250GB) and install itself in a 14 GB root partition, closely followed by some system level partitions and then a 235ish GB unused space section. This then leads to issues with installing the additional packages. Nothing that I do in SDK manager seems to change this behavior (its the latest available version). I can’t remember having this issue with the 5.1.1 install that I also had to do with SDK Manager (after the debian install messed up the update from 5.0 to 5.1.1, if I remember correctly).
Does anybody know how we can get SDK Manager to use the full capacity of the SSD?
Update 2: Just to check that I’m not crazy, I just reinstalled Jetpack 5.1.1 on the Jetson Xavier NX devkit and that one does fully utilize the SSD’s capacity. So there seems to be an issue in the Jetpack 5.1.2 scripts used by the SDK Manager that causes this underutilization of capacity.
Hopefully NVIDIA will patch this in the near future.
Update 3: if I now use the debian based update procedure, I’m back again to my original problem (of infinite UEFI update attempts that fail at 11%)
