UEFI boot failed on custom carrier board
Xavier R35.2.1
using Xavier devkit UEFI can be start , but it fails to work with our custom carrier board.
The difference is that our customized carrier board PCIE C0 is connected to the FPGA.
I modified the device tree tegra194-p2888-0008-p2822-0000.dtb to disable pcie@0x14180000{}, but it still doesn’t work.
How to skip PCIE initialization in UEFI ?
UEFI_ERROR_LOG.txt (76.9 KB)
Hi auth-root,
How about you have the similar connection as the devkit, could it boot w/o current error?
ParseGicMsiBase: cannot retrieve property 'msi-parent': FDT_ERR_NOTFOUND
Do you add msi-parent in your device tree?
This error will also occur when using devkit, but it can be started normally.
tegra194-p2888-0008-p2822-0000.dtb not add msi-parent.
So you boot issue might not be caused from this.
Could you try to compare the boot up log for both devkit and custom board?
Please share your flash log.
