Hi Everyone,
When I use the following command to burn UEFI, I find that I cannot boot from the USB drive as the first priority.
ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1 ./flash.sh --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
But when I remove ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1, I can boot from the USB drive first.
So if I want to enable the AB partition and also want to set the image to boot from the USB drive first, how can I do this?
What do you mean about boot from the USB drive?
Do you mean use USB drive as a rootfs?
Yes, you are right. my USB(/dev/sda) partition table is as follows:
Number Start (sector) End (sector) Size Code Name
1 2048 133119 64.0 MiB EF00 esp
2 133120 59725790 28.4 GiB 0700 APP
My SSD(/dev/nvme0n1) partition table looks like this:
2 133120 8521727 4.0 GiB 8300 APP
3 10094592 18483199 4.0 GiB 8300 APP_b
But if I enable ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1, I can not get the USB drive as my first boot device, it will automatic boot from SSD at first.
Also.
Some question to confirm:
- Are you using a Jetson Nano or Jetson Orin Nano?
- What is your JP version?
Seems like you are using UEFI, which not support Jetson Nano
Please refer to doc to override the default order.
I added ADDITIONAL_DTB_OVERLAY="BootOrderUsb.dtbo" in the command to execute flash.sh, and then I can boot from the USB drive first. Thank you for your answer.
Could you describe more in detail?
How do you enter in SSD system?
In general, add OVERLAY will take effect unless you manually modify in bios setting.
