I have Orin NX 16GB, fused with following configuration
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="64" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="PkcPubkeyHash1" size="64" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="PkcPubkeyHash2" size="64" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="SecureBootKey" size="32" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="PscOdmStatic" size="4" value="0x60"/>
<fuse name="OemK1" size="32" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="OemK2" size="32" value="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"/>
<fuse name="BootSecurityInfo" size="4" value="0x3E9"/>
<fuse name="SecurityMode" size="4" value="0x1"/>
</genericfuse>
I updated eks.img with the command:
$ python3 gen_ekb.py
-chip t234 \
-oem_k1_key oem_k1.key \
-in_sym_key sym_t234.key \
-in_sym_key2 sym2_t234.key \
-in_auth_key auth_t234.key \
-out eks_t234.img
oem_k1.key is the key that fused, sym_t234.key is generated as README of gen_ekb, sym2 key is all 0, auth key is generated as README of gen_ekb.
I didn’t enable UEFI secure boot, just fused and generate new eks_t234.img .
After flashed, the board is failed with following uart log:
NOTICE: BL31: v2.8(release):l4t-r36.4.4
NOTICE: BL31: Built : 2025-06-16 15:14:01
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 13.4.0 (GCC)) #1 Mon Jun 16 15:53:22 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
M/TC: engine AES0 engine [AES/RNG](16) post op: SE0 err_status register 0x10f8 nonzero (value 0x80000000)
M/TC: SE abnormal cond, error info: 0x30040000
M/TC: HW error: d(0), e(0), ro(0x110), rv(0xb0040000), che(0x30), act(0x0)
M/TC: device SE0(0) post op: error_capture 0x30040000
M/TC: AES crypto failed: -17
E/TC:00 00 se_aes_encrypt:35 se_aes_encrypt failed with: -17
I/TC: Derive EKB_RK from #1 fuse key failed, ignored.
E/TC:00 00 hwkey_derivation_process:452 hwkey_derivation_process: Failed to derive SSK root key (ffff0000)
E/TC:00 00 ekb_extraction_process:404 Tried all EKB_RKs but still can't extract the EKB image.
E/TC:00 00 jetson_user_key_pta_init:1154 jetson_user_key_pta_init: Failed (ffff000f).
E/TC:00 00 call_initcalls:43 Initcall __text_start + 0x0016b3f0 failed
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version v36.4.4 built on 2024-10-01T15:28:28+00:00)
I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00 jetson_user_key_pta_uefi_vars_auth:984 UEFI variable auth key not set !
E/TC:?? 00 stmm_handle_variable_authentication:894 Failed to get signed CMAC ffff0008
ASSERT [FvbNorFlashStandaloneMm] /usr/src/debug/standalone-mm-optee-tegra/36.4.4/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/VarIntCheck.c(932): ((BOOLEAN)(0==1))
Can you please point me what is wrong and how I can solve this? Thank you so much.
Linh
