Is there any way to make the RGMII via ETH Phy 88E1512 work in UEFI?
It works perfectly in Tegra at kernel runtime, but the UEFI debug says that it cannot be reset.
I/TC: WARNING: UEFI variable protection is not fully enabled !
I/TC: WARNING: Test UEFI variable auth key is being used !
Failed to get BMC Boot Options Parameter 4 (IPMI CompCode = 0x0)
Waiting for driver 2 of 2 to complete
.SNP:PHY: PhyDxeInitialization () Failed to reset Phy
EqosDeviceDxe:DeviceThreadMain, driver returned Device Error to start notification
I don’t get those errors on AGX Orin devkit.
Are you trying to port custom PHY on AGX Orin?
If so, I would suggest you asking the help from your vendor for those porting works in UEFI.
It is a custom board that we produce (no eeprom - not sure if this is relevant). The PHY we use is ETH Phy 88E1512. Jetpack 6.1.
So you suggest there is a hardware issue? Because I doubt there is since it works perfectly afterwards (after the kernel boots).
The UEFI I build following edk2 instructions, but only for logo change, did not removed any components.
It seems we don’t have RGMII on AGX Orin by default, but we have it on AGX Xavier so that Wayne asked if you’ve also verified it with R35.
Your current device tree settings for phy looks good to us.
UEFI is dtb driven.
Please provide the full device tree and also the full boot log with debug UEFI logs enabled.
Not sure if relevant but, one thing that I noticed. I tried to use another DT for the UEFI where the only difference compared to the kernel DT was that the RGMII node was disabled. I included an FDT entry in extlinux to use the kernel DT (with the node enabled). But for unknown reason, the nvethernet could not probe the PHY anymore (-2 error). Although the running device tree stated that the node is enabled. So the FDT entry is not ignored, but for some reasone the device was not working. Very weird behavior that I do not know if is supposed to happen.
The only way that the device works is with both DT being the same. But in that case, it works only in the kernel and in UEFI not. PhyDxeInitialisation throws that reset error.
About above error, could you add more debug messages to PhyReset() in PhyDxeUtil.c to check why it fails.
From your original post, it seems you want it working in UEFI. Why you try to disable it in the DTB used for UEFI?
Please help to clarify your use case. If it can work after boot up, why you need to enable it in UEFI?
OK, It seems to be caused by PhySoftReset timeout.
.SNP:PHY: ERROR! PhySoftReset timeout
-----velorin0: PhySoftReset failed: Time out
It seems that the waiting is caused by the fact that the do-while loop inside PhySoftReset() is never broken by the PHYCTRL_RESET to become zero (as per comment):
// Wait until PHYCTRL_RESET become zero
if ((Data32 & REG_PHY_CONTROL_RESET) == 0) {
break;
therefore the loop is broken only when timeout is reached.
At the beginning I wanted the interface working only in the kernel. Doing so, the boot time is really long due to this error in UEFI. So I tried disabling it in UEFI dtb, but as you see, by doing so, it is somehow disabled also in the kernel, although I used different dtbs and fdt entry.
Nevertheless, this does not matter anymore, because later it has been decided that we need it in UEFI also. So right now the need is to be working in both UEFI and kernel.
I have not change the code in this regard. This is the original definition form edk2 repo. Assuming it is define din microseconds, then yes, it is 200ms.
#define PHY_TIMEOUT 200000
But this value is way too low to cause any major delays. To what value should I set it?
There is another function called after the if, namely DeviceDiscoveryThreadMicroSecondDelay (1);. The description states that is switches to main thread for at least the given number of microseconds.
From my point of view, it is more likely that this will induce the extra delay (In addition to the REG_PHY_CONTROL_RESET not becoming 0).
Of course you do not have it because I have not specified anything in this regard. Please specify what info you need and I will provide it to you, if possible.
Yes, I do. But if this is not possible please confirm it here, so we will stop lookin in this direction.
I will do this as soon as you confirm that there are issues in UEFI from your side and at the moment the network is unusable.
