UEFI Secureboot with disk encryption
I just try with Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
Your patch is included in this version ? (last release available) because I have always issue EKS bad parameter to decrypt disk and and at boot UEFI show me ** WARNING: Test Key is used. ** … even if I use–uefi-keys uefi_keys/uefi_keys.conf
[0002.821] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.823] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE:  BL31: v2.6(release):07eea4970
NOTICE:  BL31: Built : 07:55:15, Mar 19 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
E/TC:0 0 ekb_extraction_process:227 Bad parameter: eks image not correct
E/TC:0 0 jetson_user_key_pta_init:801 jetson_user_key_pta_init: Failed (ffff0006).
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x000c3240 failed
I/TC: Primary CPU switching to normal world boot
  [0003.483] I> Welcome to NVDisp-Init
[0003.483] I> NVDisp-Init version: t194-709c0123
[0003.484] I> CPU-BL Params @ 0xca020000
[0003.484] I>  0) Base:0x00000000 Size:0x00000000
[0003.484] I>  1) Base:0xc8100000 Size:0x00100000
[0003.484] I>  2) Base:0xc9800000 Size:0x00200000
[0003.485] I>  3) Base:0xc8600000 Size:0x00200000
[0003.487] I>  4) Base:0xc8000000 Size:0x00100000
[0003.492] I>  5) Base:0xc7f00000 Size:0x00100000
[0003.496] I>  6) Base:0xc9400000 Size:0x00400000
[0003.501] I>  7) Base:0xc9000000 Size:0x00400000
[0003.505] I>  8) Base:0xc7e00000 Size:0x00100000
[0003.510] I>  9) Base:0xc7d00000 Size:0x00100000
[0003.514] I> 10) Base:0xca800000 Size:0x00800000
[0003.519] I> 11) Base:0x40000000 Size:0x00040000
[0003.523] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.527] I> 13) Base:0x40046000 Size:0x00002000
[0003.532] I> 14) Base:0x40048000 Size:0x00002000
[0003.536] I> 15) Base:0xaf000000 Size:0x00004000
[0003.541] I> 16) Base:0x4004a000 Size:0x00002000
[0003.545] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.550] I> 18) Base:0x4004c000 Size:0x00002000
[0003.554] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.559] I> 20) Base:0x4004e000 Size:0x00002000
[0003.563] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.568] I> 22) Base:0x00000000 Size:0x00000000
[0003.572] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.577] I> 24) Base:0xcc000000 Size:0x02000000
[0003.581] I> 25) Base:0x40050000 Size:0x00002000
[0003.586] I> 26) Base:0x40040000 Size:0x00006000
[0003.590] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.594] I> 28) Base:0xc8400000 Size:0x00200000
[0003.599] I> 29) Base:0xc8800000 Size:0x00400000
[0003.603] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.608] I> 31) Base:0x00000000 Size:0x00000000
[0003.612] I> 32) Base:0xf8000000 Size:0x08000000
[0003.617] I> 33) Base:0xce000000 Size:0x2a000000
[0003.621] I> 34) Base:0xcb000000 Size:0x01000000
[0003.626] I> 35) Base:0xae000000 Size:0x01000000
[0003.630] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.635] I> 37) Base:0xca000000 Size:0x00800000
[0003.639] I> 38) Base:0x80000000 Size:0x20000000
[0003.644] I> 39) Base:0xb0000000 Size:0x08000000
[0003.648] I> 40) Base:0x00000000 Size:0x00000000
[0003.652] I> 41) Base:0x00000000 Size:0x00000000
[0003.657] I> 42) Base:0xc8200000 Size:0x00200000
[0003.661] I> 43) Base:0x00000000 Size:0x00000000
[0003.666] I> 44) Base:0x00000000 Size:0x00000000
[0003.670] I> 45) Base:0x00000000 Size:0x00000000
[0003.675] GIC-SPI Target CPU: 0
[0003.678] Interrupts Init done
[0003.681] calling constructors
[0003.684] initializing heap
[0003.686] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.690] initializing threads
[0003.693] initializing timers
[0003.696] creating bootstrap completion thread
[0003.700] top of bootstrap2()
[0003.703] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.708] initializing platform
[0003.711] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.716] W> device prod register failed
[0003.720] I> Bl_dtb @0xadf00000
[0003.723] I> gpio framework initialized
[0003.734] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.740] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.745] I> fixed regulator driver initialized
[0003.762] I> register 'maxim' power off handle
[0003.765] I> virtual i2c enabled
[0003.765] I> registered 'maxim,max20024' pmic
[0003.766] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.766] I> Boot-device: QSPI
[0003.767] I> Boot_device: QSPI_FLASH instance: 0
[0003.772] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.782] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.790] I> QSPI source rate = 204000 Khz
[0003.793] I> Requested rate for QSPI clock = 34000 Khz
[0003.798] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.803] I> tx_clk_tap_delay : 0
[0003.805] I> rx_clk_tap_delay : 16
[0003.809] I> QSPI Flash Size = 32 MB
[0003.817] I> Qspi initialized successfully
[0003.817] I> qspi flash-0 params source = boot args
[0003.821] W> No board IDs available
[0003.824] E> Failed to get board id info!
[0003.830] I> sdmmc-3 params source = safe params
[0003.837] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.839] W> Cannot find any partition table for 00000003
[0003.843] E> Failed to publish 00000003
[0003.852] I> Found 23 partitions in SDMMC_USER (instance 3)
[0003.870] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.877] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.878] I> hdmi cable connected
[0003.884] W> set volts not configured for 'vdd-1v0'
[0003.890] W> set volts not configured for 'vdd-1v8-hs'
[0003.890] I> retrieved tmds range from prod_list_hdmi_soc
[0003.892] E> cannot find any other nvdisp nodes
[0003.909] I> edid read success
[0003.921] I> edid read success
[0003.921] I> width = 640, height = 480, frequency = 25174825
[0003.922] I> width = 640, height = 480, frequency = 25174825
[0003.923] I> width = 1024, height = 768, frequency = 65000000
[0003.927] I> width = 1024, height = 768, frequency = 65000000
[0003.932] I> width = 1920, height = 1080, frequency = 148500000
[0003.938] I> width = 1280, height = 720, frequency = 74250000
[0003.944] I> width = 640, height = 480, frequency = 25174825
[0003.949] I> width = 720, height = 480, frequency = 26973026
[0003.955] I> width = 1280, height = 720, frequency = 74175824
[0003.960] I> width = 1280, height = 720, frequency = 74175824
[0003.966] I> width = 1920, height = 1080, frequency = 148351648
[0003.972] I> width = 1920, height = 1080, frequency = 148351648
[0003.977] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.989] I> hdmi_enable, starting HDMI initialisation
[0003.993] I> hdmi_enable, HDMI initialisation complete
[0004.003] initializing target
[0004.003] calling apps_init()
[0004.004] starting app kernel_boot_app
[0004.005] I> Kernel type = Normal
EnrollFromDefaultKeysApp: Skipped - USER_MODE
Thank you.
If I remove disk encryption '-i 'and --user_key <key_file> that used to encrypt user images, such as kernel, kernel-dtb and initrd. I can boot but I can see the same issue in LOG eks bad parametter.
If I remove only disk encrytion but keep --user_key valid EKS is mandatory and I cant boot with EKS issue bad parametter too !!!
It is not possible to boot with bad EKS reading and user_key enabled ???
I/TC:
  [0003.416] I> Welcome to NVDisp-Init
[0003.416] I> NVDisp-Init version: t194-709c0123
[0003.416] I> CPU-BL Params @ 0xca020000
[0003.417] I>  0) Base:0x00000000 Size:0x00000000
[0003.417] I>  1) Base:0xc8100000 Size:0x00100000
[0003.417] I>  2) Base:0xc9800000 Size:0x00200000
[0003.418] I>  3) Base:0xc8600000 Size:0x00200000
[0003.420] I>  4) Base:0xc8000000 Size:0x00100000
[0003.425] I>  5) Base:0xc7f00000 Size:0x00100000
[0003.429] I>  6) Base:0xc9400000 Size:0x00400000
[0003.434] I>  7) Base:0xc9000000 Size:0x00400000
[0003.438] I>  8) Base:0xc7e00000 Size:0x00100000
[0003.443] I>  9) Base:0xc7d00000 Size:0x00100000
[0003.447] I> 10) Base:0xca800000 Size:0x00800000
[0003.452] I> 11) Base:0x40000000 Size:0x00040000
[0003.456] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.460] I> 13) Base:0x40046000 Size:0x00002000
[0003.465] I> 14) Base:0x40048000 Size:0x00002000
[0003.469] I> 15) Base:0xaf000000 Size:0x00004000
[0003.474] I> 16) Base:0x4004a000 Size:0x00002000
[0003.478] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.483] I> 18) Base:0x4004c000 Size:0x00002000
[0003.487] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.492] I> 20) Base:0x4004e000 Size:0x00002000
[0003.496] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.501] I> 22) Base:0x00000000 Size:0x00000000
[0003.505] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.510] I> 24) Base:0xcc000000 Size:0x02000000
[0003.514] I> 25) Base:0x40050000 Size:0x00002000
[0003.518] I> 26) Base:0x40040000 Size:0x00006000
[0003.523] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.527] I> 28) Base:0xc8400000 Size:0x00200000
[0003.532] I> 29) Base:0xc8800000 Size:0x00400000
[0003.536] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.541] I> 31) Base:0x00000000 Size:0x00000000
[0003.545] I> 32) Base:0xf8000000 Size:0x08000000
[0003.550] I> 33) Base:0xce000000 Size:0x2a000000
[0003.554] I> 34) Base:0xcb000000 Size:0x01000000
[0003.559] I> 35) Base:0xae000000 Size:0x01000000
[0003.563] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.568] I> 37) Base:0xca000000 Size:0x00800000
[0003.572] I> 38) Base:0x80000000 Size:0x20000000
[0003.576] I> 39) Base:0xb0000000 Size:0x08000000
[0003.581] I> 40) Base:0x00000000 Size:0x00000000
[0003.585] I> 41) Base:0x00000000 Size:0x00000000
[0003.590] I> 42) Base:0xc8200000 Size:0x00200000
[0003.594] I> 43) Base:0x00000000 Size:0x00000000
[0003.599] I> 44) Base:0x00000000 Size:0x00000000
[0003.603] I> 45) Base:0x00000000 Size:0x00000000
[0003.608] GIC-SPI Target CPU: 0
[0003.611] Interrupts Init done
[0003.614] calling constructors
[0003.616] initializing heap
[0003.619] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.623] initializing threads
[0003.626] initializing timers
[0003.629] creating bootstrap completion thread
[0003.633] top of bootstrap2()
[0003.636] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.641] initializing platform
[0003.644] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.649] W> device prod register failed
[0003.653] I> Bl_dtb @0xadf00000
[0003.656] I> gpio framework initialized
[0003.669] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.674] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.678] I> fixed regulator driver initialized
[0003.699] I> register 'maxim' power off handle
[0003.701] I> virtual i2c enabled
[0003.702] I> registered 'maxim,max20024' pmic
[0003.702] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.702] I> Boot-device: QSPI
[0003.703] I> Boot_device: QSPI_FLASH instance: 0
[0003.705] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.715] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.722] I> QSPI source rate = 204000 Khz
[0003.726] I> Requested rate for QSPI clock = 34000 Khz
[0003.731] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.736] I> tx_clk_tap_delay : 0
[0003.738] I> rx_clk_tap_delay : 16
[0003.742] I> QSPI Flash Size = 32 MB
[0003.750] I> Qspi initialized successfully
[0003.750] I> qspi flash-0 params source = boot args
[0003.754] W> No board IDs available
[0003.757] E> Failed to get board id info!
[0003.763] I> sdmmc-3 params source = safe params
[0003.770] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.771] W> Cannot find any partition table for 00000003
[0003.776] E> Failed to publish 00000003
[0003.781] I> Found 22 partitions in SDMMC_USER (instance 3)
[0003.801] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.806] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.806] I> hdmi cable connected
[0003.811] W> set volts not configured for 'vdd-1v0'
[0003.816] W> set volts not configured for 'vdd-1v8-hs'
[0003.817] I> retrieved tmds range from prod_list_hdmi_soc
[0003.818] E> cannot find any other nvdisp nodes
[0003.834] I> edid read success
[0003.847] I> edid read success
[0003.847] I> width = 640, height = 480, frequency = 25174825
[0003.848] I> width = 640, height = 480, frequency = 25174825
[0003.848] I> width = 1024, height = 768, frequency = 65000000
[0003.849] I> width = 1024, height = 768, frequency = 65000000
[0003.852] I> width = 1024, height = 768, frequency = 65000000
[0003.858] I> width = 1920, height = 1080, frequency = 148500000
[0003.864] I> width = 1280, height = 720, frequency = 74250000
[0003.869] I> width = 640, height = 480, frequency = 25174825
[0003.875] I> width = 720, height = 480, frequency = 26973026
[0003.880] I> width = 1280, height = 720, frequency = 74175824
[0003.886] I> width = 1280, height = 720, frequency = 74175824
[0003.892] I> width = 1920, height = 1080, frequency = 148351648
[0003.897] I> width = 1920, height = 1080, frequency = 148351648
[0003.903] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.914] I> hdmi_enable, starting HDMI initialisation
[0003.919] I> hdmi_enable, HDMI initialisation complete
[0003.928] initializing target
[0003.929] calling apps_init()
[0003.930] starting app kernel_boot_app
[0003.931] I> Kernel type = Normal
EnrollFromDefaultKeysApp: Cannot enroll dbt: Not Found
EnrollFromDefaultKeysApp: Cannot enroll dbx: Not Found
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: UEFI Secure Boot is enabled.
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
▒▒I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
▒▒[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (root@swdev33) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Mar 28 14:20:22 EDT 2023
[    0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x259d6eb18 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x2589d0000 MEMATTR=0x25914a018 ESRT=0x259181118 RNG=0x27c54f398 MEMRESERVE=0x25914bf18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000259181118 to 0x0000000259181150.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000a0973fff]
[    0.000000]   node   0: [mem 0x00000000a0974000-0x00000000a0975fff]
[    0.000000]   node   0: [mem 0x00000000a0977000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c79fffff]
[    0.000000]   node   0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[    0.000000]   node   0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000257bdffff]
[    0.000000]   node   0: [mem 0x0000000257be0000-0x000000025844ffff]
[    0.000000]   node   0: [mem 0x0000000258450000-0x000000025852efff]
[    0.000000]   node   0: [mem 0x000000025852f000-0x00000002586b6fff]
[    0.000000]   node   0: [mem 0x00000002586b7000-0x00000002589bffff]
[    0.000000]   node   0: [mem 0x00000002589c0000-0x00000002589dffff]
[    0.000000]   node   0: [mem 0x00000002589e0000-0x0000000258c5ffff]
[    0.000000]   node   0: [mem 0x0000000258c60000-0x0000000258caffff]
[    0.000000]   node   0: [mem 0x0000000258cb0000-0x000000025908ffff]
[    0.000000]   node   0: [mem 0x0000000259090000-0x00000002590dffff]
[    0.000000]   node   0: [mem 0x00000002590e0000-0x00000002590effff]
[    0.000000]   node   0: [mem 0x00000002590f0000-0x000000025911ffff]
[    0.000000]   node   0: [mem 0x0000000259120000-0x000000025915ffff]
[    0.000000]   node   0: [mem 0x0000000259160000-0x000000025917ffff]
[    0.000000]   node   0: [mem 0x0000000259180000-0x000000025925ffff]
[    0.000000]   node   0: [mem 0x0000000259260000-0x00000002592fffff]
[    0.000000]   node   0: [mem 0x0000000259300000-0x00000002593bffff]
[    0.000000]   node   0: [mem 0x00000002593c0000-0x00000002597cffff]
[    0.000000]   node   0: [mem 0x00000002597d0000-0x000000025981ffff]
[    0.000000]   node   0: [mem 0x0000000259820000-0x000000025986ffff]
[    0.000000]   node   0: [mem 0x0000000259870000-0x0000000259d3ffff]
[    0.000000]   node   0: [mem 0x0000000259d40000-0x0000000259d4ffff]
[    0.000000]   node   0: [mem 0x0000000259d50000-0x0000000259ecffff]
[    0.000000]   node   0: [mem 0x0000000259ed0000-0x0000000259f6ffff]
[    0.000000]   node   0: [mem 0x0000000259f70000-0x000000025a06ffff]
[    0.000000]   node   0: [mem 0x000000025a070000-0x000000025a10ffff]
[    0.000000]   node   0: [mem 0x000000025a110000-0x000000025a1bffff]
[    0.000000]   node   0: [mem 0x000000025a1c0000-0x000000025a25ffff]
[    0.000000]   node   0: [mem 0x000000025a260000-0x000000025ab6ffff]
[    0.000000]   node   0: [mem 0x000000025ab70000-0x000000025ad4ffff]
[    0.000000]   node   0: [mem 0x000000025ad50000-0x000000027c4fffff]
[    0.000000]   node   0: [mem 0x000000027c500000-0x000000027c54ffff]
[    0.000000]   node   0: [mem 0x000000027c550000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839268
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[    0.000000] Memory: 6934996K/7473852K available (18112K kernel code, 3170K rwdata, 7140K rodata, 3968K init, 1108K bss, 473320K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000023] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000683] Console: colour dummy device 80x25
[    0.002109] printk: console [tty0] enabled
[    0.002168] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002200] pid_max: default: 32768 minimum: 301
[    0.002346] LSM: Security Framework initializing
[    0.002398] Yama: becoming mindful.
[    0.002437] SELinux:  Initializing.
[    0.002569] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002604] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.005677] rcu: Hierarchical SRCU implementation.
[    0.005921] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006604] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[    0.006669] DTB Build time: Mar 19 2023 08:08:44
[    0.009418] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.009668] Remapping and enabling EFI services.
[    0.011431] smp: Bringing up secondary CPUs ...
[    0.040582] Detected PIPT I-cache on CPU1
[    0.040680] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.071239] Detected PIPT I-cache on CPU2
[    0.071335] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.100776] Detected PIPT I-cache on CPU3
[    0.100861] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.130417] Detected PIPT I-cache on CPU4
[    0.130558] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.160076] Detected PIPT I-cache on CPU5
[    0.160219] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.160500] smp: Brought up 1 node, 6 CPUs
[    0.160862] SMP: Total of 6 processors activated.
[    0.160953] CPU features: detected: Privileged Access Never
[    0.160986] CPU features: detected: LSE atomic instructions
[    0.161008] CPU features: detected: User Access Override
[    0.161030] CPU features: detected: 32-bit EL0 Support
[    0.161050] CPU features: detected: RAS Extension Support
[    0.161070] CPU features: detected: CRC32 instructions
[    0.161091] CPU features: detected: 32-bit EL1 Support
[    0.234862] CPU: All CPU(s) started at EL2
[    0.240880] devtmpfs: initialized
[    0.282693] Registered cp15_barrier emulation handler
[    0.282828] Registered setend emulation handler
[    0.282861] KASLR enabled
[    0.283116] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.283157] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.284515] pinctrl core: initialized pinctrl subsystem
[    0.285508] SMBIOS 3.0.0 present.
[    0.285542] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[    0.286177] NET: Registered protocol family 16
[    0.287910] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.288431] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.289129] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.289192] audit: initializing netlink subsys (disabled)
[    0.289464] audit: type=2000 audit(0.284:1): state=initialized audit_enabled=0 res=1
[    0.289862] thermal_sys: Registered thermal governor 'step_wise'
[    0.289868] thermal_sys: Registered thermal governor 'power_allocator'
[    0.289937] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.292037] cpuidle: using governor menu
[    0.292430] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.292808] ASID allocator initialised with 32768 entries
[    0.293034] Serial: AMBA PL011 UART driver
[    0.295858] Tegra reboot handler registered.
[    0.363025] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[    0.363080] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[    0.363118] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[    0.363154] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[    0.363192] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[    0.363228] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[    0.363267] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[    0.363302] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[    0.363336] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[    0.363370] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[    0.363405] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[    0.363439] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[    0.363473] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[    0.363508] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[    0.363542] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[    0.363586] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[    0.363622] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[    0.363715] mc-err: mcerr ops are set to t19x
[    0.377093] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.377132] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.377161] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.377186] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.384009] ACPI: Interpreter disabled.
[    0.385130] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.386328] iommu: Default domain type: Translated
[    0.386405] eventlib_kernel: keventlib is initialized, test id: 0
[    0.386782] SCSI subsystem initialized
[    0.386947] usbcore: registered new interface driver usbfs
[    0.386994] usbcore: registered new interface driver hub
[    0.387039] usbcore: registered new device driver usb
[    0.387431] mc: Linux media interface: v0.10
[    0.387475] videodev: Linux video capture interface: v2.00
[    0.387751] pps_core: LinuxPPS API ver. 1 registered
[    0.387774] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.387809] PTP clock support registered
[    0.388010] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.388343] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.388434] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.388992] Registered efivars operations
[    0.394490] FPGA manager framework
[    0.394577] Advanced Linux Sound Architecture Driver Initialized.
[    0.395191] Bluetooth: Core ver 2.22
[    0.395235] NET: Registered protocol family 31
[    0.395253] Bluetooth: HCI device and connection manager initialized
[    0.395279] Bluetooth: HCI socket layer initialized
[    0.395301] Bluetooth: L2CAP socket layer initialized
[    0.395330] Bluetooth: SCO socket layer initialized
[    0.397839] camchar: rtcpu character device driver loaded
[    0.398949] clocksource: Switched to clocksource arch_sys_counter
[    0.799234] VFS: Disk quotas dquot_6.6.0
[    0.799334] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.799817] pnp: PnP ACPI: disabled
[    0.814128] la/ptsa driver initialized.
[    0.814280] NET: Registered protocol family 2
[    0.814504] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.822101] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.822323] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.822697] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.823422] TCP: Hash tables configured (established 65536 bind 65536)
[    0.823607] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.823784] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.824049] NET: Registered protocol family 1
[    0.824792] RPC: Registered named UNIX socket transport module.
[    0.824838] RPC: Registered udp transport module.
[    0.824863] RPC: Registered tcp transport module.
[    0.824888] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.824927] PCI: CLS 0 bytes, default 64
[    0.825244] Trying to unpack rootfs image as initramfs...
[    1.107957] Freeing initrd memory: 9120K
[    1.113447] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.113822] kvm [1]: IPA Size Limit: 40 bits
[    1.114366] kvm [1]: vgic interrupt IRQ9
[    1.114868] kvm [1]: VHE mode initialized successfully
[    1.116650] Initialise system trusted keyrings
[    1.117009] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.123309] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.124057] NFS: Registering the id_resolver key type
[    1.124094] Key type id_resolver registered
[    1.124107] Key type id_legacy registered
[    1.124192] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.124242] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.124282] ntfs: driver 2.1.32 [Flags: R/W].
[    1.134792] NET: Registered protocol family 38
[    1.134813] Key type asymmetric registered
[    1.134828] Asymmetric key parser 'x509' registered
[    1.134881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.135142] io scheduler mq-deadline registered
[    1.135159] io scheduler kyber registered
[    1.141213] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[    1.144427] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.144537] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.144639] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.144736] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.144812] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.150786] scrncapt: init (heads:4 wins:6 planes:4)
[    1.151091] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    1.151984] EINJ: ACPI disabled.
[    1.155234] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.155258] tegra-pmc: ### PMC reset source: MAINSWRST
[    1.155272] tegra-pmc: ### PMC reset level: L1
[    1.155313] tegra-pmc: ### PMC reset status reg: 0x2d
[    1.155360] tegra-pmc: PMC Prod config success
[    1.160241] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.174568] random: fast init done
[    1.175679] printk: console [ttyTCU0] enabled
[    2.654379] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.658998] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.663605] arm-smmu 10000000.iommu:         stage 1 translation
[    2.669270] arm-smmu 10000000.iommu:         stage 2 translation
[    2.674514] arm-smmu 10000000.iommu:         nested translation
[    2.680111] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.687285] arm-smmu 10000000.iommu:         64 context banks (0 stage-2 only)
[    2.697664] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.700147] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.706965] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.714451] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.719751] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.724471] arm-smmu 12000000.iommu:         stage 1 translation
[    2.730249] arm-smmu 12000000.iommu:         stage 2 translation
[    2.735671] arm-smmu 12000000.iommu:         nested translation
[    2.740835] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.748017] arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
[    2.758297] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.761392] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.767696] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.775589] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.785221] tegra_profiler: version: 1.150, samples/io: 50/29
[    2.788125] tegra_profiler: auth: init
[    2.792483] THERMAL EST: found 3 subdevs
[    2.796049] THERMAL EST num_resources: 0
[    2.799661] [THERMAL EST subdev 0]
[    2.803215] [THERMAL EST subdev 1]
[    2.806353] [THERMAL EST subdev 2]
[    2.809871] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.816290] THERMAL EST: thz register success.
[    2.820311] THERMAL EST: end of probe, return err: 0
[    2.825877] nvsciipc: loaded module
[    2.832865] tun: Universal TUN/TAP device driver, 1.6
[    2.835219] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.841369] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.846962] e1000e: Intel(R) PRO/1000 Network Driver
[    2.852130] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.857945] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.863502] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.869634] PPP generic driver version 2.4.2
[    2.873915] PPP BSD Compression module registered
[    2.878483] PPP Deflate Compression module registered
[    2.883759] PPP MPPE Compression module registered
[    2.888484] usbcore: registered new interface driver r8152
[    2.894252] usbcore: registered new interface driver asix
[    2.899320] usbcore: registered new interface driver ax88179_178a
[    2.905446] usbcore: registered new interface driver cdc_ether
[    2.911691] usbcore: registered new interface driver net1080
[    2.916997] usbcore: registered new interface driver cdc_subset
[    2.923290] usbcore: registered new interface driver zaurus
[    2.929019] usbcore: registered new interface driver cdc_ncm
[    2.934665] usbcore: registered new interface driver aqc111
[    2.940102] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.946128] ohci-pci: OHCI PCI platform driver
[    2.950704] ohci-platform: OHCI generic platform driver
[    2.956360] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.962855] usbcore: registered new interface driver uas
[    2.967069] usbcore: registered new interface driver usb-storage
[    2.972875] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.979086] mousedev: PS/2 mouse device common for all mice
[    2.984126] usbcore: registered new interface driver xpad
[    2.991888] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.994848] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[    3.002665] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.009246] i2c /dev entries driver
[    3.012281] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.018245] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.023653] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.028807] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.034107] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.039669] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.045342] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.058270] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    3.059049] device-mapper: uevent: version 1.0.3
[    3.062180] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.072679] cpuidle: Initializing cpuidle driver
[    3.076462] sdhci: Secure Digital Host Controller Interface driver
[    3.080962] sdhci: Copyright(c) Pierre Ossman
[    3.085411] Synopsys Designware Multimedia Card Interface Driver
[    3.091620] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.097560] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    3.098361] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    3.111113] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.133330] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    3.143383] vdd-1v0: supplied by regulator-dummy
[    3.148824] vdd-1v8-hs: supplied by regulator-dummy
[    3.153627] vdd-1v8-ls: supplied by regulator-dummy
[    3.158395] vdd-1v8-ao: supplied by regulator-dummy
[    3.162272] vddio-ddr-1v1: supplied by regulator-dummy
[    3.167013] vdd-rtc: supplied by regulator-dummy
[    3.169015] spmic-ldo1: supplied by regulator-dummy
[    3.170643] vdd-ao-3v3: supplied by regulator-dummy
[    3.177218] vddio-emmc-3v3: supplied by regulator-dummy
[    3.183813] spmic-ldo4: supplied by regulator-dummy
[    3.185310] vdd-usb-3v3: supplied by regulator-dummy
[    3.191764] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.198180] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.204303] spmic-ldo8: supplied by vdd-1v8-ls
[    3.206258] gpio-510 (gpio_default): hogged as output/high
[    3.208273] gpio-511 (gpio_default): hogged as output/high
[    3.211096] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.346545] max77686-rtc max77620-rtc: registered as rtc0
[    3.347590] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[    3.347923] max77620 4-003c: max77620 probe successful
[    3.470552] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    3.471711] hid: raw HID events driver (C) Jiri Kosina
[    3.472538] usbcore: registered new interface driver usbhid
[    3.472688] usbhid: USB HID core driver
[    3.474817] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[    3.476088] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
▒▒[    27.769849] Camera-FW on t194-rce-safe started
TCU early console enabled.
[    27.844154] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.775 ms, total boot 75.110 ms)
▒▒[    3.560314] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    3.560736] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    3.561660] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    3.562374] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    3.564338] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    3.565018] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    3.565543] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    3.566915] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[    3.567270] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    3.569814] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[    3.576966] tegra_aon c1a0000.aon: Adding to iommu group 5
[    3.582869] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    3.588239] tegra186-aondbg aondbg: aondbg driver probe() OK
[    3.594594] denver_knobs_init:MTS_VERSION:55637613
[    3.606678] t19x_cache tegra-cache: probed
[    3.609632] optee: probing for conduit method.
[    3.610447] optee: revision 3.19 (3f29c61f)
[    3.611525] optee: dynamic shared memory is enabled
[    3.615746] optee: initialized driver
[    3.621413] nvpmodel: initialized successfully
[    3.623032] tegra_hv: get_hvd: not initialized yet
[    3.627656] user_ivc_mempool: hypervisor not present
[    3.633089] usbcore: registered new interface driver snd-usb-audio
[    3.640093] u32 classifier
[    3.641432]     input device check on
[    3.645245]     Actions configured
[    3.648522] Initializing XFRM netlink socket
[    3.653439] NET: Registered protocol family 10
[    3.659794] Segment Routing with IPv6
[    3.661031] NET: Registered protocol family 17
[    3.665050] NET: Registered protocol family 15
[    3.669723] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.683451] Bluetooth: RFCOMM socket layer initialized
[    3.687755] Bluetooth: RFCOMM ver 1.11
[    3.691928] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.697536] Bluetooth: HIDP socket layer initialized
[    3.703547] 9pnet: Installing 9P2000 support
[    3.707177] Key type dns_resolver registered
[    3.712292] registered taskstats version 1
[    3.715377] Loading compiled-in X.509 certificates
[    3.753846] Loaded X.509 cert 'Build time autogenerated kernel key: abbb12ace44f7a1aef75190aed9faf7e7ae98700'
[    3.755653] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[    3.760791] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    3.761176] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    3.761538] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    3.761885] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    4.875565] tegra194-pcie 14160000.pcie: Phy link never came up
[    4.876203] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    4.876393] pci_bus 0004:00: root bus resource [bus 00-ff]
[    4.876639] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    4.877134] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    4.877297] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    4.877879] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    4.878340] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    4.900097] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    4.900550] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.902515] pcieport 0004:00:00.0: Adding to iommu group 6
[    4.904114] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    4.905467] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    4.907051] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    4.908230] pci 0004:00:00.0: Removing from iommu group 6
[    4.908705] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    4.912553] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[    4.918300] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    4.918736] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    4.919190] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    4.920842] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    6.035704] tegra194-pcie 141a0000.pcie: Phy link never came up
[    6.036543] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    6.036773] pci_bus 0005:00: root bus resource [bus 00-ff]
[    6.036982] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    6.037311] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    6.037546] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    6.037946] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    6.038360] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    6.055245] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    6.055819] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.057651] pcieport 0005:00:00.0: Adding to iommu group 7
[    6.059188] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    6.060701] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    6.061882] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    6.062664] pci 0005:00:00.0: Removing from iommu group 7
[    6.062926] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    6.098497] host1x 13e10000.host1x: Adding to iommu group 8
[    6.122358] host1x 13e10000.host1x: initialized
[    6.124203] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[    6.125036] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.126260] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[    6.126829] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.128038] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[    6.128640] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.129580] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[    6.130228] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.131191] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[    6.135800] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.145609] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[    6.152782] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    6.162561] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[    6.169595] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    6.179750] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[    6.186554] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    6.196489] falcon 15340000.vic: Adding to iommu group 17
[    6.210744] falcon 15340000.vic: initialized
[    6.211644] falcon 15380000.nvjpg: Adding to iommu group 17
[    6.216924] falcon 15380000.nvjpg: initialized
[    6.217489] falcon 154c0000.nvenc: Adding to iommu group 17
[    6.230104] falcon 154c0000.nvenc: initialized
[    6.230592] falcon 15a80000.nvenc1: Adding to iommu group 17
[    6.240477] falcon 15a80000.nvenc1: initialized
[    6.241191] nvdec 15480000.nvdec: Adding to iommu group 17
[    6.251624] nvdec 15480000.nvdec: initialized
[    6.252295] nvdec 15140000.nvdec1: Adding to iommu group 17
[    6.261245] nvdec 15140000.nvdec1: initialized
[    6.261783] tsec 15500000.tsec: Adding to iommu group 18
[    6.267557] tsec 15500000.tsec: initialized
[    6.268119] tsec 15100000.tsecb: Adding to iommu group 19
[    6.277258] tsec 15100000.tsecb: initialized
[    6.284084] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.311575] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.324857] gpio-374 (wifi-enable): hogged as output/high
[    6.325130] gpio-431 (camera-control-output-low): hogged as output/low
[    6.325372] gpio-432 (camera-control-output-low): hogged as output/low
[    6.327042] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    6.329022] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    6.329533] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.331109] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    6.333072] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.339452] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    6.344449] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.353166] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    6.360424] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[    6.371557] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.377004] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    6.383025] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.391851] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.400861] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[    6.407947] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    6.415819] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    6.422134] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.431405] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    6.438024] pva 16000000.pva0: Adding to iommu group 22
[    6.464661] pva 16000000.pva0: initialized
[    6.470070] pva 16800000.pva1: Adding to iommu group 23
[    6.482200] pva 16800000.pva1: initialized
[    6.487804] nvdla 15880000.nvdla0: Adding to iommu group 24
[    6.501252] nvdla 15880000.nvdla0: initialized
[    6.502911] nvdla 158c0000.nvdla1: Adding to iommu group 25
[    6.511370] nvdla 158c0000.nvdla1: initialized
[    6.516488] tegradccommon 15200000.display-hub: host1x channel mapped
[    6.516745] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[    6.516869] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    6.517046] tegradc 15200000.display: Adding to iommu group 26
[    6.517337] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    6.518290] tegradccommon 15200000.display-hub: dma mapping done
[    6.518725] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    6.522601] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    6.524633] tegradc 15210000.display: Adding to iommu group 26
[    6.524803] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.524915] generic_infoframe_type: 0x87
[    6.525013] tegradc 15200000.display: DT parsed successfully
[    6.525133] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.527391] tegra_cec 3960000.tegra_cec: probed
[    6.528590] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    6.528715] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.528730] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.528734] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.529921] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    6.529933] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    6.531384] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    6.535232] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    6.540147] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    6.544027] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    6.551450] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    6.559247] tegradc 15210000.display: disp0 connected to head1->sor
[    6.562552] kfuse 3830000.kfuse: initialized
[    6.567574] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    6.576394] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.584242] tegradc 15210000.display: DT parsed successfully
[    6.592398] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.593028] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.598074] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    6.693145] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    6.702210] serial-tegra 3110000.serial: Adding to iommu group 2
[    6.707504] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    6.716959] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.722165] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    6.742088] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    6.742457] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.745461] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.754183] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    6.762468] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[    6.769352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.776598] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.783782] usb usb1: Product: xHCI Host Controller
[    6.788722] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.795075] usb usb1: SerialNumber: 3610000.xhci
[    6.800821] hub 1-0:1.0: USB hub found
[    6.803600] hub 1-0:1.0: 4 ports detected
[    6.808238] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.813254] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.820599] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.828177] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.836431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.843419] usb usb2: Product: xHCI Host Controller
[    6.848653] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.854889] usb usb2: SerialNumber: 3610000.xhci
[    6.860250] hub 2-0:1.0: USB hub found
[    6.863351] hub 2-0:1.0: 4 ports detected
[    6.903769] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    6.910395] i2c i2c-2: Added multiplexed i2c bus 9
[    6.912186] i2c i2c-2: Added multiplexed i2c bus 10
[    6.912387] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    6.926094] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1907000 KHz, changing to: 1907200 KHz
[    6.927181] tegra194-cpufreq ccplex: probed with BWMGR
[    6.928331] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    6.928758] irq: IRQ261: trimming hierarchy from :pmc@c360000
[    6.929202] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[    6.930364] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    6.937475] tegra194-vi5 15c10000.vi: initialized
[    6.938757] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.940070] nvethernet 2490000.ethernet: Adding to iommu group 27
[    6.940239] mmc0: CQHCI version 5.10
[    6.943310] generic_infoframe_type: 0x87
[    6.949797] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    6.953430] tegradc 15200000.display: DT parsed successfully
[    6.957320] nvethernet 2490000.ethernet: failed to read MDIO address
[    6.965505] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.971012] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    6.971984] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    6.977971] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.985259] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    6.992140] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.992148] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    7.000026] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    7.008744] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    7.014816] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[    7.022946] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[    7.023133] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    7.031086] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[    7.038417] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    7.043485] nvethernet 2490000.ethernet: invalid resource
[    7.051744] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    7.053843] tegradc 15200000.display: probed
[    7.057790] mmc0: Command Queue Engine enabled
[    7.057795] mmc0: periodic cache flush enabled
[    7.057806] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    7.058203] nvethernet 2490000.ethernet: failed to ioremap MAC base address
[    7.058207] nvethernet 2490000.ethernet: failed to allocate platform resources
[    7.058275] nvethernet: probe of 2490000.ethernet failed with error -22
[    7.058319] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    7.058465] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[    7.062136]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[    7.070977] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    7.078207] irq: IRQ263: trimming hierarchy from :pmc@c360000
[    7.172780] irq: IRQ264: trimming hierarchy from :interrupt-controller@3881000
[    7.172855] Console: switching to colour frame buffer device 240x67
[    7.172953] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.180113] tegradc 15200000.display: fb registered
[    7.187674] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[    7.193021] irq: IRQ265: trimming hierarchy from :pmc@c360000
[    7.199708] tegra-se-nvhost 15810000.se: initialized
[    7.204823] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.215221] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    7.220822] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.227490] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[    7.239667] tegra-se-nvhost 15820000.se: initialized
[    7.246132] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    7.250915] usb 1-2: New USB device found, idVendor=0424, idProduct=2513, bcdDevice= b.b3
[    7.255132] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[    7.258516] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.265639] tegra-se-nvhost 15830000.se: initialized
[    7.273226] hub 1-2:1.0: USB hub found
[    7.278208] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    7.280873] hub 1-2:1.0: 3 ports detected
[    7.287786] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[    7.298144] tegra-se-nvhost 15840000.se: initialized
[    7.300506] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[    7.304401] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.312185] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[    7.318999] tegra_actmon d230000.actmon: in actmon_register()...
[    7.324920] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[    7.325503] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.331226] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    7.338471] Extcon AUX1(HDMI) enable
[    7.338589] tegradc 15210000.display: disp1 connected to head1->sor
[    7.355204] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.360838] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.369615] hvc_sysfs: hypervisor is not present
[    7.376292] tegradc 15210000.display: DT parsed successfully
[    7.386674] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[    7.421300] ALSA device list:
[    7.421403]   No soundcards found.
[    7.421645] tegradc 15210000.display: vblank syncpt # 17 for dc 1
[    7.421890] tegradc 15210000.display: vpulse3 syncpt # 18 for dc 1
[    7.428905] tegradc 15210000.display: probed
[    7.429241] tegradc 15210000.display: fb registered
[    7.432777] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    7.432989] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    7.436725] Freeing unused kernel memory: 3968K
[    7.437949] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    7.443116] Run /init as init process
[    7.452005] tegradc 15210000.display: blank - powerdown
[    7.456960] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    7.456963] Extcon DP: HPD disabled
[    7.456984] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    7.457001] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    7.481581] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    7.505684] tegradc 15200000.display: blank - powerdown
[    7.513753] Root device found: mmcblk0p1
[    7.550919] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    7.550961] Extcon AUX1(HDMI) disable
[    7.574522] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    7.575479] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    7.582987] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    7.582992] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    7.588804] tegradc 15200000.display: unblank
[    7.589937] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.590132] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.596224] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    7.598214] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[    7.602207] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.602211] Extcon AUX1(HDMI) enable
[    7.615019] tegradc 15200000.display: sync windows ret = 246
[    7.643549] extcon-disp-state external-connection:disp-state: cable 53 state 1
[    7.643553] Extcon HDMI: HPD enabled
[    7.643558] tegradc 15200000.display: hdmi: plugged
[    7.654193] Found dev node: /dev/mmcblk0p1
[    7.691589] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.697204] Rootfs mounted over mmcblk0p1
[    7.737166] Switching from initrd to actual rootfs
[    7.886226] systemd[1]: System time before build time, advancing clock.
[    7.910513] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[    8.214661] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    8.220265] systemd[1]: Detected architecture arm64.
[    8.257762] systemd[1]: No hostname configured.
[    8.259321] systemd[1]: Set hostname to <localhost>.
[    8.783456] random: crng init done
[    8.970471] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    8.972372] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    8.978046] systemd[1]: Created slice system-modprobe.slice.
[    8.982846] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.986277] systemd[1]: Reached target Slices.
[    8.989636] systemd[1]: Reached target Swap.
[    8.993747] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.997540] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.001068] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.005386] systemd[1]: Listening on Journal Audit Socket.
[    9.007066] tegra-xusb 3610000.xhci: entering ELPG done
[    9.011125] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.015157] systemd[1]: Listening on Journal Socket.
[    9.019126] systemd[1]: Listening on udev Control Socket.
[    9.022727] systemd[1]: Listening on udev Kernel Socket.
[    9.030719] systemd[1]: Mounting Huge Pages File System...
[    9.039122] systemd[1]: Mounting POSIX Message Queue File System...
[    9.047993] systemd[1]: Mounting Kernel Debug File System...
[    9.056718] systemd[1]: Mounting Kernel Trace File System...
[    9.066664] systemd[1]: Starting Journal Service...
[    9.074545] systemd[1]: Starting Set the console keyboard layout...
[    9.083196] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    9.091684] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    9.100500] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.109454] systemd[1]: Starting Load Kernel Module pstore_blk...
[    9.118542] systemd[1]: Starting Load Kernel Module pstore_zone...
[    9.127342] systemd[1]: Starting Load Kernel Module ramoops...
[    9.137294] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.169276] systemd[1]: Started Nameserver information manager.
[    9.173980] systemd[1]: Reached target Network (Pre).
[    9.182965] systemd[1]: Starting Set console scheme...
[    9.187420] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.189177] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.196986] systemd[1]: Starting Load Kernel Modules...
[    9.204278] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.212770] systemd[1]: Starting udev Coldplug all Devices...
[    9.250005] systemd[1]: Mounted Huge Pages File System.
[    9.259199] systemd[1]: Mounted POSIX Message Queue File System.
[    9.263201] systemd[1]: Mounted Kernel Debug File System.
[    9.274497] systemd[1]: Mounted Kernel Trace File System.
[    9.289754] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    9.292170] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    9.301076] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[    9.301204] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.304866] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[    9.305415] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[    9.307807] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    9.307820] nvmap_page_pool_init: Total RAM pages: 1753405
[    9.307825] nvmap_page_pool_init: nvmap page pool size: 219175 pages (856 MB)
[    9.308168] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.309576] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[    9.315649] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    9.315660] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    9.321638] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[    9.325477] systemd[1]: Finished Load Kernel Module efi_pstore.
[    9.330982] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[    9.334893] systemd[1]: Finished Load Kernel Module pstore_blk.
[    9.339798] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[    9.345233] systemd[1]: Finished Load Kernel Module pstore_zone.
[    9.350013] systemd[1]: modprobe@ramoops.service: Succeeded.
[    9.355307] systemd[1]: Finished Load Kernel Module ramoops.
[    9.365978] systemd[1]: Finished Set console scheme.
[    9.372564] systemd[1]: Finished Remount Root and Kernel File Systems.
[    9.385859] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.388235] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.394350] systemd[1]: Starting Load/Save Random Seed...
[    9.404950] systemd[1]: Starting Create System Users...
[    9.410186] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    9.410186]
[    9.411985] systemd[1]: Finished Set the console keyboard layout.
[    9.464479] systemd[1]: Finished Load Kernel Modules.
[    9.472002] systemd[1]: Finished Load/Save Random Seed.
[    9.476759] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.483536] systemd[1]: Mounting Kernel Configuration File System...
[    9.491926] systemd[1]: Started OP-TEE Client Supplicant.
[    9.500032] systemd[1]: Starting Apply Kernel Variables...
[    9.508007] systemd[1]: nvfb-udev.service: Succeeded.
[    9.511995] systemd[1]: Finished NVIDIA specific first-boot udev script.
[    9.516176] systemd[1]: Mounted Kernel Configuration File System.
[   11.222334] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_unregister
[   11.224289] nv_imx219: Unknown symbol tegracam_v4l2subdev_unregister (err -22)
[   11.233015] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_register
[   11.241931] nv_imx219: Unknown symbol tegracam_v4l2subdev_register (err -22)
[   11.243437] nv_imx219: disagrees about version of symbol tegracam_device_unregister
[   11.255376] nv_imx219: Unknown symbol tegracam_device_unregister (err -22)
[   11.256762] nv_imx219: disagrees about version of symbol tegracam_get_privdata
[   11.257994] nv_imx219: Unknown symbol tegracam_get_privdata (err -22)
[   11.259263] nv_imx219: disagrees about version of symbol camera_common_mclk_enable
[   11.260581] nv_imx219: Unknown symbol camera_common_mclk_enable (err -22)
[   11.267689] nv_imx219: disagrees about version of symbol camera_common_mclk_disable
[   11.269061] nv_imx219: Unknown symbol camera_common_mclk_disable (err -22)
[   11.270375] nv_imx219: disagrees about version of symbol tegracam_set_privdata
[   11.272769] nv_imx219: Unknown symbol tegracam_set_privdata (err -22)
[   11.274132] nv_imx219: disagrees about version of symbol tegracam_device_register
[   11.275744] nv_imx219: Unknown symbol tegracam_device_register (err -22)
[   11.316897] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_unregister
[   11.318260] nv_imx219: Unknown symbol tegracam_v4l2subdev_unregister (err -22)
[   11.319745] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_register
[   11.321121] nv_imx219: Unknown symbol tegracam_v4l2subdev_register (err -22)
[   11.322438] nv_imx219: disagrees about version of symbol tegracam_device_unregister
[   11.329522] nv_imx219: Unknown symbol tegracam_device_unregister (err -22)
[   11.332079] nv_imx219: disagrees about version of symbol tegracam_get_privdata
[   11.333545] nv_imx219: Unknown symbol tegracam_get_privdata (err -22)
[   11.334856] nv_imx219: disagrees about version of symbol camera_common_mclk_enable
[   11.336209] nv_imx219: Unknown symbol camera_common_mclk_enable (err -22)
[   11.337536] nv_imx219: disagrees about version of symbol camera_common_mclk_disable
[   11.338892] nv_imx219: Unknown symbol camera_common_mclk_disable (err -22)
[   11.340326] nv_imx219: disagrees about version of symbol tegracam_set_privdata
[   11.343818] nv_imx219: Unknown symbol tegracam_set_privdata (err -22)
[   11.354122] nv_imx219: disagrees about version of symbol tegracam_device_register
[   11.378433] nv_imx219: Unknown symbol tegracam_device_register (err -22)
[   11.776886] using random self ethernet address
[   11.778313] using random host ethernet address
[   12.873140] using random self ethernet address
[   12.874620] using random host ethernet address
[   13.148479] CPU4: shutdown
[   13.188269] CPU5: shutdown
[   16.351082] nvadsp 2993000.adsp: ADSP OS loading timed out
[   16.352753] nvadsp 2993000.adsp: Unable to start ADSP OS
[   16.354061] nvadsp 2993000.adsp: adsp failed to boot with ret = -62
[   16.355339] nvadsp 2993000.adsp: Dumping ADSP logs ........
[   16.357968] nvadsp 2993000.adsp: End of ADSP log dump  .....
[   16.359240] nvadsp 2993000.adsp: dumping fault frame...
[   16.360433] nvadsp 2993000.adsp: r0  0x00000000 r1  0x00000000 r2  0x00000000 r3  0x00000000
[   16.361714] nvadsp 2993000.adsp: r4  0x00000000 r5  0x00000000 r6  0x00000000 r7  0x00000000
[   16.363051] nvadsp 2993000.adsp: r8  0x00000000 r9  0x00000000 r10 0x00000000 r11 0x00000000
[   16.364350] nvadsp 2993000.adsp: r12 0x00000000 usp 0x00000000 ulr 0x00000000 pc  0x00000000
[   16.365661] nvadsp 2993000.adsp: spsr 0x00000000
[   16.366864] nvadsp 2993000.adsp: dumping arm mode register data...
[   16.368139] nvadsp 2993000.adsp:   fiq r13 0x00000000 r14 0x00000000
[   16.369428] nvadsp 2993000.adsp:   irq r13 0x00000000 r14 0x00000000
[   16.370659] nvadsp 2993000.adsp:   svc r13 0x00000000 r14 0x00000000
[   16.371921] nvadsp 2993000.adsp:   und r13 0x00000000 r14 0x00000000
[   16.373108] nvadsp 2993000.adsp:   sys r13 0x00000000 r14 0x00000000
[   16.374315] nvadsp 2993000.adsp:   abt r13 0x00000000 r14 0x00000000
[   16.380046] tegra210-adsp tegra210-adsp: Failed to start OS
[   16.384846] tegra210-adsp tegra210-adsp: Failed to init ADSP.
[   16.470086] tegra210-adsp: probe of tegra210-adsp failed with error -62
[   21.065596] nvidia: loading out-of-tree module taints kernel.
[   23.684869] Please complete system configuration setup on desktop to proceed...
Do you have any idea ?
Best regards,
Julien.
I just try with a new Jetson NX devkit without any fuse burned. So like that I can use your custom command to force flashing EKS partition and I have the same issue I generate and change bootloader/eks_t194.img but I have a bad parameter and board not boot.
entering main console loop
] ▒▒NG: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
E/TC:0 0 ekb_extraction_process:227 Bad parameter: eks image not correct
E/TC:0 0 jetson_user_key_pta_init:801 jetson_user_key_pta_init: Failed (ffff0006).
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x000c3240 failed
I/TC: Primary CPU switching to normal world boot
  [0003.320] I> Welcome to NVDisp-Init
[0003.320] I> NVDisp-Init version: t194-709c0123
Best regards
did you setup a display monitor? above messages pop-up means it’s waiting for system configuration.
you may also check Skipping oem-config by running l4t_create_default_user.sh before you flash the target.
Hi JerryChang,
Your right and I know I have a HDMI screen plugged to the board and its boot well but with an issue with EKS image not correct. When I disable encryption boot is ok but with user_key normally if I have an issue with eks I can"t boot because user key in eks is needed to uncrypt user image like kernel like you explain me in previous post ?
Best regards,
hello JulienMoinard,
I’m a bit confused with your test results…
let me explain as following.
the user_key is specified in eks.img. user_key is purely software, user can define it; 0 user_key means no encryption.
please also check the commands to generate eks.img
for example,
$ python3 gen_ekb.py -chip t194 -kek2_key <kek2_fuse_key_file> -fv <fv_for_ekb_ek> -in_sym_key <sym_key_file> -in sym_key2 <sym2_key_file> -out <eks_image_file>
for example,
<sym_key_file> above is the user_key; this also the key of kernel encryption key.
since you have a non-zero user_key, you have to generate eks.img with the keys, and copy the file to bootloader folder. the key within eks.img and flash commands, --user_key should be identical.
<sym2_key_file> is the LUKS key for disk encryption support. it’s the -i in flash commands to assign key for EKB.
Hello Jerry Chang,
Excuse me for confusing but I try lot of things to understand where is the problem.
I agree with you and I understand EKS and I have a working project for over two years but for now in this version I have a big issue to generate / use EKS and I don’t know why.
I am so frustrated.
Best regards,
please share your whole steps in detail, let’s start from the beginning.
please do confirm you’re used the same for EKS generation, and also image flashing.
From a fresh installation it works well on JetPack4.6.3 and NOT on JetPack5.1 (I change eks_t194.img instead of eks.img, I try eks.img too but without any result).
Do you change anythink else ? I use the last gen_ekb like you see.
Do you change any format in keys for EKS or something else ?
Where I made mistake ?
Working on JetPack_4.6.3
I generate and replace eks.img in bootloader folder.
sudo python3 gen_ekb.py -chip t194 -kek2_key key2.key -fv fv_ekb -in_sym_key user.key -in_sym_key2 disk.key -out bootloader/eks.img
Flash command JetPack 4.6.3
lootus@ubuntu:~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra$ sudo ROOTFS_ENC=1 ./flash.sh -u keys/rsa.key -v keys/sbk.key -i keys/disk.key --user_key keys/user.key jetson-xavier-nx-devkit-emmc mmcblk0p1
Full flash command for reference
FlashCommandJtPack4.6.3.txt (145.8 KB)
Full successful boot sequence for reference
WorkingOnJetPack4.6.3.txt (39.7 KB)
But NOT Working on JetPack_5.1
I generate and replace eks_t194.img instead of eks.img in bootloader folder.
sudo python3 gen_ekb.py -chip t194 -kek2_key key2.key -fv fv_ekb -in_sym_key user.key -in_sym_key2 disk.key -out bootloader/eks_t194.img
Same Flash command but with JetPack 5.1
lootus@ubuntu:~/nvidia/nvidia_sdk/JetPack_5.1_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra$ sudo ROOTFS_ENC=1 ./flash.sh -u keys/rsa.key -v keys/sbk.key -i keys/disk.key --user_key keys/user.key jetson-xavier-nx-devkit-emmc mmcblk0p1
Not working with JetPack 5.1 Bad parameter: eks image not correct
[0002.817] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.819] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE:  BL31: v2.6(release):6363e7382
NOTICE:  BL31: Built : 15:09:29, Jan 24 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Jan 24 23:20:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x000c3120 failed
FlashCommandjetPack5.1.txt (124.9 KB)
Not working full boot sequence for reference
NotworkingJetpack5.1.txt (59.0 KB)
Best regards,
Julien
it’s failure when EKB extraction, the error is due to mismatch content header.
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x000c3120 failed`
there’re several test approaches you may give them a try…
(1) could you please double check eks_t194.img has updated correctly.
(2) please try not using user_key.
(3) is it possible to validate with r35.3.1 release version?
Like you can see in my previous post I have the same issue on r35.3.1. I not recompile UEFI I use your last release (r35.3.1) instead.
When you tell me not using user_key I already done that on my previous post but I need user_key to generate EKS ? So user_key is in eks but not provided in flash command ?
I update eks_t194.img like I update eks.img for Jetpack 4.6.3 I don’t understand.
Best regards,
This doesn’t work for me on l4t-r35.3.1.
Could you share with us all information with example keys to use with gen_ekb.py please ?
Best regards,
Julien.
it turns out there’s an issue with --user_key.
FYI,
the option --user_key is only supported with JP-4.x to encrypt/decrypt user images, such as kernel/kernel-dtb.
however, this options is no longer supported with JP-5.x, it’s replaced by --uefi-enc options, and it’ll be available by the next JP-5 release, i.e. Jetpack-5.1.2 release version.
back to your original question…
the root cause might be the EKS image is not correctly decrypted.
you’ll need to check kek2.key which is used to encrypt EKS image.
hence,
please check… whether the KEK2 key is burned into the target.
a) If yes…, could you please check whether the burned KEK2 key is the same as the key2.key used in generating eks image?
b) If no…, could you please check whether the key2.key includes zeros key.
Hello JerryChang,
Thank you so much for your answer about --user_key I need to wait for your next release , do you have any lead time ?
Your right, I will double check by kek2 key.
Do you think I need to use last odmfuse from jetpack 5 to fuse a new board to ensure that the format / bit order of the key is ok ? Or you don’t change anything with odmfuse in the last 2 years ?
In another word can I use an old already fused board with old odmfuse script to flash with new jetpack 5 ?
I have so many already fused board so I your change something probably I can’t use anymore my old SOM already fused ?
Best regards,
I don’t have solid schedule for next JP-5 release, sorry for that.
please expect it may not be available soon since JP-5.1.1 has just public in late March.
as mentioned above, you should avoid using --user_key for JP-5.
as long as all fused/flashing keys are match, image flashing should also works.
furthermore, we had also confirm with the device that fused before (in JP-4). and we verify with flashing JP-5 image to it.
Hi Julien,
I’ve successfully enabled diskencryption with uefi secureboot on this release, however Im using a Xavier AGX…
As JerryChang already mentioned, --user-key is not support on this release. See my post: UEFI Secureboot JP 5.1.1 L4T 35.3.1 - #19 by riboyama
I took a quick look at the Jetpack 4.5 docs, it seems that your board is fused correctly and that your fuses are compatible with this release. However, I’m no expert so take this with a grain of salt.
Generating eks_t194.img:
python3 gen_ekb.py -chip t194 -kek2_key kek2.key \
        -fv fv_ekb_t194.key \
        -in_sym_key sym_t194.key \
        -in_sym_key2 sym2_t194.key \
        -out eks_t194.img
  • The fv_ekb_194.key should be bad66eb4484983684b992fe54a648bb8, unless you have recompiled the optee sources with another key.
  • ---user-key is unsupported. sym_t194.key is the user_key. So sym_t194.key must be all zero’s: 00000000000000000000000000000000
  • sym2_t194.key is your rootfs encryption key. It will also be used for flash.sh -i sym2_t194.key
  • Copy eks_t194.img to Linux_for_Tegra/bootloader/eks_t194.img
Flashing:
The flash.sh script is broken in this release if you enable Secureboot and Diskencryption together when using flash.sh See my post for the fix.
After you’ve edited disk_encryption_helper.func you can now flash:
The correct flash command for PKC + SBK + DiskEncryption + UEFI Secureboot (AGX devkit) is sudo ROOTFS_ENC=1 ./flash.sh --uefi-keys uefi_keys/uefi_keys.conf -i $sym2file -u $keyfile -v $sbkfile jetson-agx-xavier-devkit mmcblk0p1
On first boot you will see that dbx and dbt cannot be enrolled, this is OK.
On reboot you should see Skipped - USER_MODE, this means that the uefi secureboot is enabled.
Hi Riboyama,
Thank you so much for your help for UEFI it is works well except some warning message that I can remove by myself if I recompile uefi binary. So thank again.
For my issue with EKS you answer some question I have, user key need to be 0 to be used with gen_ekb. But I have always an issue.
I try without SBK and PKC by using KEK2 to 0 and user_key to 0 on unfused board :
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/keys$ sudo python3 gen_ekb.py -kek2_key key2.key -fv fv_ekb -in_sym_key user.key -in_sym_key2 disk.key -out ../bootloader/eks_t194.img
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/keys$ cat key2.key
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/keys$ cat user.key
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/keys$ cat disk.key
7B233A2F57E7EFA655A6F7B963E8EBCC
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/keys$ cat fv_ekb
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra$ sudo ROOTFS_ENC=1 ./flash.sh -i keys/disk.key jetson-xavier-nx-devkit-emmc mmcblk0p1
[sudo] Mot de passe de lootus :
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
Change device boot from mmcblk0p1 to internal
# Target Board Information:
# Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: enabled ,
copying soft_fuses(/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
] ▒▒: This OP-TEE configuration might be insecure!
I don’t understand this kek2.key work on jetpack 4 , I try to change kek2.key on jetpack 4 by changing a byte and of course It doesn’t work with a similar issue so my kek2 key on jetpack 4 is right but the same for jetpack 5 . I am so confused
So you seems right my kek2 key is not the right one . Are your really sure that an old board fused witht odmfuse from jetpack 4 is not an issue to use this board fused to be usable with jetpack 5 ?
Any change on hardware SOM that explain that ?
I am crazy !
Best julien.
I guess you could check the odmfuse config on your Jetpack 4.x to see if the key matches with your fuses.
Can you try copying the eks_t194.img with cp, instead of using --out ../bootloader/eks_t194.img maybe the tool doesn’t overwrite the image correctly?
python3 gen_ekb.py -kek2_key key2.key -fv fv_ekb -in_sym_key user.key -in_sym_key2 disk.key -out eks_t194.img
cp eks_t194.img Linux_for_Tegra/bootloader/eks_t194.img
Do you have an idea how to check that keys match with fuse ?
Because in Jetpack 4 gen_ekb work well and linux boot properly with disk encryption.
But not in Jetpack 5 but if it is works well at your side , I make a mistake probably ?
sudo python3 gen_ekb.py -kek2_key key2.key -fv fv_ekb -in_sym_key user.key -in_sym_key2 disk.key -out eks_t194.img
lootus@ubuntu:/local/dev/photon-5.1/nvidia_sdk/JetPack_5.1.1/Linux_for_Tegra/bootloader$ cp keys/eks_t194.img bootloader/eks_t194.img
As you can see, file has been updated before upgrade
But after flash , my eks_t194.img file was updated and do you know why ? for signing probably but sign is in another file ?
Do you have an example to use ODM fuse compare with mine ?
Best regards,
Julien.
I just try with a new board and fuse with known keys but I have the same issue.
[0002.760] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.761] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE:  BL31: v2.6(release):07eea4970
NOTICE:  BL31: Built : 07:55:15, Mar 19 2023
I/TC:
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:42 UTC 2023 aarch64
Sombody can confirm me that encryption disk work on JetPack 5.1.1 with a Jetson Nx ?
It is very important for me to be able to load this eks img
Best regards,
Julien.
