I’m running TensorRT 5.0.3 on a Xavier board. I want to implement a plugin for TF’s split operation. Here is a simple model I created for testing:
import uff
import numpy as np
import tensorflow as tf
x = np.array([[31, 23, 4, 24, 27, 34],
[18, 3, 25, 0, 6, 35],
[28, 14, 33, 22, 20, 8]])
print(x.shape)
input = tf.placeholder(tf.float32, shape=x.shape, name='input')
split = tf.split(input, x.shape[0], name='output')
with tf.Session() as sess:
out = sess.run(split, feed_dict = {input: x})
print(out)
g = tf.get_default_graph()
print(g.get_operations())
train_writer = tf.summary.FileWriter("session.log", sess.graph)
uff_model = uff.from_tensorflow(
tf.get_default_graph(),
output_nodes=['output'],
output_filename='../data/model-split.uff',
text=False,
When running this code, the graph generation and UFF conversion seems fine:
(3, 6)
2018-12-03 13:30:08.907213: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:924] ARM64 does not support NUMA - returning NUMA node zero
2018-12-03 13:30:08.907603: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.5
pciBusID: 0000:00:00.0
totalMemory: 15.46GiB freeMemory: 2.95GiB
2018-12-03 13:30:08.907758: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1511] Adding visible gpu devices: 0
2018-12-03 13:30:10.125579: I tensorflow/core/common_runtime/gpu/gpu_device.cc:982] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-12-03 13:30:10.125765: I tensorflow/core/common_runtime/gpu/gpu_device.cc:988] 0
2018-12-03 13:30:10.125864: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 0: N
2018-12-03 13:30:10.126235: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 2473 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
[array([[31., 23., 4., 24., 27., 34.]], dtype=float32), array([[18., 3., 25., 0., 6., 35.]], dtype=float32), array([[28., 14., 33., 22., 20., 8.]], dtype=float32)]
[<tf.Operation 'input' type=Placeholder>, <tf.Operation 'Const' type=Const>, <tf.Operation 'output/split_dim' type=Const>, <tf.Operation 'output' type=Split>]
=== Automatically deduced input nodes ===
[name: "input"
op: "Placeholder"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
Using output node output
Converting to UFF graph
Warning: No conversion function registered for layer: Split yet.
Converting as custom op Split output
op: "Split"
input: "output/split_dim"
input: "input"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "num_split"
value {
i: 3
No. nodes: 4
UFF Output written to ../data/model-split.uff
However when I parse this UFF file in a C++ TensorRT program, I cannot recover the num_split attribute of the expected output. It seems to be an integer according to the UFF generation:
op: "Split"
input: "input"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "num_split"
value {
i: 3
But when I try to parse the FieldCollection parameter in the plugin it returns an unknown format.
SplitLayer::SplitLayer(const FieldCollection fc, const Weights* weights, int nbWeights)
:mNumSplit(0) {
std::cout << "SplitLayer::SplitLayer - nbWeights=" << nbWeights << std::endl;
std::cout << "Fields:" << std::endl;
for (int i = 0; i < fc.nbFields; i++) {
std::cout << i << ": " << fc.fields[i].name << " (" << static_cast<int>(fc.fields[i].type)
<< ") " << fc.fields[i].length << std::endl;
UFFParser: parsing output/split_dim
UFFParser: parsing input
UFFParser: Parse Plugin node output
UFFParser: PluginNode Input Descriptor input
UFFParser: Operation of node Input
SplitLayer::SplitLayer - nbWeights=0
Fields:
0: num_split (6) 1
1: T (5) 1
SplitLayer::getNbOutputs
The num_split attribute is returned as a field with type FieldType::kUNKNOWN and length 1. Attribute T shows up properly.
I tried force-casting the data pointer into an int or a char to check if I could retrieve the expected value (3) but it does not work.
Can you double-check this specific use-case? It seems something wrong occurs during parsing. Thanks for your support.
