UFS Device Compatibility and IST Storage Requirements for IGX Thor T5000 Safety Flow
Hi NVIDIA Team,
We are designing custom carrier board with IGX Thor T5000 module. We would like to request a compatibility clarification regarding the UFS device planned for our custom carrier board design.
We are evaluating the following UFS device:
Vendor: Phison (P/N : PSUF31L29-G(128/256/512)US
Controller: PS8329
NAND: Kioxia BiCS8
UFS Version: UFS 3.1
Form Factor: M.2 2230
Capacity Options: 128 GB / 256 GB / 512 GB
Since UFS is used by the current safety flow for IST-related artifacts and runtime IST result data and the IGX Thor Developer Kit Mini uses a 256GB Micron UFS device, could you please clarify the actual storage requirement for IST data - Can smaller UFS capacities (like 128GB) be used when IST is enabled?
Also, Could you please advise:
1. Whether the above Phison UFS 3.1 device is expected to operate correctly with the IGX Thor UFS controller and current SEP/IST workflow.
2. Whether NVIDIA maintains a validated or recommended UFS device/vendor list for use with the IGX Thor safety flow.
3. Regarding the “Power management operations such as auto-hibernate” feature mentioned in Section 2.11.1 “Universal Flash Storage (UFS-III)” in datasheet.
Our understanding is that the UFS device supports auto-standby functionality, while HIBERN8 entry is initiated by the host-side UFS controller through standard hibernate commands.
Could you please confirm whether this understanding is correct?
Additionally, we would also like to understand the important parameters need to be considered while selecting a UFS device for storing IST-related artifacts and test results for safety system.
Kindly let me know if your any details.
Regards,
Manikandan
Hello @manikandan.b!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi manikandan.b,
Please follow up on NV ticket system, I have the update there, thanks.
