I extracted UI_Composer_Viewer-Vibrante21_X_DGPU.7.0.16512014.run and got a file UICViewer
but when i tried to run it as ./UICViewer it says -bash: ./UICViewer: No such file or directory
Please give me some idea to fix this. I have settled the permissions on the files also
You cannot execute 32-bit armhf on the JTX1 unless you’ve set up a 32-bit compatibility within user space. Meaning 32-bit linker and 32-bit libraries. Although ARMv8-a 64-bit has a 32-bit compatibility mode (ARMv8 without the “-a” can execute armhf) to work with armhf (and the kernel supports this), the user space changes to do this are extensive (and does not exist by default). 32-bit compatibility mode in user space is not something well-tested and I suspect it is a long and difficult road to get this working properly without bad side-effects (and no doubt performance would suffer).
What is the recommended tool flow then to run a UI Composer project on the TX1 ? Do you have an updated UI Composer Viewer or some other application ?
Our application is to run a Automotive instrument cluster. We used the sample and was able run and view in windows successfully. But what are the next steps in getting deployed on the TX1 ?
Typically whoever maintains the 32-bit version would start providing a 64-bit build for ARMv8-a (arm64/aarch64). Barring that, you’d get the source code and compile it yourself. Do you have a URL for source code?
Well the UI Composer Viewer is provided by Nvidia. I havent seen a link to the source code. Is there a place we can search for ? the downloads are available here
Looks like this would be a nice application for developers of “many things Jetson”. I don’t even see an x86_64 Linux desktop version though, just Windows, Mac, Android, and the 32-bit Vibrante. Considering the mobile “drive” (Vibrante) version is close to what many Jetsons are used for in development I could see the usefulness of such a port to the JTX1.
Anyone at nVidia know if there is a chance of getting a port of an arm64/aarch64 L4T version of UI Composer?
