Ultralytics messes up my system during execution
I am trying to run ultralytics yolo V5 on a xavier nx, but during execution it simply removes the installed torch and torchvision and replaces them with its versions which, unsurprisingly, do not work
There must be a way to prevent a system to download automatically packages, messing up the system
Using docker images are not a solution I am afraid
Have you run any commands related to install?
Or just start a python script?
The problem happens when I run a python program I created. It just imports the libraries, and when it is time to import ultralytics, it starts to replace the librariers I have
Sorry for the late update.
Have you checked this issue with the Ultralytics team?
So they can provide help directly?
I did and they told me to use venv, which apparently solved the problem. Old fashioned but effective
