@SteveNV
Hi SteveNV,
I can not flash successfully.
It shows information below:
flash log below:
11:28:45 INFO: *** Retrying to install. attempt number: 2
11:28:53 DEBUG: running command < true >
11:28:53 INFO: command finished successfully
11:28:53 DEBUG: running command < stat /dev/ttyUSB1 >
11:28:53 INFO: Device: 6h/6d Inode: 477 Links: 1 Device type: bc,1
11:28:53 DEBUG: running command < lsof /dev/ttyUSB1 2>/dev/null >
11:28:54 DEBUG: command terminated with error
11:28:54 DEBUG: running command < true >
11:28:54 INFO: command finished successfully
11:28:54 DEBUG: Flash Tegra A: using adapter to install NV_FLASH_TEGRA_A_COMP@PX2_AUTOCHAUFFEUR to /home/cts/nvidia/nvidia_sdk/DRIVE_OS_5.0.10.3_SDK_with_DriveWorks_Linux_OS_PX2_AUTOCHAUFFEUR
11:28:54 INFO: Flash Tegra A: Return success directly for empty component
11:28:54 INFO: Flash Tegra A: command finished successfully
11:28:54 INFO: All done!
but there is nothing new software or library in target actually.
could you please help me solve the issue.
thanks
