Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify):
GPU Information
Model: RTX 5080 & RTX 4090
Driver Version:
Hi All,
I’m trying to use some existing Isaac Sim assets but the application keeps complaining about not being able to find the necessary resources from the AWS endpoint.
The “Warning: Isaac Sim Assets not found” dialog means Isaac Sim’s internal networking layer
(omni.client) could not reach the default cloud asset server at startup:
This is a known issue when a firewall, corporate proxy, SSL inspection appliance, or network
policy blocks the OmniClient library’s connection to AWS S3 – even though the same URL opens
fine in a web browser. The browser and OmniClient use different network stacks and certificate
stores.
Quickest Fix: Download the Local Assets Pack
The officially supported solution for this is to download the assets locally and point Isaac Sim
at them. This works regardless of network restrictions.
Documentation:
If You Prefer to Fix the Network Connection
If you want to keep using cloud assets instead, check these first:
Test S3 reachability from the terminal (not the browser):
Hi @dsonmez, we wanted to follow up on the guidance provided above — downloading the local assets pack or adjusting your proxy/firewall settings should resolve the issue. Since we haven’t heard back, we’ll go ahead and close this thread. If you’re still experiencing the problem, please open a new topic and link back to this one so we can continue helping. Thank you!
