There are two USB-C connectors. Only one works. Make sure to either try both, or to use the one in the docs. Also, it won’t show up if it isn’t in recovery mode. For recovery mode use one of these:
- Hold the recovery button down, and then power up; you can let go of the button immediately (it is like the shift key on a keyboard and has no time requirement).
- Hold the recovery button down on a Jetson which is already powered, and then hit the reset button. Similar, there is no requirement to keep that button down for any length of time.
NVIDIA devices on a USB bus will show up with:
lsusb -d 0955:
