Unable to achive super-speed as current-speed with usb gadget
Hello Nvidia Team,
I am using AGX Orin NX with custom carrier board. I am trying attain super-speed on usb3.0 port.
The XUDC enumerates on the host PC and the gadget works, but the link always negotiates USB 2.0 High-Speed (480 Mbps) instead of USB 3.0 SuperSpeed (5 Gbps).
Logs:
$ cat /sys/kernel/config/usb_gadget/l4t/max_speed
super-speed
$ cat /sys/kernel/config/usb_gadget/l4t/UDC
3550000.usb
$ cat /sys/class/udc/3550000.usb/maximum_speed
super-speed
$ cat /sys/class/udc/3550000.usb/current_speed
high-speed
$ cat /sys/class/udc/3550000.usb/state
configured
So the controller reports SuperSpeed capability but the negotiated link stays at High-Speed.
We have verified with multiple known-good USB 3.x cables and USB 3 host ports. The issue persists.
Hardware design notes
  • Device port is routed to SoC lane pair usb2-1 (D+/D−) + usb3-0 (SuperSpeed TX/RX).
  • Host ports (usb2-0/usb3-1, usb2-2/usb3-2) remain enabled for keyboard and other USB peripherals via XHCI.
Device tree changes:
dts
usb2-0 {
    status = "okay";
    mode = "host";              /* was peripheral + usb-role-switch */
    vbus-supply = <&vdd_5v0_sys>;
usb2-1 {
    status = "okay";
    mode = "peripheral";        /* was host — our device port */
    vbus-supply = <&vdd_5v0_hdmi>;
usb3-0 {
    status = "okay";
    nvidia,usb2-companion = <1>;  /* SS companion of usb2-1 */
    maximum-speed = "super-speed";
usb3-1 {
    status = "okay";
    nvidia,usb2-companion = <0>;  /* SS companion of usb2-0 (host) */
XUDC — device controller (usb@3550000)
dts
usb@3550000 {
    compatible = "nvidia,tegra234-xudc";
    dr_mode = "peripheral";
    status = "okay";
    phys = <&{/bus@0/padctl@3520000/pads/usb2/lanes/usb2-1}>,
           <&{/bus@0/padctl@3520000/pads/usb3/lanes/usb3-0}>;
    phy-names = "usb2-0", "usb3-0";
sh
usb@3610000 {
    status = "okay";
    phys = <&.../lanes/usb2-0>,
           <&.../lanes/usb2-2>,
           <&.../lanes/usb3-1>,
           <&.../lanes/usb3-2>;
    phy-names = "usb2-0", "usb2-2", "usb3-1", "usb3-2";
    /* usb2-1 + usb3-0 intentionally excluded — reserved for XUDC */
Ouput logs after configuration:
sh
# On Jetson — bind gadget
echo "" | sudo tee /sys/kernel/config/usb_gadget/l4t/UDC
echo 3550000.usb | sudo tee /sys/kernel/config/usb_gadget/l4t/UDC
# Connect Type-A cable to host PC, then check speed
# high-speed (expected: super-speed)
sh
# Gadget already at max allowed speed
super-speed
Questions for NVIDIA
  1. Is SuperSpeed USB gadget (XUDC) mode officially supported on the `usb2-1` `usb3-0` ane pair, or is device mode restricted to a specific pair (e.g. default `usb2-0` `usb3-1`)
  2. For a custom Type-A device port on `usb2-1` `usb3-0`,is our `nvidia,usb2-companion = <1>` n `usb3-0` and XUDC `phys`/phy-names` configuration correct as per the tegra-xudc and tegra234-xusb-padctl bindings?
  3. What conditions cause `maximum_speed: super-speed` while `current_speed: high-speed`?Which driver layer (padctl PHY, XUDC PORTSC, host PC) should we debug first?
  4. Are any extra properties required for SuperSpeed gadget on a direct Type-A design (e.g. `avddio-usb-supply`,`vdd-usb-supply`,padctl port settings, or disabling specific xhci phys)?
  5. Are there known BSP or `tegra-xudc` limitations on Orin NX / AGX Orin for SuperSpeed gadget mode in recent L4T releases?
  6. What is NVIDIA’s recommended procedure to confirm whether the USB3 PHY (`usb3-0`)is powering on and SS training is attempted (e.g. dynamic debug for `tegra-xudc`,padctl register dumps, PORTSC decode)?
Guidance on whether our device tree and lane assignment are correct for SuperSpeed gadget on a custom Type-A port (`usb2-1` `usb3-0`) and what additional software or hardware checks NVIDIA recommends when 'maximum_speed` shows `super-speed` the link negotiates only 'high-speed`.
You can have USB3 with either usb3-x and usb2-x in pair. Please refer to adaptation guide to modify device tree per hardware design:
Jetson Orin NX and Nano Series — NVIDIA Jetson Linux Developer Guide
And please do compliance test to ensure signal quality is good:
Jetson Download Center | NVIDIA Developer
Because usb2-0 is obligatory for system flashing, would strongly suggest design it as an OTG port.
Hi @DaneLLL the issue is even after configuration i am not able to achieve super-speed which is achieved only when in host mode.
Please find some of the output logs:
  • Uphy configurations from bpmp:
       uphy {
                status = "okay";
                hsio-uphy-config = <0x00>;
                hsstp-lane-map = <0x03>;
                nvhs-uphy-config = <0x00>;
                gbe-uphy-config = <0x16>;
                gbe0-enable-10g;
sudo cat /sys/kernel/debug/bpmp/debug/uphy/config
0x03a40000
Output of lsusb -t
lsusb -t
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/16p, 480M
    |__ Port 002: Dev 102, If 0, Class=Communications, Driver=rndis_host, 480M
    |__ Port 002: Dev 102, If 1, Class=CDC Data, Driver=rndis_host, 480M
    |__ Port 002: Dev 102, If 2, Class=Communications, Driver=cdc_acm, 480M
    |__ Port 002: Dev 102, If 3, Class=CDC Data, Driver=cdc_acm, 480M
    |__ Port 002: Dev 102, If 4, Class=Mass Storage, Driver=usb-storage, 480M
    |__ Port 002: Dev 102, If 5, Class=Communications, Driver=cdc_ncm, 480M
    |__ Port 002: Dev 102, If 6, Class=CDC Data, Driver=cdc_ncm, 480M
    |__ Port 009: Dev 083, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 010: Dev 082, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 010: Dev 082, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/10p, 20000M/x2
  • Current speed detected:
high-speed
super-speed
  • Dmesg output:
[  420.739544] tegra-xudc 3550000.usb: ep 3 disabled
[  420.739581] tegra-xudc 3550000.usb: ep 2 disabled
[  420.739602] tegra-xudc 3550000.usb: ep 5 disabled
[  420.739622] tegra-xudc 3550000.usb: ep 4 disabled
[  420.739637] tegra-xudc 3550000.usb: ep 7 disabled
[  420.739655] tegra-xudc 3550000.usb: ep 9 disabled
[  420.739681] tegra-xudc 3550000.usb: ep 13 disabled
[  420.739711] tegra-xudc 3550000.usb: ep 8 disabled
[  420.739732] tegra-xudc 3550000.usb: ep 15 disabled
[  420.739752] tegra-xudc 3550000.usb: ep 11 disabled
[  420.739788] tegra-xudc 3550000.usb: ep 6 disabled
[  420.924476] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[  420.924504] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[  420.924519] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[  420.924596] tegra-xudc 3550000.usb: EP 9 (type: intr, dir: in) enabled
[  420.924612] tegra-xudc 3550000.usb: EP 7 (type: bulk, dir: in) enabled
[  420.924626] tegra-xudc 3550000.usb: EP 4 (type: bulk, dir: out) enabled
[  420.924656] tegra-xudc 3550000.usb: EP 15 (type: intr, dir: in) enabled
[  420.924676] tegra-xudc 3550000.usb: EP 11 (type: bulk, dir: in) enabled
[  420.924700] tegra-xudc 3550000.usb: EP 6 (type: bulk, dir: out) enabled
[  420.931463] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  420.931486] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  420.932844] tegra-xudc 3550000.usb: ep 13 disabled
[  420.932940] tegra-xudc 3550000.usb: ep 8 disabled
[  420.955093] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  420.955118] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
Have you performed compliance test to the USB port? Also please get full dmesg log. If it is enumerated to USB2, it should have high-speed print. From the prints you shared, it looks signal is not good, or VBUS supply is not stable or insufficient current.
Hi @DaneLLL , please find attached the dmesg logs. We successfully achieved the 5Gbps line speed in host mode. Because the port meets this speed requirement, we believe the underlying hardware is functioning correctly and is not the root cause of the issue.
dmesg.txt (64.3 KB)
This could be unrelated, but right after the USB shows up in the dmesg I see this
[   11.754453] qmi_wwan_q: Unknown symbol usbnet_change_mtu (err -2)
[   11.754498] qmi_wwan_q: Unknown symbol usbnet_open (err -2)
[   11.754516] qmi_wwan_q: Unknown symbol usbnet_skb_return (err -2)
[   11.754530] qmi_wwan_q: Unknown symbol usbnet_get_ethernet_addr (err -2)
[   11.754545] qmi_wwan_q: Unknown symbol usbnet_tx_timeout (err -2)
[   11.754569] qmi_wwan_q: Unknown symbol usbnet_suspend (err -2)
[   11.754581] qmi_wwan_q: Unknown symbol usbnet_start_xmit (err -2)
[   11.754604] qmi_wwan_q: Unknown symbol usbnet_get_endpoints (err -2)
[   11.754637] qmi_wwan_q: Unknown symbol usbnet_stop (err -2)
[   11.754657] qmi_wwan_q: Unknown symbol usbnet_disconnect (err -2)
[   11.754672] qmi_wwan_q: Unknown symbol usbnet_probe (err -2)
[   11.754684] qmi_wwan_q: Unknown symbol usbnet_resume (err -2)
This is apparently for a driver for Quectel cellular modem. All by itself this would not stop super-speed mode, but it has me wondering: The kernel itself was apparently rebuilt without the Quectel module or feature also being built/rebuilt. If the device tree or other drivers depend on this for super-speed, then it is conceivable that simply rebuilding the module to match the existing kernel would solve this.
Alternatively, if the device is used by the Quectel driver, then even if the device tree is otherwise correct the USB part of that driver would fail. Don’t know, and this is somewhat grasping at the fringe, but it is worth checking if that driver is needed for anything related to the USB super-speed.
Otherwise there is a good chance that signal quality is insufficient or the other device tree related changes are not doing what they should.
Thanks for the additional information about the qmi_wwan_q module issue. To help isolate whether this is related to the USB 3.0 SuperSpeed negotiation problem or a separate driver concern, we need the following diagnostic outputs:
  1. Dynamic debug output for tegra-xudc driver — This will trace the SuperSpeed training sequence and show exactly where the negotiation fails.
  2. Padctl PHY register dumps — We need to confirm that the usb3-0 lane is powering on and that SuperSpeed training is being initiated at the PHY layer.
  3. PORTSC register decode for the XUDC controller — This will help identify where the negotiation stalls at the controller level.
  4. USB 3.0 compliance test results — These will verify signal quality and rule out electrical issues on the link.
  5. Lane pair isolation test — Please test with the default usb2-0 + usb3-1 lane pair to determine if the issue is specific to your usb2-1 + usb3-0 configuration.
Once you provide these outputs, we can narrow down whether the root cause is in the PHY layer, the controller firmware, the device tree configuration, or the driver stack.
Hi @linuxdev , this module is being loaded by a custom init script and it has no relation with the usb super speed
Hi @DaneLLL , can you please check the dmesg logs and help in identifying the real issue
Hi @vrushti.dabhi,
Thanks for sharing the dmesg logs and confirming that the hardware achieves 5 Gbps in host mode. This is helpful—it rules out fundamental hardware defects and points to a driver, PHY layer, or lane-pair-specific configuration issue.
To isolate where the SuperSpeed negotiation is failing, we need the following diagnostic outputs:
  1. Dynamic debug output for tegra-xudc driver: Enable dynamic debug for the tegra-xudc driver to see the SuperSpeed training sequence and identify where negotiation stalls.
    echo 'module tegra_xudc +p' | sudo tee /sys/kernel/debug/dynamic_debug/control
    Then rebind the gadget and capture dmesg.
  2. Padctl PHY register dumps: Confirm that the usb3-0 lane is powering on and SuperSpeed training is initiated at the PHY layer.
    sudo cat /sys/kernel/debug/tegra_padctl_uphy/registers
  3. PORTSC register decode for XUDC controller: Identify where the controller-level negotiation stalls.
    sudo cat /sys/kernel/debug/tegra_xudc/portsc
  4. USB 3.0 compliance test results: Verify signal quality and rule out electrical issues (cable, connector, termination).
  5. Lane pair isolation test: Does the issue reproduce if you switch to the default usb2-0 + usb3-1 lane pair configuration? This will help determine if the problem is lane-pair-specific or configuration-specific.
  6. Kernel version and full module list: Please share the output of uname -a and lsmod to correlate with the qmi_wwan_q driver mismatch noted in post 9.
Once we have these outputs, we can pinpoint whether the issue is in device tree configuration, the tegra-xudc driver, the padctl PHY layer, or hardware signal quality.
Hi @DaneLLL / @carolyuu , is there any limitation from module side that one port can be configured as super speed ?
Thanks for the follow-up. To isolate whether the SuperSpeed negotiation issue is in the device tree configuration, tegra-xudc driver, padctl PHY layer, or hardware signal quality, we need the following diagnostic outputs:
1. Dynamic debug for tegra-xudc driver:
Enable dynamic debug and capture the SuperSpeed training sequence:
# Unbind and rebind the gadget
# Capture dmesg output
dmesg | tail -100
2. Padctl PHY register dumps for usb3-0 lane:
Confirm SuperSpeed training is initiated at the PHY layer:
Identify where the negotiation stalls at the controller level:
4. USB 3.0 compliance test:
Once you share these outputs, we can pinpoint the root cause and recommend the appropriate fix.
Hi @carolyuu
Here are the results:
  • Dynamic debug for tegra-xudc driver:
Logs:
root@tegra-ubuntu:/boot/dtb# echo 'module tegra_xudc +p' | sudo tee /sys/kernel/debug/dynamic_debug/control
dmesg | tail -100
3550000.usb
[  215.443148] l4tbr0: port 1(usb0) entered disabled state
[  215.443396] l4tbr0: port 2(usb1) entered disabled state
[  215.630221] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[  215.630252] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[  215.630269] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[  215.630380] tegra-xudc 3550000.usb: EP 9 (type: intr, dir: in) enabled
[  215.630397] tegra-xudc 3550000.usb: EP 7 (type: bulk, dir: in) enabled
[  215.630411] tegra-xudc 3550000.usb: EP 4 (type: bulk, dir: out) enabled
[  215.630564] tegra-xudc 3550000.usb: EP 15 (type: intr, dir: in) enabled
[  215.630584] tegra-xudc 3550000.usb: EP 11 (type: bulk, dir: in) enabled
[  215.630616] tegra-xudc 3550000.usb: EP 6 (type: bulk, dir: out) enabled
[  215.630703] l4tbr0: port 1(usb0) entered blocking state
[  215.630712] l4tbr0: port 1(usb0) entered forwarding state
[  215.638617] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  215.638641] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  215.638827] l4tbr0: port 2(usb1) entered blocking state
[  215.638836] l4tbr0: port 2(usb1) entered forwarding state
[  215.640330] tegra-xudc 3550000.usb: ep 13 disabled
[  215.640476] tegra-xudc 3550000.usb: ep 8 disabled
[  215.660829] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  215.660854] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  518.133051] tegra-xudc 3550000.usb: ep 3 disabled
[  518.133090] tegra-xudc 3550000.usb: ep 2 disabled
[  518.133109] tegra-xudc 3550000.usb: ep 5 disabled
[  518.133128] tegra-xudc 3550000.usb: ep 4 disabled
[  518.133141] tegra-xudc 3550000.usb: ep 7 disabled
[  518.133188] tegra-xudc 3550000.usb: ep 9 disabled
[  518.133212] tegra-xudc 3550000.usb: ep 13 disabled
[  518.133239] tegra-xudc 3550000.usb: ep 8 disabled
[  518.133256] tegra-xudc 3550000.usb: ep 15 disabled
[  518.133273] tegra-xudc 3550000.usb: ep 11 disabled
[  518.133310] tegra-xudc 3550000.usb: ep 6 disabled
[  518.133629] l4tbr0: port 1(usb0) entered disabled state
[  518.133935] l4tbr0: port 2(usb1) entered disabled state
[  518.319737] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[  518.319768] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[  518.319783] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[  518.319864] tegra-xudc 3550000.usb: EP 9 (type: intr, dir: in) enabled
[  518.319881] tegra-xudc 3550000.usb: EP 7 (type: bulk, dir: in) enabled
[  518.319895] tegra-xudc 3550000.usb: EP 4 (type: bulk, dir: out) enabled
[  518.319998] tegra-xudc 3550000.usb: EP 15 (type: intr, dir: in) enabled
[  518.320019] tegra-xudc 3550000.usb: EP 11 (type: bulk, dir: in) enabled
[  518.320045] tegra-xudc 3550000.usb: EP 6 (type: bulk, dir: out) enabled
[  518.320150] l4tbr0: port 1(usb0) entered blocking state
[  518.320160] l4tbr0: port 1(usb0) entered forwarding state
[  518.325900] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  518.325921] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  518.326080] l4tbr0: port 2(usb1) entered blocking state
[  518.326087] l4tbr0: port 2(usb1) entered forwarding state
[  518.327726] tegra-xudc 3550000.usb: ep 13 disabled
[  518.327845] tegra-xudc 3550000.usb: ep 8 disabled
[  518.348472] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  518.348494] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  739.300111] tegra-xudc 3550000.usb: ep 3 disabled
[  739.300193] tegra-xudc 3550000.usb: ep 2 disabled
[  739.300212] tegra-xudc 3550000.usb: ep 5 disabled
[  739.300294] tegra-xudc 3550000.usb: ep 4 disabled
[  739.300308] tegra-xudc 3550000.usb: ep 7 disabled
[  739.300353] tegra-xudc 3550000.usb: ep 9 disabled
[  739.300387] tegra-xudc 3550000.usb: ep 13 disabled
[  739.300454] tegra-xudc 3550000.usb: ep 11 disabled
[  739.300485] tegra-xudc 3550000.usb: ep 6 disabled
[  739.300533] tegra-xudc 3550000.usb: ep 8 disabled
[  739.300549] tegra-xudc 3550000.usb: ep 15 disabled
[  739.300860] l4tbr0: port 1(usb0) entered disabled state
[  739.301032] l4tbr0: port 2(usb1) entered disabled state
[  739.301150] tegra-xudc 3550000.usb: ep 0 disabled
[  739.319353] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[  751.111600] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[  751.111637] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[  751.111655] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[  751.111744] tegra-xudc 3550000.usb: EP 9 (type: intr, dir: in) enabled
[  751.111764] tegra-xudc 3550000.usb: EP 7 (type: bulk, dir: in) enabled
[  751.111782] tegra-xudc 3550000.usb: EP 4 (type: bulk, dir: out) enabled
[  751.111916] tegra-xudc 3550000.usb: EP 15 (type: intr, dir: in) enabled
[  751.112036] l4tbr0: port 1(usb0) entered blocking state
[  751.112045] l4tbr0: port 1(usb0) entered forwarding state
[  751.112357] tegra-xudc 3550000.usb: EP 11 (type: bulk, dir: in) enabled
[  751.112377] tegra-xudc 3550000.usb: EP 6 (type: bulk, dir: out) enabled
[  751.120496] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  751.120516] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  751.120696] l4tbr0: port 2(usb1) entered blocking state
[  751.120704] l4tbr0: port 2(usb1) entered forwarding state
[  751.121841] tegra-xudc 3550000.usb: ep 13 disabled
[  751.121955] tegra-xudc 3550000.usb: ep 8 disabled
[  751.142709] tegra-xudc 3550000.usb: EP 13 (type: bulk, dir: in) enabled
[  751.142731] tegra-xudc 3550000.usb: EP 8 (type: bulk, dir: out) enabled
[  751.503046] tegra-xudc 3550000.usb: ep 3 disabled
[  751.503137] tegra-xudc 3550000.usb: ep 2 disabled
[  751.503154] tegra-xudc 3550000.usb: ep 5 disabled
[  751.503244] tegra-xudc 3550000.usb: ep 4 disabled
[  751.503288] tegra-xudc 3550000.usb: ep 7 disabled
[  751.503330] tegra-xudc 3550000.usb: ep 9 disabled
[  751.503355] tegra-xudc 3550000.usb: ep 13 disabled
[  751.503430] tegra-xudc 3550000.usb: ep 11 disabled
[  751.503463] tegra-xudc 3550000.usb: ep 6 disabled
[  751.503515] tegra-xudc 3550000.usb: ep 8 disabled
[  751.503533] tegra-xudc 3550000.usb: ep 15 disabled
[  751.503676] tegra-xudc 3550000.usb: ep 0 disabled
[  751.520855] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
I was not able to get entries for “sudo cat /sys/kernel/debug/tegra_padctl_uphy/registers” and “sudo cat /sys/kernel/debug/tegra_xudc/portsc” as it shows error no such file or directory
Regarding lane pair isolation test , the issue persist
Not sure if it helps but you may try the patch:
Making sure you're not a bot!
[USB] USB port deadlock and could not detect plug/unplug event
Also please confirm you don’t run in isochronous endpoint:
USB Audio gadget on Jetson Orin devkit 64G - #16 by DaneLLL
If the issue persists, please try to reproduce it on developer kit(Orin NX module + Orin Nano carrier board) in Jetpack 6.2.2 r36.5 or 7.2 r39.2.
Hi @DaneLLL , the issue still persist, is this something related to USB3.0 A2A cable, also i am still confused on why superspeed is attained in host mode?
Please try to reproduce it on developer kit(Orin NX module + Orin Nano carrier board) in Jetpack 6.2.2 r36.5 or 7.2 r39.2. And share us the steps. So that we can check further.
I do not know what is specifically tested by that test, but do beware that files in “/sys”, such as those which are absent, exist only because they are an interface to a running driver. Their absence tends to say that the driver is not present. @DaneLLL I am curious which driver those files are associated with? Which specific hardware or hardware feature would be missing when those files are missing?
