Unable to add pgie_src_pad from deepstream-image-meta-test to deepstream-app
• Hardware Platform : Jetson TX2
• DeepStream Version : 5.1
• JetPack Version : 4.5.1
• TensorRT Version : 7.1.3
• Issue Type: I need to add image encoding code to deepstream app
• How to reproduce the issue ? To reproduce the issue go to deepstream-image-meta-test code and copy the image encoding code and paste it in the respective places in deepstream-app file
Initially I have tried the same image encoding code with deepstream-test2 app it worked correctly and no issues occured.
Now the same thing I have added the image encoding code in the deepstream-app file. But the pgie_src_pad unable to create it, so that the image cannot be cropped and stored
I have attached the code which I chnaged in deepstream-app
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include <sys/time.h>
#include <math.h>
#include <stdlib.h>
#include <cuda_runtime_api.h>
#include <glib/gbase64.h>
#include "deepstream_app.h"
#include "gstnvdsmeta.h"
#include "nvbufsurface.h"
#include "nvds_obj_encode.h"
#include "gst-nvmessage.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_FACE 0
static guint batch_num = 0;
static guint demux_batch_num = 0;
gint frame_number = 0;
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
GQuark _dsmeta_quark;
#define CEIL(a,b) ((a + b - 1) / b)
gchar pgie_classes_str[1][32] = { "face" };
#define save_img FALSE
#define attach_user_meta TRUE
 * @brief  Add the (nvmsgconv->nvmsgbroker) sink-bin to the
 *         overall DS pipeline (if any configured) and link the same to
 *         common_elements.tee (This tee connects
 *         the common analytics path to Tiler/display-sink and
 *         to configured broker sink if any)
 *         NOTE: This API shall return TRUE if there are no
 *         broker sinks to add to pipeline
 * @param  appCtx [IN]
 * @return TRUE if succussful; FALSE otherwise
static gboolean add_and_link_broker_sink (AppCtx * appCtx);
 * @brief  Checks if there are any [sink] groups
 *         configured for source_id=provided source_id
 *         NOTE: source_id key and this API is valid only when we
 *         disable [tiler] and thus use demuxer for individual
 *         stream out
 * @param  config [IN] The DS Pipeline configuration struct
 * @param  source_id [IN] Source ID for which a specific [sink]
 *         group is searched for
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id);
 * callback function to receive messages from components
 * in the pipeline.
static gboolean
bus_callback (GstBus * bus, GstMessage * message, gpointer data)
  AppCtx *appCtx = (AppCtx *) data;
  GST_CAT_DEBUG (NVDS_APP,
      "Received message on bus: source %s, msg_type %s",
      GST_MESSAGE_SRC_NAME (message), GST_MESSAGE_TYPE_NAME (message));
  switch (GST_MESSAGE_TYPE (message)) {
    case GST_MESSAGE_INFO:{
      GError *error = NULL;
      gchar *debuginfo = NULL;
      gst_message_parse_info (message, &error, &debuginfo);
      g_printerr ("INFO from %s: %s\n",
          GST_OBJECT_NAME (message->src), error->message);
      if (debuginfo) {
        g_printerr ("Debug info: %s\n", debuginfo);
      g_error_free (error);
      g_free (debuginfo);
      break;
    case GST_MESSAGE_WARNING:{
      gst_message_parse_warning (message, &error, &debuginfo);
      g_printerr ("WARNING from %s: %s\n",
      if (debuginfo) {
      g_free (debuginfo);
      break;
    case GST_MESSAGE_ERROR:{
      guint i = 0;
      gst_message_parse_error (message, &error, &debuginfo);
      g_printerr ("ERROR from %s: %s\n",
      if (debuginfo) {
      NvDsSrcParentBin *bin = &appCtx->pipeline.multi_src_bin;
      GstElement *msg_src_elem = (GstElement *) GST_MESSAGE_SRC (message);
      gboolean bin_found = FALSE;
      /* Find the source bin which generated the error. */
      while (msg_src_elem && !bin_found) {
        for (i = 0; i < bin->num_bins && !bin_found; i++) {
          if (bin->sub_bins[i].src_elem == msg_src_elem ||
                  bin->sub_bins[i].bin == msg_src_elem) {
            bin_found = TRUE;
            break;
        msg_src_elem = GST_ELEMENT_PARENT (msg_src_elem);
      if ((i != bin->num_bins) &&
          (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_RTSP)) {
        // Error from one of RTSP source.
        NvDsSrcBin *subBin = &bin->sub_bins[i];
        if (!subBin->reconfiguring ||
            g_strrstr(debuginfo, "500 (Internal Server Error)")) {
          subBin->reconfiguring = TRUE;
          g_timeout_add (0, reset_source_pipeline, subBin);
        g_free (debuginfo);
        return TRUE;
      if (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_CAMERA_V4L2) {
        if (g_strrstr(debuginfo, "reason not-negotiated (-4)")) {
          NVGSTDS_INFO_MSG_V ("incorrect camera parameters provided, please provide supported resolution and frame rate\n");
        if (g_strrstr(debuginfo, "Buffer pool activation failed")) {
          NVGSTDS_INFO_MSG_V ("usb bandwidth might be saturated\n");
      g_free (debuginfo);
      appCtx->return_value = -1;
      appCtx->quit = TRUE;
      break;
    case GST_MESSAGE_STATE_CHANGED:{
      GstState oldstate, newstate;
      gst_message_parse_state_changed (message, &oldstate, &newstate, NULL);
      if (GST_ELEMENT (GST_MESSAGE_SRC (message)) == appCtx->pipeline.pipeline) {
        switch (newstate) {
          case GST_STATE_PLAYING:
            NVGSTDS_INFO_MSG_V ("Pipeline running\n");
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->
                    pipeline.pipeline), GST_DEBUG_GRAPH_SHOW_ALL,
                "ds-app-playing");
            break;
          case GST_STATE_PAUSED:
            if (oldstate == GST_STATE_PLAYING) {
              NVGSTDS_INFO_MSG_V ("Pipeline paused\n");
            break;
          case GST_STATE_READY:
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.
                    pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-ready");
            if (oldstate == GST_STATE_NULL) {
              NVGSTDS_INFO_MSG_V ("Pipeline ready\n");
            } else {
              NVGSTDS_INFO_MSG_V ("Pipeline stopped\n");
            break;
          case GST_STATE_NULL:
            g_mutex_lock (&appCtx->app_lock);
            g_cond_broadcast (&appCtx->app_cond);
            g_mutex_unlock (&appCtx->app_lock);
            break;
          default:
            break;
      break;
    case GST_MESSAGE_EOS:{
       * In normal scenario, this would use g_main_loop_quit() to exit the
       * loop and release the resources. Since this application might be
       * running multiple pipelines through configuration files, it should wait
       * till all pipelines are done.
      NVGSTDS_INFO_MSG_V ("Received EOS. Exiting ...\n");
      return FALSE;
      break;
    default:
      break;
  return TRUE;
 * Function to dump bounding box data in kitti format. For this to work,
 * property "gie-kitti-output-dir" must be set in configuration file.
 * Data of different sources and frames is dumped in separate file.
static void
write_kitti_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  gchar bbox_file[1024] = { 0 };
  FILE *bbox_params_dump_file = NULL;
  if (!appCtx->config.bbox_dir_path)
    return;
  for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = l_frame->data;
    guint stream_id = frame_meta->pad_index;
    g_snprintf (bbox_file, sizeof (bbox_file) - 1,
        "%s/%02u_%03u_%06lu.txt", appCtx->config.bbox_dir_path,
        appCtx->index, stream_id, (gulong) frame_meta->frame_num);
    bbox_params_dump_file = fopen (bbox_file, "w");
    if (!bbox_params_dump_file)
      continue;
    for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
        l_obj = l_obj->next) {
      NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
      float left = obj->rect_params.left;
      float top = obj->rect_params.top;
      float right = left + obj->rect_params.width;
      float bottom = top + obj->rect_params.height;
      // Here confidence stores detection confidence, since dump gie output
      // is before tracker plugin
      float confidence = obj->confidence;
      fprintf (bbox_params_dump_file,
          "%s 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
          obj->obj_label, left, top, right, bottom, confidence);
    fclose (bbox_params_dump_file);
 * Function to dump past frame objs in kitti format.
static void
write_kitti_past_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  if (!appCtx->config.kitti_track_dir_path)
    return;
  // dump past frame tracked objects appending current frame objects
    NvDsPastFrameObjBatch *pPastFrameObjBatch = NULL;
    NvDsUserMetaList *bmeta_list = NULL;
    NvDsUserMeta *user_meta = NULL;
    for(bmeta_list=batch_meta->batch_user_meta_list; bmeta_list!=NULL; bmeta_list=bmeta_list->next){
      user_meta = (NvDsUserMeta *)bmeta_list->data;
      if(user_meta && user_meta->base_meta.meta_type==NVDS_TRACKER_PAST_FRAME_META){
        pPastFrameObjBatch = (NvDsPastFrameObjBatch *) (user_meta->user_meta_data);
        for (uint si=0; si < pPastFrameObjBatch->numFilled; si++){
          NvDsPastFrameObjStream *objStream = (pPastFrameObjBatch->list) + si;
          guint stream_id = (guint)(objStream->streamID);
          for (uint li=0; li<objStream->numFilled; li++){
            NvDsPastFrameObjList *objList = (objStream->list) + li;
            for (uint oi=0; oi<objList->numObj; oi++) {
              NvDsPastFrameObj *obj = (objList->list) + oi;
                "%s/%02u_%03u_%06lu.txt", appCtx->config.kitti_track_dir_path,
                appCtx->index, stream_id, (gulong) obj->frameNum);
              float left = obj->tBbox.left;
              float right = left + obj->tBbox.width;
              float top = obj->tBbox.top;
              float bottom = top + obj->tBbox.height;
              // Past frame object confidence given by tracker
              bbox_params_dump_file = fopen (bbox_file, "a");
              if (!bbox_params_dump_file){
                continue;
              fprintf(bbox_params_dump_file,
                "%s %lu 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
                objList->objLabel, objList->uniqueId, left, top, right, bottom, confidence);
 * Function to dump bounding box data in kitti format with tracking ID added.
 * For this to work, property "kitti-track-output-dir" must be set in configuration file.
static void
write_kitti_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
    return;
      continue;
      float left = obj->tracker_bbox_info.org_bbox_coords.left;
      float top = obj->tracker_bbox_info.org_bbox_coords.top;
      float right = left + obj->tracker_bbox_info.org_bbox_coords.width;
      float bottom = top + obj->tracker_bbox_info.org_bbox_coords.height;
      // Here confidence stores tracker confidence value for tracker output
      float confidence = obj->tracker_confidence;
      guint64 id = obj->object_id;
          obj->obj_label, id, left, top, right, bottom, confidence);
static gint
component_id_compare_func (gconstpointer a, gconstpointer b)
  NvDsClassifierMeta *cmetaa = (NvDsClassifierMeta *) a;
  NvDsClassifierMeta *cmetab = (NvDsClassifierMeta *) b;
  if (cmetaa->unique_component_id < cmetab->unique_component_id)
    return -1;
  if (cmetaa->unique_component_id > cmetab->unique_component_id)
    return 1;
  return 0;
 * Function to process the attached metadata. This is just for demonstration
 * and can be removed if not required.
 * Here it demonstrates to use bounding boxes of different color and size for
 * different type / class of objects.
 * It also demonstrates how to join the different labels(PGIE + SGIEs)
 * of an object to form a single string.
static void
process_meta (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  // For single source always display text either with demuxer or with tiler
  if (!appCtx->config.tiled_display_config.enable ||
      appCtx->config.num_source_sub_bins == 1) {
    appCtx->show_bbox_text = 1;
      gint class_index = obj->class_id;
      NvDsGieConfig *gie_config = NULL;
      gchar *str_ins_pos = NULL;
      if (obj->unique_component_id ==
          (gint) appCtx->config.primary_gie_config.unique_id) {
        gie_config = &appCtx->config.primary_gie_config;
      } else {
        for (gint i = 0; i < (gint) appCtx->config.num_secondary_gie_sub_bins;
            i++) {
          gie_config = &appCtx->config.secondary_gie_sub_bin_config[i];
          if (obj->unique_component_id == (gint) gie_config->unique_id) {
            break;
          gie_config = NULL;
      g_free (obj->text_params.display_text);
      obj->text_params.display_text = NULL;
      if (gie_config != NULL) {
        if (g_hash_table_contains (gie_config->bbox_border_color_table,
                class_index + (gchar *) NULL)) {
          obj->rect_params.border_color =
              *((NvOSD_ColorParams *)
              g_hash_table_lookup (gie_config->bbox_border_color_table,
                  class_index + (gchar *) NULL));
        } else {
          obj->rect_params.border_color = gie_config->bbox_border_color;
        obj->rect_params.border_width = appCtx->config.osd_config.border_width;
        if (g_hash_table_contains (gie_config->bbox_bg_color_table,
          obj->rect_params.has_bg_color = 1;
          obj->rect_params.bg_color =
              g_hash_table_lookup (gie_config->bbox_bg_color_table,
        } else {
          obj->rect_params.has_bg_color = 0;
      if (!appCtx->show_bbox_text)
        continue;
      obj->text_params.x_offset = obj->rect_params.left;
      obj->text_params.y_offset = obj->rect_params.top - 30;
      obj->text_params.font_params.font_color =
          appCtx->config.osd_config.text_color;
      obj->text_params.font_params.font_size =
          appCtx->config.osd_config.text_size;
      obj->text_params.font_params.font_name = appCtx->config.osd_config.font;
      if (appCtx->config.osd_config.text_has_bg) {
        obj->text_params.set_bg_clr = 1;
        obj->text_params.text_bg_clr = appCtx->config.osd_config.text_bg_color;
      obj->text_params.display_text = g_malloc (128);
      obj->text_params.display_text[0] = '\0';
      str_ins_pos = obj->text_params.display_text;
      if (obj->obj_label[0] != '\0')
        sprintf (str_ins_pos, "%s", obj->obj_label);
      str_ins_pos += strlen (str_ins_pos);
      if (obj->object_id != UNTRACKED_OBJECT_ID) {
        /** object_id is a 64-bit sequential value;
         * but considering the display aesthetic,
         * trimming to lower 32-bits */
        if (appCtx->config.tracker_config.display_tracking_id) {
          guint64 const LOW_32_MASK = 0x00000000FFFFFFFF;
          sprintf (str_ins_pos, " %lu", (obj->object_id & LOW_32_MASK));
      obj->classifier_meta_list =
          g_list_sort (obj->classifier_meta_list, component_id_compare_func);
      for (NvDsMetaList * l_class = obj->classifier_meta_list; l_class != NULL;
          l_class = l_class->next) {
        NvDsClassifierMeta *cmeta = (NvDsClassifierMeta *) l_class->data;
        for (NvDsMetaList * l_label = cmeta->label_info_list; l_label != NULL;
            l_label = l_label->next) {
          NvDsLabelInfo *label = (NvDsLabelInfo *) l_label->data;
          if (label->pResult_label) {
            sprintf (str_ins_pos, " %s", label->pResult_label);
          } else if (label->result_label[0] != '\0') {
            sprintf (str_ins_pos, " %s", label->result_label);
 * Function which processes the inferred buffer and its metadata.
 * It also gives opportunity to attach application specific
 * metadata (e.g. clock, analytics output etc.).
static void
process_buffer (GstBuffer * buf, AppCtx * appCtx, guint index)
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  if (!batch_meta) {
    NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
    return;
  process_meta (appCtx, batch_meta);
  //NvDsInstanceData *data = &appCtx->instance_data[index];
  //guint i;
  //  data->frame_num++;
  /* Opportunity to modify the processed metadata or do analytics based on
   * type of object e.g. maintaining count of particular type of car.
  if (appCtx->all_bbox_generated_cb) {
    appCtx->all_bbox_generated_cb (appCtx, buf, batch_meta, index);
  //data->bbox_list_size = 0;
   * callback to attach application specific additional metadata.
  if (appCtx->overlay_graphics_cb) {
    appCtx->overlay_graphics_cb (appCtx, buf, batch_meta, index);
 * Buffer probe function to get the results of primary infer.
 * Here it demonstrates the use by dumping bounding box coordinates in
 * kitti format.
static GstPadProbeReturn
gie_primary_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  AppCtx *appCtx = (AppCtx *) u_data;
  if (!batch_meta) {
    return GST_PAD_PROBE_OK;
  write_kitti_output (appCtx, batch_meta);
 * Probe function to get results after all inferences(Primary + Secondary)
 * are done. This will be just before OSD or sink (in case OSD is disabled).
gie_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
  guint index = bin->index;
  AppCtx *appCtx = bin->appCtx;
  if (gst_buffer_is_writable (buf))
    process_buffer (buf, appCtx, index);
 * Buffer probe function after tracker.
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  guint face_count = 0;
  guint id;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsDisplayMeta *display_meta = NULL;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
 for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    int offset = 0;
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
      obj_meta = (NvDsObjectMeta *) (l_obj->data);
      if (obj_meta->class_id == PGIE_CLASS_ID_FACE) {
        face_count++;
        num_rects++;
      // if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
      //   person_count++;
      //   num_rects++;
      /* To verify  encoded metadata of cropped objects, we iterate through the
       * user metadata of each object and if a metadata of the type
       * 'NVDS_CROP_IMAGE_META' is found then we write that to a file as
       * implemented below.
      char fileNameString[FILE_NAME_SIZE];
      const char *osd_string = "OSD";
      int obj_res_width = (int) obj_meta->rect_params.width;
      int obj_res_height = (int) obj_meta->rect_params.height;
      if(prop.integrated) {
        obj_res_width = GST_ROUND_DOWN_2(obj_res_width);
        obj_res_height = GST_ROUND_DOWN_2(obj_res_height);
      snprintf (fileNameString, FILE_NAME_SIZE, "%s_%d_%d_%d_%s_%dx%d.jpg",
          osd_string, frame_number, frame_meta->source_id, num_rects,
          obj_meta->obj_label, obj_res_width, obj_res_height);
      /* For Demonstration Purposes we are writing metadata to jpeg images of
       * only vehicles for the first 100 frames only.
       * The files generated have a 'OSD' prefix. */
        NvDsUserMetaList *usrMetaList = obj_meta->obj_user_meta_list;
        FILE *file;
        while (usrMetaList != NULL) {
          NvDsUserMeta *usrMetaData = (NvDsUserMeta *) usrMetaList->data;
          if (usrMetaData->base_meta.meta_type == NVDS_CROP_IMAGE_META) {
            NvDsObjEncOutParams *enc_jpeg_image =
                (NvDsObjEncOutParams *) usrMetaData->user_meta_data;
            /* Write to File */
            file = fopen (fileNameString, "wb");
            // printf("enc_jpeg_image:%d", enc_jpeg_image->outBuffer);
            fwrite (enc_jpeg_image->outBuffer, sizeof (uint8_t),
                enc_jpeg_image->outLen, file);
            fclose (file);
            usrMetaList = NULL;
          } else {
            usrMetaList = usrMetaList->next;
    display_meta = nvds_acquire_display_meta_from_pool (batch_meta);
    NvOSD_TextParams *txt_params = &display_meta->text_params[0];
    txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
    // offset =
    //     snprintf (txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ",
    //     person_count);
    offset =
        snprintf (txt_params->display_text + offset, MAX_DISPLAY_LEN,
        "Face = %d ", face_count);
    /* Now set the offsets where the string should appear */
    txt_params->x_offset = 10;
    txt_params->y_offset = 12;
    /* Font , font-color and font-size */
    txt_params->font_params.font_name = "Serif";
    txt_params->font_params.font_size = 10;
    txt_params->font_params.font_color.red = 1.0;
    txt_params->font_params.font_color.green = 1.0;
    txt_params->font_params.font_color.blue = 1.0;
    txt_params->font_params.font_color.alpha = 1.0;
    /* Text background color */
    txt_params->set_bg_clr = 1;
    txt_params->text_bg_clr.red = 0.0;
    txt_params->text_bg_clr.green = 0.0;
    txt_params->text_bg_clr.blue = 0.0;
    txt_params->text_bg_clr.alpha = 1.0;
    nvds_add_display_meta_to_frame (frame_meta, display_meta);
  frame_number++;
  g_print ("Frame Number = %d Number of objects = %d "
      "Face Count = %d\n",
      frame_number, num_rects, face_count);
  if (!batch_meta) {
   * Output KITTI labels with tracking ID if configured to do so.
  write_kitti_track_output(appCtx, batch_meta);
  if (appCtx->config.tracker_config.enable_past_frame)
      write_kitti_past_track_output (appCtx, batch_meta);
  if (appCtx->bbox_generated_post_analytics_cb)
    appCtx->bbox_generated_post_analytics_cb (appCtx, buf, batch_meta, index);
/* pgie_src_pad_buffer_probe will extract metadata received on pgie src pad
 * and update params for drawing rectangle, object information etc. We also
 * iterate through the object list and encode the cropped objects as jpeg
 * images and attach it as user meta to the respective objects.*/
pgie_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer ctx)
  GstMapInfo inmap = GST_MAP_INFO_INIT;
  if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
    GST_ERROR ("input buffer mapinfo failed");
    return GST_FLOW_ERROR;
  NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
  gst_buffer_unmap (buf, &inmap);
        face_count++;
        num_rects++;
      //   person_count++;
      //   num_rects++;
      /* Conditions that user needs to set to encode the detected objects of
       * interest. Here, by default all the detected objects are encoded.
       * For demonstration, we will encode the first object in the frame */
      if ((obj_meta->class_id == PGIE_CLASS_ID_FACE)
          && num_rects == 1) {
        NvDsObjEncUsrArgs userData = { 0 };
        /* To be set by user */
        userData.saveImg = save_img;
        userData.attachUsrMeta = attach_user_meta;
        /* Set if Image scaling Required */
        userData.scaleImg = FALSE;
        userData.scaledWidth = 0;
        userData.scaledHeight = 0;
        /* Preset */
        userData.objNum = num_rects;
        /*Main Function Call */
        nvds_obj_enc_process (ctx, &userData, ip_surf, obj_meta, frame_meta);
  nvds_obj_enc_finish (ctx);
latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  guint i = 0, num_sources_in_batch = 0;
  if(nvds_enable_latency_measurement)
    NvDsFrameLatencyInfo *latency_info = NULL;
    g_mutex_lock (&appCtx->latency_lock);
    latency_info = appCtx->latency_info;
    g_print("\n************BATCH-NUM = %d**************\n",batch_num);
    num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
    for(i = 0; i < num_sources_in_batch; i++)
      g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
          latency_info[i].source_id,
          latency_info[i].frame_num,
          latency_info[i].latency);
    g_mutex_unlock (&appCtx->latency_lock);
    batch_num++;
demux_latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
    g_print("\n************DEMUX BATCH-NUM = %d**************\n",demux_batch_num);
    demux_batch_num++;
static gboolean
  NvDsConfig *config = &appCtx->config;
  /** Only first instance_bin broker sink
   * employed as there's only one analytics path for N sources
   * NOTE: There shall be only one [sink] group
   * with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * a) Multiple of them does not make sense as we have only
   * one analytics pipe generating the data for broker sink
   * b) If Multiple broker sinks are configured by the user
   * in config file, only the first in the order of
   * appearance will be considered
   * and others shall be ignored
   * c) Ideally it should be documented (or obvious) that:
   * multiple [sink] groups with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * is invalid
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[0];
  NvDsPipeline *pipeline = &appCtx->pipeline;
  for (guint i = 0; i < config->num_sink_sub_bins; i++) {
    if(config->sink_bin_sub_bin_config[i].type == NV_DS_SINK_MSG_CONV_BROKER)
      if(!pipeline->common_elements.tee) {
         NVGSTDS_ERR_MSG_V ("%s failed; broker added without analytics; check config file\n", __func__);
         return FALSE;
      /** add the broker sink bin to pipeline */
      if(!gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
      /** link the broker sink bin to the common_elements tee
       * (The tee after nvinfer -> tracker (optional) -> sgies (optional) block) */
      if (!link_element_to_tee_src_pad (pipeline->common_elements.tee, instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
  return TRUE;
static gboolean
create_demux_pipeline (AppCtx * appCtx, guint index)
  gboolean ret = FALSE;
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.demux_instance_bins[index];
  GstElement *last_elem;
  gchar elem_name[32];
  instance_bin->index = index;
  instance_bin->appCtx = appCtx;
  g_snprintf (elem_name, 32, "processing_demux_bin_%d", index);
  instance_bin->bin = gst_bin_new (elem_name);
  if (!create_demux_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->demux_sink_bin,
        config->sink_bin_sub_bin_config[index].source_id)) {
    goto done;
  gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->demux_sink_bin.bin);
  last_elem = instance_bin->demux_sink_bin.bin;
  if (config->osd_config.enable) {
    if (!create_osd_bin (&config->osd_config, &instance_bin->osd_bin)) {
      goto done;
    gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->osd_bin.bin);
    NVGSTDS_LINK_ELEMENT (instance_bin->osd_bin.bin, last_elem);
    last_elem = instance_bin->osd_bin.bin;
  NVGSTDS_BIN_ADD_GHOST_PAD (instance_bin->bin, last_elem, "sink");
    NVGSTDS_ELEM_ADD_PROBE (instance_bin->all_bbox_buffer_probe_id,
        instance_bin->osd_bin.nvosd, "sink",
        gie_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER, instance_bin);
  } else {
        instance_bin->demux_sink_bin.bin, "sink",
  ret = TRUE;
done:
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
 * Function to add components to pipeline which are dependent on number
 * of streams. These components work on single buffer. If tiling is being
 * used then single instance will be created otherwise < N > such instances
 * will be created for < N > streams
static gboolean
create_processing_instance (AppCtx * appCtx, guint index)
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[index];
  g_snprintf (elem_name, 32, "processing_bin_%d", index);
  if (!create_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->sink_bin, index)) {
    goto done;
  gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->sink_bin.bin);
  last_elem = instance_bin->sink_bin.bin;
      goto done;
  } else {
        instance_bin->sink_bin.bin, "sink",
  ret = TRUE;
done:
  if (!ret) {
  return ret;
 * Function to create common elements(Primary infer, tracker, secondary infer)
 * of the pipeline. These components operate on muxed data from all the
 * streams. So they are independent of number of streams in the pipeline.
static gboolean
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
    GstElement ** sink_elem, GstElement ** src_elem,
    bbox_generated_callback bbox_generated_post_analytics_cb)
  *sink_elem = *src_elem = NULL;
  if (config->primary_gie_config.enable) {
    if (config->num_secondary_gie_sub_bins > 0) {
      if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
              config->primary_gie_config.unique_id,
              config->secondary_gie_sub_bin_config,
              &pipeline->common_elements.secondary_gie_bin)) {
        goto done;
          pipeline->common_elements.secondary_gie_bin.bin);
      if (!*src_elem) {
        *src_elem = pipeline->common_elements.secondary_gie_bin.bin;
      if (*sink_elem) {
        NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
            *sink_elem);
      *sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
  if (config->dsanalytics_config.enable) {
    // Create dsanalytics element bin and set properties
    if (!create_dsanalytics_bin (&config->dsanalytics_config,
            &pipeline->common_elements.dsanalytics_bin)) {
      g_print ("creating dsanalytics bin failed\n");
      goto done;
    // Add dsanalytics bin to instance bin
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->common_elements.dsanalytics_bin.bin);
      if (!*src_elem) {
        *src_elem = pipeline->common_elements.dsanalytics_bin.bin;
      if (*sink_elem) {
        NVGSTDS_LINK_ELEMENT (pipeline->common_elements.dsanalytics_bin.bin,
            *sink_elem);
    // Set this bin as the last element
    *sink_elem = pipeline->common_elements.dsanalytics_bin.bin;
  if (config->tracker_config.enable) {
    if (!create_tracking_bin (&config->tracker_config,
            &pipeline->common_elements.tracker_bin)) {
      g_print ("creating tracker bin failed\n");
      goto done;
        pipeline->common_elements.tracker_bin.bin);
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.tracker_bin.bin;
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.tracker_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.tracker_bin.bin;
    if (!create_primary_gie_bin (&config->primary_gie_config,
            &pipeline->common_elements.primary_gie_bin)) {
      goto done;
        pipeline->common_elements.primary_gie_bin.bin);
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.primary_gie_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.primary_gie_bin.bin;
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.primary_gie_bin.bin;
    NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.
        primary_bbox_buffer_probe_id,
        pipeline->common_elements.primary_gie_bin.bin, "src",
        gie_primary_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
        pipeline->common_elements.appCtx);
  if(*src_elem) {
          *src_elem, "src",
          analytics_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
          &pipeline->common_elements);
    /* Add common message converter */
    if (config->msg_conv_config.enable) {
      NvDsSinkMsgConvBrokerConfig *convConfig = &config->msg_conv_config;
      pipeline->common_elements.msg_conv = gst_element_factory_make (NVDS_ELEM_MSG_CONV, "common_msg_conv");
      if (!pipeline->common_elements.msg_conv) {
        NVGSTDS_ERR_MSG_V ("Failed to create element 'common_msg_conv'");
        goto done;
      g_object_set (G_OBJECT (pipeline->common_elements.msg_conv),
                    "config", convConfig->config_file_path,
                    "msg2p-lib", (convConfig->conv_msg2p_lib ? convConfig->conv_msg2p_lib : "null"),
                    "payload-type", convConfig->conv_payload_type,
                    "comp-id", convConfig->conv_comp_id,
                    "debug-payload-dir", convConfig->debug_payload_dir,
                    "multiple-payloads", convConfig->multiple_payloads, NULL);
                   pipeline->common_elements.msg_conv);
      NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.msg_conv);
      *src_elem = pipeline->common_elements.msg_conv;
    pipeline->common_elements.tee = gst_element_factory_make (NVDS_ELEM_TEE, "common_analytics_tee");
    if (!pipeline->common_elements.tee) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'common_analytics_tee'");
      goto done;
          pipeline->common_elements.tee);
    NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.tee);
    *src_elem = pipeline->common_elements.tee;
  ret = TRUE;
done:
  return ret;
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id) {
  for (guint j = 0; j < config->num_sink_sub_bins; j++) {
    if (config->sink_bin_sub_bin_config[j].enable &&
        config->sink_bin_sub_bin_config[j].source_id == source_id &&
        config->sink_bin_sub_bin_config[j].link_to_demux == FALSE) {
      return TRUE;
  return FALSE;
 * Main function to create the pipeline.
gboolean
create_pipeline (AppCtx * appCtx,
    bbox_generated_callback bbox_generated_post_analytics_cb,
    bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb,
    overlay_graphics_callback overlay_graphics_cb)
  GstBus *bus;
  GstElement *tmp_elem1;
  GstElement *tmp_elem2;
  guint i;
  GstPad *fps_pad;
  gulong latency_probe_id;
  GstElement *pgie = NULL;
  GstPad *pgie_src_pad = NULL;
  _dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
  appCtx->all_bbox_generated_cb = all_bbox_generated_cb;
  appCtx->bbox_generated_post_analytics_cb = bbox_generated_post_analytics_cb;
  appCtx->overlay_graphics_cb = overlay_graphics_cb;
  if (config->osd_config.num_out_buffers < 8) {
    config->osd_config.num_out_buffers = 8;
  pipeline->pipeline = gst_pipeline_new ("pipeline");
  if (!pipeline->pipeline) {
    NVGSTDS_ERR_MSG_V ("Failed to create pipeline");
    goto done;
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline->pipeline));
  pipeline->bus_id = gst_bus_add_watch (bus, bus_callback, appCtx);
  gst_object_unref (bus);
  if (config->file_loop) {
    /* Let each source bin know it needs to loop. */
    guint i;
    for (i = 0; i < config->num_source_sub_bins; i++)
        config->multi_source_config[i].loop = TRUE;
    NvDsSinkSubBinConfig *sink_config = &config->sink_bin_sub_bin_config[i];
    switch (sink_config->type) {
      case NV_DS_SINK_FAKE:
      case NV_DS_SINK_RENDER_EGL:
      case NV_DS_SINK_RENDER_OVERLAY:
        /* Set the "qos" property of sink, if not explicitly specified in the
           config. */
        if (!sink_config->render_config.qos_value_specified) {
          sink_config->render_config.qos = FALSE;
      default:
        break;
   * Add muxer and < N > source components to the pipeline based
   * on the settings in configuration file.
  if (!create_multi_source_bin (config->num_source_sub_bins,
          config->multi_source_config, &pipeline->multi_src_bin))
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
  if (config->streammux_config.is_parsed){
    if(!set_streammux_properties (&config->streammux_config,
        pipeline->multi_src_bin.streammux)){
         NVGSTDS_WARN_MSG_V("Failed to set streammux properties");
  if(appCtx->latency_info == NULL)
    appCtx->latency_info = (NvDsFrameLatencyInfo *)
      calloc(1, config->streammux_config.batch_size *
          sizeof(NvDsFrameLatencyInfo));
  /** a tee after the tiler which shall be connected to sink(s) */
  pipeline->tiler_tee = gst_element_factory_make (NVDS_ELEM_TEE, "tiler_tee");
  if (!pipeline->tiler_tee) {
    NVGSTDS_ERR_MSG_V ("Failed to create element 'tiler_tee'");
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiler_tee);
  /** Tiler + Demux in Parallel Use-Case */
  if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_ENABLE_WITH_PARALLEL_DEMUX)
    pipeline->demuxer =
        gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, "demuxer");
    if (!pipeline->demuxer) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'demuxer'");
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->demuxer);
    /** NOTE:
     * demux output is supported for only one source
     * If multiple [sink] groups are configured with
     * link_to_demux=1, only the first [sink]
     * shall be constructed for all occurences of
     * [sink] groups with link_to_demux=1
      gchar pad_name[16];
      GstPad *demux_src_pad;
      i = 0;
      if (!create_demux_pipeline (appCtx, i)) {
        goto done;
      for (i=0; i < config->num_sink_sub_bins; i++)
        if (config->sink_bin_sub_bin_config[i].link_to_demux == TRUE)
          g_snprintf (pad_name, 16, "src_%02d", config->sink_bin_sub_bin_config[i].source_id);
          break;
      if (i >= config->num_sink_sub_bins)
        g_print ("\n\nError : sink for demux (use link-to-demux-only property) is not provided in the config file\n\n");
        goto done;
      i = 0;
          pipeline->demux_instance_bins[i].bin);
      demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
      NVGSTDS_LINK_ELEMENT_FULL (pipeline->demuxer, pad_name,
          pipeline->demux_instance_bins[i].bin, "sink");
      gst_object_unref (demux_src_pad);
      NVGSTDS_ELEM_ADD_PROBE(latency_probe_id,
          appCtx->pipeline.demux_instance_bins[i].demux_sink_bin.bin,
          "sink",
          demux_latency_measurement_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
          appCtx);
      latency_probe_id = latency_probe_id;
    last_elem = pipeline->demuxer;
    link_element_to_tee_src_pad (pipeline->tiler_tee, last_elem);
    last_elem = pipeline->tiler_tee;
  if (config->tiled_display_config.enable) {
    /* Tiler will generate a single composited buffer for all sources. So need
     * to create only one processing instance. */
    if (!create_processing_instance (appCtx, 0)) {
      goto done;
    // create and add tiling component to pipeline.
    if (config->tiled_display_config.columns *
        config->tiled_display_config.rows < config->num_source_sub_bins) {
      if (config->tiled_display_config.columns == 0) {
            (guint) (sqrt (config->num_source_sub_bins) + 0.5);
      config->tiled_display_config.rows =
          (guint) ceil (1.0 * config->num_source_sub_bins /
          config->tiled_display_config.columns);
      NVGSTDS_WARN_MSG_V
          ("Num of Tiles less than number of sources, readjusting to "
          "%u rows, %u columns", config->tiled_display_config.rows,
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->instance_bins[0].bin);
    last_elem = pipeline->instance_bins[0].bin;
    if (!create_tiled_display_bin (&config->tiled_display_config,
            &pipeline->tiled_display_bin)) {
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
    NVGSTDS_LINK_ELEMENT (pipeline->tiled_display_bin.bin, last_elem);
    last_elem = pipeline->tiled_display_bin.bin;
    link_element_to_tee_src_pad (pipeline->tiler_tee, pipeline->tiled_display_bin.bin);
    NVGSTDS_ELEM_ADD_PROBE (latency_probe_id,
      pipeline->instance_bins->sink_bin.sub_bins[0].sink, "sink",
      appCtx);
  else
     * Create demuxer only if tiled display is disabled.
    pipeline->demuxer =
      goto done;
      gchar pad_name[16];
      /* Check if any sink has been configured to render/encode output for
       * source index `i`. The processing instance for that source will be
       * created only if atleast one sink has been configured as such.
      if (!is_sink_available_for_source_id(config, i))
        continue;
      if (!create_processing_instance(appCtx, i))
        goto done;
      gst_bin_add(GST_BIN(pipeline->pipeline),
                  pipeline->instance_bins[i].bin);
      g_snprintf(pad_name, 16, "src_%02d", i);
      demux_src_pad = gst_element_get_request_pad(pipeline->demuxer, pad_name);
      NVGSTDS_LINK_ELEMENT_FULL(pipeline->demuxer, pad_name,
                                pipeline->instance_bins[i].bin, "sink");
      gst_object_unref(demux_src_pad);
      for (int k = 0; k < MAX_SINK_BINS;k++) {
        if(pipeline->instance_bins[i].sink_bin.sub_bins[k].sink){
              pipeline->instance_bins[i].sink_bin.sub_bins[k].sink, "sink",
              appCtx);
          break;
  if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_DISABLE) {
    fps_pad = gst_element_get_static_pad (pipeline->demuxer, "sink");
  else {
    fps_pad = gst_element_get_static_pad (pipeline->tiled_display_bin.bin, "sink");
  pipeline->common_elements.appCtx = appCtx;
  // Decide where in the pipeline the element should be added and add only if
  // enabled
  if (config->dsexample_config.enable) {
    // Create dsexample element bin and set properties
    if (!create_dsexample_bin (&config->dsexample_config,
            &pipeline->dsexample_bin)) {
      goto done;
    // Add dsexample bin to instance bin
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->dsexample_bin.bin);
    // Link this bin to the last element in the bin
    NVGSTDS_LINK_ELEMENT (pipeline->dsexample_bin.bin, last_elem);
    last_elem = pipeline->dsexample_bin.bin;
  // create and add common components to pipeline.
  if (!create_common_elements (config, pipeline, &tmp_elem1, &tmp_elem2,
          bbox_generated_post_analytics_cb)) {
    goto done;
  if(!add_and_link_broker_sink(appCtx)) {
    goto done;
  if (tmp_elem2) {
    NVGSTDS_LINK_ELEMENT (tmp_elem2, last_elem);
    last_elem = tmp_elem1;
  NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the srd pad of the pgie element, since by that time, the buffer would have
   * had got all the nvinfer metadata. */
  pgie_src_pad = gst_element_get_static_pad (pgie, "src");
  /*Creat Context for Object Encoding */
  NvDsObjEncCtxHandle obj_ctx_handle = nvds_obj_enc_create_context ();
  if (!obj_ctx_handle) {
    g_print ("Unable to create context\n");
    return -1;
  if (!pgie_src_pad)
    g_print ("Unable to get src pad\n");
  else
    gst_pad_add_probe (pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
        pgie_src_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
  gst_object_unref (pgie_src_pad);
  // enable performance measurement and add call back function to receive
  // performance data.
  if (config->enable_perf_measurement) {
    appCtx->perf_struct.context = appCtx;
    enable_perf_measurement (&appCtx->perf_struct, fps_pad,
        pipeline->multi_src_bin.num_bins,
        config->perf_measurement_interval_sec,
        config->multi_source_config[0].dewarper_config.num_surfaces_per_frame,
        perf_cb);
  if (config->num_message_consumers) {
    for (i = 0; i < config->num_message_consumers; i++) {
      appCtx->c2d_ctx[i] = start_cloud_to_device_messaging (
                                &config->message_consumer_config[i], NULL,
                                &appCtx->pipeline.multi_src_bin);
      if (appCtx->c2d_ctx[i] == NULL) {
        NVGSTDS_ERR_MSG_V ("Failed to create message consumer");
        goto done;
  GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.pipeline),
      GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-null");
  g_mutex_init (&appCtx->app_lock);
  g_cond_init (&appCtx->app_cond);
  g_mutex_init (&appCtx->latency_lock);
  ret = TRUE;
done:
  if (!ret) {
  return ret;
 * Function to destroy pipeline and release the resources, probes etc.
void
destroy_pipeline (AppCtx * appCtx)
  gint64 end_time;
  guint i;
  GstBus *bus = NULL;
  end_time = g_get_monotonic_time () + G_TIME_SPAN_SECOND;
  if (!appCtx)
    return;
  if (appCtx->pipeline.demuxer) {
    gst_pad_send_event (gst_element_get_static_pad (appCtx->pipeline.demuxer,
            "sink"), gst_event_new_eos ());
  } else if (appCtx->pipeline.instance_bins[0].sink_bin.bin) {
            pipeline.instance_bins[0].sink_bin.bin, "sink"),
  g_usleep (100000);
  if (appCtx->pipeline.pipeline) {
    destroy_smart_record_bin (&appCtx->pipeline.multi_src_bin);
    bus = gst_pipeline_get_bus (GST_PIPELINE (appCtx->pipeline.pipeline));
    while (TRUE) {
      GstMessage *message = gst_bus_pop (bus);
      if (message == NULL)
        break;
      else if (GST_MESSAGE_TYPE (message) == GST_MESSAGE_ERROR)
        bus_callback (bus, message, appCtx);
      else
        gst_message_unref (message);
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_NULL);
  g_cond_wait_until (&appCtx->app_cond, &appCtx->app_lock, end_time);
  for (i = 0; i < appCtx->config.num_source_sub_bins; i++) {
    NvDsInstanceBin *bin = &appCtx->pipeline.instance_bins[i];
      NVGSTDS_ELEM_REMOVE_PROBE (bin->all_bbox_buffer_probe_id,
          bin->osd_bin.nvosd, "sink");
    } else {
          bin->sink_bin.bin, "sink");
      NVGSTDS_ELEM_REMOVE_PROBE (bin->primary_bbox_buffer_probe_id,
          bin->primary_gie_bin.bin, "src");
    free(appCtx->latency_info);
    appCtx->latency_info = NULL;
  destroy_sink_bin ();
  g_mutex_clear(&appCtx->latency_lock);
    gst_bus_remove_watch (bus);
    gst_object_unref (appCtx->pipeline.pipeline);
      if (appCtx->c2d_ctx[i])
        stop_cloud_to_device_messaging (appCtx->c2d_ctx[i]);
gboolean
pause_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  GstStateChangeReturn ret;
  GstClockTime timeout = 5 * GST_SECOND / 1000;
  ret =
      gst_element_get_state (appCtx->pipeline.pipeline, &cur, &pending,
      timeout);
  if (ret == GST_STATE_CHANGE_ASYNC) {
    return FALSE;
  if (cur == GST_STATE_PAUSED) {
    return TRUE;
  } else if (cur == GST_STATE_PLAYING) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PAUSED);
        GST_CLOCK_TIME_NONE);
    pause_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
gboolean
resume_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  ret =
      timeout);
    return FALSE;
    return TRUE;
  } else if (cur == GST_STATE_PAUSED) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PLAYING);
    resume_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
In the above mentioned code I have added the image encoding code as shown below
    int offset = 0;
        face_count++;
        num_rects++;
      //   person_count++;
      //   num_rects++;
        FILE *file;
            /* Write to File */
            fclose (file);
            usrMetaList = NULL;
          } else {
    // offset =
    //     person_count);
    offset =
  frame_number++;
        face_count++;
        num_rects++;
      //   person_count++;
      //   num_rects++;
        /* Preset */
gboolean
    return -1;
  if (!pgie_src_pad)
  else
Make file
In make file i have added the libraries for image encoding in LIBS+=
CUDA_VER?=10.2
ifeq ($(CUDA_VER),)
  $(error "CUDA_VER is not set")
endif
APP:= deepstream-app
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=5.1
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
ifeq ($(TARGET_DEVICE),aarch64)
  CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c)
SRCS+= $(wildcard ../../apps-common/src/*.c)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0 gstreamer-video-1.0 x11 json-glib-1.0
OBJS:= $(SRCS:.c=.o)
CFLAGS+= -I./ -I../../apps-common/includes \
		 -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 \
		 -I /usr/local/cuda-$(CUDA_VER)/include
LIBS:= -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper \
	   -lnvdsgst_smartrecord -lnvds_utils -lnvds_msgbroker -lm \
	   -lnvbufsurface -lnvbufsurftransform -lnvds_batch_jpegenc \
       -lcuda -lgstrtspserver-1.0 -ldl -Wl,-rpath,$(LIB_INSTALL_DIR)
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS+= $(shell pkg-config --libs $(PKGS))
all: $(APP)
%.o: %.c $(INCS) Makefile
	$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
	$(CC) -o $(APP) $(OBJS) $(LIBS)
install: $(APP)
	cp -rv $(APP) $(APP_INSTALL_DIR)
clean:
	rm -rf $(OBJS) $(APP)
Please help me on this issue
You did not get the pgie element, it’s created in function create_common_elements.
@Amycao I tried to get the pgie element create_common_elements function, but still im not able to get the image details while executing the exe
@Amycao Can you share any example related to this issue
You can refer to attached patches for integrating encode cropped images to deepstream-app sample.deepstream_app.patch (5.8 KB)
deepstream_app_main.patch (963 Bytes)
Makefile.patch (518 Bytes)
@Amycao Can you let me know how to work on this path files
What do you mean work on path file?
Sorry how to work on this patch file?
cd / && sudo patch -p0 < patch name
I have tried the patch file but it failed, I have attached the screenshots for reference
Do this first.
yes I did. But it shows as malformed patch for the specified line .
It works on my side. not sure why not work your side. can you google search? let’s focust on deepstream related.
