For the regression of CVE, it is fixed in the recent r36.5 release.
Would you mind sharing more details about the issues you encountered after upgrading (please file a new topic for clarity)
Could you file a topic for your issue with r36.5 as well.
Hello Ashwin,
Since the fix has been released in JetPack 6.2.2 (L4T r36.5), what is the best way to execute the update (Step 8 in your process put on hold every update)? Do you have any recommendations for upgrading the system without performing a full reinstallation?
Thanks for your appreciated help!
Yes, it is possible to upgrade to JetPack 6.2.2 without wiping your existing data.
Please follow the steps below carefully to complete the upgrade.
First, remove the hold on the kernel-related packages:
sudo apt-mark unhold nvidia-l4t-display-kernel nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers nvidia-l4t-kernel-oot-headers nvidia-l4t-kernel-oot-modules
Verify that no packages are held:
sudo apt-mark showhold
Ensure the packages are successfully unheld before proceeding.
You need to update the repository configuration to point to r36.5 instead of your current version.
Open the NVIDIA L4T source list:
sudo nano /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
Locate all entries containing r36.4 and replace them with r36.5.
Save and exit the file (Ctrl + O, Enter, Ctrl + X).
Refresh the package lists and perform the distribution upgrade:
sudo apt update
sudo apt dist-upgrade
After the upgrade, NVIDIA recommends running the following command to resolve dependency issues and ensure all packages are correctly configured:
sudo apt install --fix-broken -o Dpkg::Options::="--force-overwrite"
If prompted about device configuration, enter y and select the maintainer’s version to apply the latest fixes from r36.5.
Reboot the system to apply the new kernel and firmware changes:
sudo reboot
Once the system is back up, verify the upgrade:
sudo apt show nvidia-jetpack
head -n 1 /etc/nv_tegra_release
Expected output:
# R36 (release), REVISION: 5.0
✅ Upgrade complete.
Done, Thank you again for your appreciated help. Best Regards JLouis
