Unable to boot after flash (default install)
I wanted to test the flashing process and did the following steps:
(on an ubuntu 18.04 VM running on Mac via virtualbox, usb passthrough)
I tried to reboot the jetson with hdmi monitor connected but the screen keeps flashing: Dropbox - File Deleted
Similar to this issue - Can't turn on the device
I connected to the uart port and usb passthrough to vm to capture the logs: - Serial Output · GitHub
In the default rootfs/boot/extlinux.conf there’s no ‘quiet’ option to remove so didn’t edit.
Note, my first attempt to flash failed, I had not allocated enough storage to the ubuntu vm (host), on the 2nd attempt the flash succeeded.
Any ideas on how to resolve this?
actually, I found the ‘quiet’ argument in extlinux.conf, removed and reflashing…
will update soon…
ok, that fixed it:)
Resolved
