We have a custom board designed for Orin. We are trying to boot it up using a USB drive, but the issue we encounter is:
[ 12.094322] Root device found: PARTUUID=8ffe1fa0-b97e-4d2e-8e79-d72158e7fc99
[ 12.380597] random: crng init done
[ 22.301366] ERROR: PARTUUID=8ffe1fa0-b97e-4d2e-8e79-d72158e7fc99 mount fail...
We are successfully able to boot the Nvidia jetson orin dev kit, but it fails at the above point while trying on the custom board.
I checked the UUID by blkid
and changed it in bootloader/l4t-rootfs-uuid.txt_ext file. The error persists.
Also, i changed cvb_eeprom_read_size from 0x100 to 0x0
Console log of successful boot on Nvidia Orin devkit:
sBootLog.txt (60.5 KB)
Console log of boot on Custom board:
CBconsoleLog.txt (35.4 KB)
From these logs, i assume that the USB drive is not being detected at all.
9.037042] usb 2-1.3: New USB device found, idVendor=0781, idProduct=55ab, bcdDevice= 1.00
[ 9.045612] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.053113] usb 2-1.3: Product: SanDisk 3.2Gen1
[ 9.057850] usb 2-1.3: Manufacturer: USB
[ 9.061961] usb 2-1.3: SerialNumber: 0401560f40952dbc0e3436df992295ab6675723839beef3157b08d7291ecd0dd91ef00000000000000000000fee19030008c2a18ab558107562ee5c1
[ 9.090568] usb-storage 2-1.3:1.0: USB Mass Storage device detected
This is not found in the custom board boot log.
Below are the relevant images of hardware design for the jetson connector:
hw.zip (185.6 KB)
It is a C type USB drive connected to the board via a USB extension.
Also, custom board works fine with Jetson Nano. We are able to boot Jetson Nano on it with SD card.
Please advice,
