Hi, I just tried booting jetson nano, I used macbook to write the SD card using the instructions exactly as provided in the getting started.
My power supply is an actiontec power adaptor which provides an output of 5VDC 3A 15W model:ADS6818-1505-WD 0530
I also connected the J48 jumper to use the power adaptor
the NVDIA logo is showing at first but doesnt pass the bootup.
errors are the ff:
tegradc tegradc.1: dpd enable lookup fail:-19
1mx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
imx219 6-0010: imx219_board_setup_failed
EXT4-fs error (device mmcblk0p1): ext4_iget:4519: inode 655361: comm cp: checksum invalid
c: failed to access ‘etc/resolv.conf’ : Bad message
EXT4-fs error (device mmcblk0p1): ext4_iget:4519: inode 524485: comm cp: checksum invalid
EXT4-fs error (device mmcblk0p1): ext4_iget:4519: inode 528995: comm cp: checksum invalid
chroot: failed to run command ‘/sbin/init’ : Bad message
Kernel panic - not syncing: Attempted to kill initf exitcode=0x0007e00
etc…
SMP: stopping secondary CPI’s
Kernel Offset:disabled
Memory Limit: none
rebooting in 5 seconds…
any hints? thanks in advanced!
