Unable to build .cu File with VSE++ 08
Hello everyone!
System information:
Windows Vista Home, SP2
Toolkit 2.2
SDK 2.2.1
Driver 186.03
Visual C++ 2008 Express Edition
I am able to compile and run the example Files of CUDA. I have also completed all steps of the Getting Started Document and varified that the installition is correct. Now I am trying to make my own example. Therefore I add a new directory in examples named testFiles where I have the file test1.cu with the following simple code:
By now clicking on Start Debugging following error occurs:
What I am doing wrong?
Greets Alex
OK, the problem discribed above has been solved … but there is a new one, I have expanded the program a little bit
Error:
I am using the German version - the Error is “error LNK2019: unresolved external symbol”
I read some topics with the same error and added the extern “C” thing, but it won’t help.
Does noone have any advice for me? :( If i posted in the wrong forum, please let me know
Regards
External Media
I have exactly the same problem. I added in Linker Additional Dependencies msvcrt.lib.
that helped on some errors. but 10 errors are also with my compilation script on.Same then on yours.
Regards
teraflop
:rolleyes:
the problem is at another point.
the cuda/bin
there are bin2c.exe fatbin.exe filehash.exe
they all refer to dlls
a wer.dll bcrypt.dll and ncrypt.dll
if this 3 dlls are x86 they will not run on an x64 CPU environement
so for example fatbin cannot make the link then correctly
regards
teraflop
