I’m trying to compile an edk2 build to flash on my AGX Orin, but have hit a blocker. I am compiling an Ubuntu 18.04 Docker image (https://github.com/makinbacon21/nvidia-edk2-docker) following each official step up to the build script (edk2-nvidia/Platform/NVIDIA/Jetson/build.sh), which I run manually. The script fails on “Loading Plugins”:
SECTION - Loading Plugins
ERROR - Failed to import plugin: /home/nvidia/edkrepo/nvidia-uefi/edk2/BaseTools/Plugin/LinuxGcc5ToolChain/LinuxGcc5ToolChain.py
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/site-packages/edk2toolext/environment/plugin_manager.py", line 83, in _load
("py", "r", imp.PY_SOURCE))
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/imp.py", line 235, in load_module
return load_source(name, filename, file)
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/imp.py", line 172, in load_source
module = _load(spec)
File "<frozen importlib._bootstrap>", line 684, in _load
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 674, in exec_module
File "<frozen importlib._bootstrap_external>", line 780, in get_code
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/imp.py", line 156, in get_data
return file.read()
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/encodings/ascii.py", line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 3620: ordinal not in range(128)
CRITICAL - One or more plugins failed to load. Halting build.
ERROR - Failed Plugin: Linux GCC5 Tool Chain Support
File "/home/nvidia/edkrepo/nvidia-uefi/venv/bin/stuart_update", line 8, in <module>
sys.exit(main())
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/site-packages/edk2toolext/invocables/edk2_update.py", line 100, in main
Edk2Update().Invoke()
File "/home/nvidia/edkrepo/nvidia-uefi/venv/lib/python3.6/site-packages/edk2toolext/base_abstract_invocable.py", line 134, in Invoke
raise Exception("One or more plugins failed to load.")
Exception: One or more plugins failed to load.
On my Fedora 36 Server (natively, not in docker), I get much further, but several issues arise (presumably due to newer toolchain):
SECTION - Start Invocable Tool
File "/home/tmakin/edkrepo/nvidia-uefi/edk2/BaseTools/Edk2ToolsBuild.py", line 177, in <module>
main()
File "/home/tmakin/edkrepo/nvidia-uefi/edk2/BaseTools/Edk2ToolsBuild.py", line 173, in main
Edk2ToolsBuild().Invoke()
File "/home/tmakin/edkrepo/nvidia-uefi/venv/lib/python3.10/site-packages/edk2toolext/base_abstract_invocable.py", line 141, in Invoke
retcode = self.Go()
File "/home/tmakin/edkrepo/nvidia-uefi/edk2/BaseTools/Edk2ToolsBuild.py", line 148, in Go
raise Exception("Failed to build.")
Exception: Failed to build.
^ Context: the error returned is 2 (from make), due to a bunch of build errors
