i’m unable to build kernel module of 325.08 driver with 3.10 kernel of actual debian sid
log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Jul 29 13:35:08 2013
installer version: 325.08
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/bin/X11
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 325.08.
-> There appears to already be a driver installed on your system (version: 325.08). As part of installing this driver (version: 325.08), the existing driver will be uninstalled. Are you sure you want to continue? ('no' will abort installation) (Answer: Yes)
-> Performing CC sanity check with CC="cc".
-> Kernel source path: '/lib/modules/3.10-1-amd64/source'
-> Kernel output path: '/lib/modules/3.10-1-amd64/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; make clean'...
-> Building kernel module:
executing: 'cd ./kernel; make module SYSSRC=/lib/modules/3.10-1-amd64/source SYSOUT=/lib/modules/3.10-1-amd64/build'...
NVIDIA: calling KBUILD...
make[1]: Entering directory `/usr/src/linux-headers-3.10-1-common'
make -C /lib/modules/3.10-1-amd64/build \
KBUILD_SRC=/usr/src/linux-headers-3.10-1-common \
KBUILD_EXTMOD="/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel" -f /usr/src/linux-headers-3.10-1-common/Makefile \
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
mkdir -p /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_versions ; rm -f /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_versions/*
make -f /usr/src/linux-headers-3.10-1-common/scripts/Makefile.build obj=/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -
DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno
-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv.c
In file included from /usr/src/linux-headers-3.10-1-common/include/linux/kernel.h:10:0,
from /usr/src/linux-headers-3.10-1-common/include/linux/sched.h:15,
from /usr/src/linux-headers-3.10-1-common/include/linux/utsname.h:5,
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-linux.h:44,
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv.c:13:
/usr/src/linux-headers-3.10-1-common/include/linux/bitops.h: In function ‘hweight_long’:
/usr/src/linux-headers-3.10-1-common/include/linux/bitops.h:66:41: warning: signed and unsigned type in conditional expression [-Wsign-compare]
In file included from /usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/cpumask.h:4:0,
from /usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/msr.h:10,
from /usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/processor.h:20,
from /usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/thread_info.h:22,
from /usr/src/linux-headers-3.10-1-common/include/linux/thread_info.h:54,
from /usr/src/linux-headers-3.10-1-common/include/linux/preempt.h:9,
from /usr/src/linux-headers-3.10-1-common/include/linux/spinlock.h:50,
from /usr/src/linux-headers-3.10-1-common/include/linux/seqlock.h:29,
from /usr/src/linux-headers-3.10-1-common/include/linux/time.h:5,
from /usr/src/linux-headers-3.10-1-common/include/uapi/linux/timex.h:56,
from /usr/src/linux-headers-3.10-1-common/include/linux/timex.h:56,
from /usr/src/linux-headers-3.10-1-common/include/linux/sched.h:17,
/usr/src/linux-headers-3.10-1-common/include/linux/cpumask.h: In function ‘cpumask_parse’:
/usr/src/linux-headers-3.10-1-common/include/linux/cpumask.h:603:26: warning: signed and unsigned type in conditional expression [-Wsign-compare]
In file included from /usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/uaccess.h:539:0,
from /usr/src/linux-headers-3.10-1-common/include/linux/poll.h:11,
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-linux.h:97,
/usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’:
/usr/src/linux-headers-3.10-1-common/arch/x86/include/asm/uaccess_64.h:62:6: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.10-
1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_
STR
ING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-acpi.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-acpi.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-acpi.c:15:
/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-acpi.c: At top level:
/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-acpi.c:70:9: warning: initialization from incompatible pointer type [enabled by default]
/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-acpi.c:70:9: warning: (near initialization for ‘nv_acpi_driver_template.ops.remove’) [enabled by default]
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-chrdev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.
10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_
VERSION_
STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-chrdev.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-chrdev.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-chrdev.c:15:
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno
-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-cray.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-cray.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-cray.c:15:
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-drm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -
-fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-drm.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-drm.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-drm.c:15:
In file included from /usr/src/linux-headers-3.10-1-common/include/drm/drm_crtc.h:32:0,
from /usr/src/linux-headers-3.10-1-common/include/drm/drmP.h:691,
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-drm.c:19:
/usr/src/linux-headers-3.10-1-common/include/linux/fb.h: In function ‘__fb_pad_aligned_buffer’:
/usr/src/linux-headers-3.10-1-common/include/linux/fb.h:650:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-gvi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-headers-3.10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -
ous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_gvi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-gvi.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-gvi.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-gvi.c:15:
cc -Wp,-MD,/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.7/include -I/usr/src/linux-headers-3.10-1-common/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-headers-3.10-1-common/include -Iinclude -I/usr/src/linux-headers-3.10-1-common/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.10-1-common/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-
headers-3.10-1-common/include/linux/kconfig.h -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -Wno-maybe-uninitialized -m64 -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM
-DN
V_VERSION_STRING=\"325.08\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_i2c)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/.tmp_nv-i2c.o /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-i2c.c
from /tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-i2c.c:15:
/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-i2c.c: In function ‘nv_i2c_del_adapter’:
/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-i2c.c:252:14: error: void value not ignored as it ought to be
make[3]: *** [/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel/nv-i2c.o] Error 1
make[2]: *** [_module_/tmp/selfgz3346/NVIDIA-Linux-x86_64-325.08/kernel] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.10-1-common'
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make: *** [module] Error 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
