When will the source for nvidia-installer, nvidia-modprobe, etc version 340.96 be available? I need those to be able to build a Slackware package of the nVidia driver 340.96.
Mats
Mats
Might be a stupid question, but what kind of source are you looking for? Those scripts are inside a .run package that you can extract with -x option i.e.
$ wget us.download.nvidia.com/XFree86/Linux-x86_64/340.46/NVIDIA-Linux-x86_64-340.46.run
$ sh NVIDIA-Linux-x86_64-340.46.run --check
check sums and md5 sums are ok
$ sh NVIDIA-Linux-x86_64-340.46.run -x --tmpdir /var/tmp
$ cd NVIDIA-Linux-x86_64-340.46
NVIDIA-Linux-x86_64-340.46 $ ls
32 libnvidia-ml.so.340.46 nvidia-installer
glext.h libnvidia-opencl.so.340.46 nvidia-installer.1.gz
gl.h libnvidia-tls.so.340.46 nvidia-modprobe
glxext.h libnvidia-wfb.so.340.46 nvidia-modprobe.1.gz
glx.h libOpenCL.so.1.0.0 nvidia-persistenced
html libvdpau_nvidia.so.340.46 nvidia-persistenced.1.gz
kernel libvdpau.so.340.46 nvidia-persistenced-init.tar.bz2
libcuda.so.340.46 libvdpau_trace.so.340.46 nvidia-settings
libEGL.so.340.46 LICENSE nvidia-settings.1.gz
libGLESv1_CM.so.340.46 makeself-help-script.sh nvidia-settings.desktop
libGL.la mkprecompiled nvidia-smi
libGL.so.340.46 monitoring.conf nvidia-smi.1.gz
libglx.so.340.46 nvidia-application-profiles-340.46-key-documentation nvidia-xconfig
libnvcuvid.so.340.46 nvidia-application-profiles-340.46-rc nvidia-xconfig.1.gz
libnvidia-cfg.so.340.46 nvidia-bug-report.sh pci.ids
libnvidia-compiler.so.340.46 NVIDIA_Changelog pkg-history.txt
libnvidia-eglcore.so.340.46 nvidia-cuda-mps-control README.txt
libnvidia-encode.so.340.46 nvidia-cuda-mps-control.1.gz tls
libnvidia-fbc.so.340.46 nvidia-cuda-mps-server
Granted I don’t use source based distribution so I might be a wrong person to give advice. But what I looked for Index of /XFree86, there are only .run packages so I gave my advice anyway(note us.download.nvidia.com/XFree86 is a different server).
I have the .run file but I need to build nvidia-installer etc. from source. The last version available on Index of /XFree86/nvidia-installer is 340.32.
Thanks for pointing this out. It should be up now.
FWIW, I also push updates to github: GitHub - NVIDIA/nvidia-settings at 340
(and in this particular case, Release 340.46 · NVIDIA/nvidia-settings · GitHub )
Thanks for the update Aaron. Now I’m running 340.46 so this thread can be marked as solved.
Never mind. They’re up now.
