I have a ConnectX-3 Pro NIC and trying to use it with dpdk.
Since I have a 4.14.14-1.el7.elrepo.x86_64 kernel I tried to use rdma-core_v16 first.
I successfully built rpm’s and installed them.
After that I built dpdk with Mellanox support but unfortunately a testpmd runs with error:
PMD: net_mlx4: 0xda13c0: cannot attach flow rules (code 95, "Operation
not supported"), flow error type 2, cause 0x7f2869cdab80, message:
flow rule rejected by device
I also have a server with older kernel and MLX OFED installed and testpmd runs normally on it.
So I decided to try MLX OFED on server with kernel 4.14 too.
I downloaded OFED sources and tried to build drivers but during compilation got several errors, like:
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/infiniband/core/umem.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/net/ethernet/mellanox/mlx4/en_netdev.c:4149:2: error: initialization from incompatible pointer type [-Werror]
.ndo_setup_tc = mlx4_en_setup_tc,
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/net/ethernet/mellanox/mlx4/en_netdev.c:4149:2: error: (near initialization for ‘mlx4_netdev_base_ops.ndo_setup_tc’) [-Werror]
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/net/ethernet/mellanox/mlx4/en_clock.o
cc1: all warnings being treated as errors
make[3]: *** [/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/net/ethernet/mellanox/mlx4/en_netdev.o] Error 1
make[3]: *** Waiting for unfinished jobs…
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/net/ethernet/mellanox/mlx5/core/dev.o
In file included from /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/infiniband/core/umem_rbtree.c:36:0:
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/infiniband/core/umem_rbtree.c:71:33: error: conflicting types for ‘rbt_ib_umem_insert’
node_start, node_last, , rbt_ib_umem)
include/linux/interval_tree_generic.h:68:15: note: in definition of macro ‘INTERVAL_TREE_DEFINE’
ITSTATIC void ITPREFIX ## _insert(ITSTRUCT *node, \
In file included from /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/infiniband/core/umem_rbtree.c:39:0:
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/include/rdma/ib_umem_odp.h:131:6: note: previous declaration of ‘rbt_ib_umem_insert’ was here
void rbt_ib_umem_insert(struct umem_odp_node *node, struct rb_root *root);
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-4.2/obj/default/drivers/infiniband/core/umem_rbtree.c:71:33: error: conflicting types for ‘rbt_ib_umem_remove’
include/linux/interval_tree_generic.h:95:15: note: in definition of macro ‘INTERVAL_TREE_DEFINE’
ITSTATIC void ITPREFIX ## _remove(ITSTRUCT *node, \
The full log file is attached.
How to solve these compilation errors?
mlnx-ofa_kernel-4.2.rpmbuild.log.zip (40.6 KB)
