Unable to burn fuses (dev kit) / no more output (serial/hdmi) / bricked?
I’m trying to test and validate the process outlined at - https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3231/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fbootloader_secure_boot.html%23wwpID0E0UG0HA
I’ve generated pkc, sbk and kek2 keys.
pkc = openssl key generated as mentioned in guide
sbk = 4x 8bit hex values, e.g. 0xaaaaaaaa 0xbbbbbbbb 0xcccccccc 0xdddddddd
kek2 = 128 bit hex value
I first attempted with --noburn which completed successfully, this was to confirm files and formats were ok, I then un-tarred and ran ./fusecmd.sh which failed.
root@ubuntu:/storage/Linux_for_Tegra/bootloader# ./fusecmd.sh
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0140 ] Burning fuses
[   0.0141 ] Generating RCM messages
[   0.0159 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0185 ] Header already present for mb1_t194_prod.bin
[   0.0369 ]
[   0.0392 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0410 ] Assuming zero filled SBK key
[   0.0486 ]
[   0.0500 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0515 ] Assuming zero filled SBK key
[   0.0610 ]
[   0.0631 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0727 ]
[   0.0744 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0831 ]
[   0.0844 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0861 ] RCM 0 is saved as rcm_0.rcm
[   0.0937 ] RCM 1 is saved as rcm_1.rcm
[   0.0976 ] RCM 2 is saved as rcm_2.rcm
[   0.0980 ] List of rcm files are saved in rcm_list.xml
[   0.0982 ]
[   0.0986 ] Signing RCM messages
[   0.1004 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.1021 ] Assuming zero filled SBK key
[   0.1140 ]
[   0.1141 ] Copying signature to RCM mesages
[   0.1158 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1247 ]
[   0.1251 ] Boot Rom communication
[   0.1267 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.1283 ] BR_CID: 0x880219116459e587100000000fff0240
[   0.1356 ] RCM version 0X190001
[   0.1544 ] Boot Rom communication completed
[   1.1730 ]
[   2.1772 ] tegrarcm_v2 --isapplet
[   2.1810 ] Applet version 01.00.0000
[   2.2151 ]
[   2.2182 ] Parsing fuse info as per xml file
[   2.2198 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[   2.2216 ] MagicId=0x45535546 version=0x1
[   2.2256 ] node: name=SecureBootKey size=16
[   2.2296 ]   value=0x20e3f97f4c3678081fea84963298fb61
[   2.2304 ] node: name=Kek2 size=16
[   2.2307 ]   value=0x60ca57edf25f2fbf14e9f79c4dcad332
[   2.2309 ] node: name=PublicKeyHash size=32
[   2.2313 ]   value=0x8800cd191669b84b1fb82912384937c021b71e59cfda634e822640a2a5fbd269
[   2.2316 ] node: name=BootSecurityInfo size=4
[   2.2322 ]   value=0x5
[   2.2324 ]
[   2.2341 ] tegrarcm_v2 --oem burnfuses blow_fuse_data.bin
[   2.2358 ] Applet version 01.00.0000
[   2.2642 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported.
[   2.2816 ]
[   2.2819 ] Fuse burning failed
[   2.2821 ]
[   2.2824 ] trying fusing with CPU binary
[   2.2854 ] tegrasign_v2 --key None --getmode mode.txt
[   2.2869 ] Assuming zero filled SBK key
[   2.2939 ]
[   2.2942 ] Parsing partition layout
[   2.2957 ] tegraparser_v2 --pt flash.xml.tmp
[   2.3010 ]
[   2.3011 ] Creating list of images to be signed
[   2.3030 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   2.3048 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.3125 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.3230 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.3328 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.3427 ] adding BCH for spe_t194.bin
[   2.3458 ] adding BCH for spe_t194.bin
[   2.3510 ] adding BCH for nvtboot_t194.bin
[   2.3577 ] adding BCH for nvtboot_t194.bin
[   2.3672 ] Header already present for preboot_c10_prod_cr.bin
[   2.3787 ] Header already present for preboot_c10_prod_cr.bin
[   2.3900 ] Header already present for mce_c10_prod_cr.bin
[   2.3985 ] Header already present for mce_c10_prod_cr.bin
[   2.4085 ] adding BCH for mts_c10_prod_cr.bin
[   2.4172 ] adding BCH for mts_c10_prod_cr.bin
[   2.5159 ] adding BCH for cboot_t194.bin
[   2.6240 ] adding BCH for cboot_t194.bin
[   2.6373 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.6565 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.6715 ] adding BCH for tos_t194.img
[   2.6832 ] adding BCH for tos_t194.img
[   2.6942 ] adding BCH for eks.img
[   2.7129 ] adding BCH for eks.img
[   2.7166 ] adding BCH for bpmp_t194.bin
[   2.7203 ] adding BCH for bpmp_t194.bin
[   2.7474 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.7801 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.7997 ] adding BCH for camera-rtcpu-rce.img
[   2.8189 ] adding BCH for camera-rtcpu-rce.img
[   2.8313 ] adding BCH for adsp-fw.bin
[   2.8426 ] adding BCH for adsp-fw.bin
[   2.8493 ] Header already present for warmboot_t194_prod.bin
[   2.8603 ] Header already present for warmboot_t194_prod.bin
[   2.8667 ] Stat for RECFILE failed
[   2.8668 ]
Error: Return value 4
Command tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
2nd attempt, tried to fuse directly :
root@ubuntu:/storage/Linux_for_Tegra# ./odmfuse.sh -j -i 0x19 -c PKC -k /storage/keys/pkc.pem -S /storage/keys/sbk.txt --KEK2 /storage/keys/kek2.txt jetson-xavier
Error: Cannot fuse non-production board.
Note, I left of the -p flag as I’m still testing, any idea what I’m doing wrong?
I’m guessing I need to use the -p option?, but that would mean I can no longer make or test changes?
There is a patch for odmfuse.sh:
Please apply it and try again.
Hi DaneLLL,
I patched and re-ran:
copying soft_fuses(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
version 1.0.0
[   0.0131 ] Generating RCM messages
[   0.0171 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0186 ] Header already present for /storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0413 ]
[   0.0441 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0460 ] Assuming zero filled SBK key
[   0.0573 ]
[   0.0589 ] tegrasign_v2 --key None --file /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0604 ] Assuming zero filled SBK key
[   0.0722 ]
[   0.0738 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0858 ]
[   0.0891 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.1043 ]
[   0.1065 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.1085 ] RCM 0 is saved as rcm_0.rcm
[   0.1157 ] RCM 1 is saved as rcm_1.rcm
[   0.1188 ] RCM 2 is saved as rcm_2.rcm
[   0.1196 ] List of rcm files are saved in rcm_list.xml
[   0.1199 ]
[   0.1201 ] Signing RCM messages
[   0.1213 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.1230 ] Assuming zero filled SBK key
[   0.1333 ]
[   0.1338 ] Copying signature to RCM mesages
[   0.1353 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1413 ]
[   0.1415 ] Boot Rom communication
[   0.1430 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.1447 ] RCM version 0X190001
[   0.1485 ] Boot Rom communication completed
[   1.1741 ]
[   2.1778 ] tegrarcm_v2 --isapplet
[   2.1806 ] Applet version 01.00.0000
[   2.2157 ]
[   2.2171 ] tegrarcm_v2 --ismb2
[   2.2458 ]
[   2.2474 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2533 ]
[   2.2544 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2557 ] adding BCH for nvtboot_applet_t194.bin
[   2.2715 ]
[   2.2742 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2757 ] Assuming zero filled SBK key
[   2.2853 ]
[   2.2909 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2985 ]
[   2.3002 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.3022 ] Applet version 01.00.0000
[   2.3281 ] Sending mb2
[   2.3294 ] [................................................] 100%
[   2.3521 ]
[   2.3536 ] tegrarcm_v2 --boot recovery
[   2.3550 ] Applet version 01.00.0000
[   2.3933 ]
[   3.3977 ] tegrarcm_v2 --isapplet
[   3.4253 ]
[   3.4269 ] tegrarcm_v2 --ismb2
[   3.4283 ] MB2 Applet version 01.00.0000
[   3.4542 ]
[   3.4555 ] tegrarcm_v2 --ismb2
[   3.4569 ] MB2 Applet version 01.00.0000
[   3.4856 ]
[   3.4871 ] Retrieving EEPROM data
[   3.4875 ] tegrarcm_v2 --oem platformdetails eeprom cvm /storage/Linux_for_Tegra/bootloader/cvm.bin
[   3.4889 ] MB2 Applet version 01.00.0000
[   3.5209 ] Saved platform info in /storage/Linux_for_Tegra/bootloader/cvm.bin
[   3.5718 ]
[   3.5720 ] Rebooting to recovery mode
[   3.5733 ] tegrarcm_v2 --ismb2
[   3.5747 ] MB2 Applet version 01.00.0000
[   3.6053 ]
[   3.6056 ] Rebooting to recovery mode
[   3.6068 ] tegrarcm_v2 --reboot recovery
[   3.6082 ] MB2 Applet version 01.00.0000
[   3.6534 ]
Board ID(2888) version(400) sku(0004) revision(K.0)
copying sdram_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying sdram_config1(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying misc_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying scr_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying pmc_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying pmic_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying br_cmd_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying prod_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying misc_cold_boot_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying device_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying uphy_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying gpioint_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
Existing mb2_bootloader(/storage/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/storage/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/storage/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/storage/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/storage/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Existing bpmp_fw(/storage/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpmp_fw_dtb(/storage/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing tlk(/storage/Linux_for_Tegra/bootloader/tos_t194.img) reused.
Existing eks(/storage/Linux_for_Tegra/bootloader/eks.img) reused.
Existing spe_fw(/storage/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing mb1file(/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/storage/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing tegraboot(/storage/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/storage/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
Existing scefile(/storage/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/storage/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing wb0boot(/storage/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/storage/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing bl(/storage/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing applet(/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
*** Calculating HASH from keyfile /storage/keys/pkc.pem ... done
PKC HASH: 0x69d2fba5a24026824e63dacf591eb721c03749381229b81f4bb8691619cd0088
*** Generating fuse configuration ... done.
done.
*** Start fusing  ...
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; tlk tos_t194.img; eks eks.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --bl nvtboot_recovery_cpu_t194.bin --odmdata 0x9190000 --chip 0x19 --applet mb1_t194_prod.bin  --cmd "burnfuses odmfuse_pkc.xml" --skipuid
version 1.0.0
[   0.0157 ] Burning fuses
[   0.0157 ] Generating RCM messages
[   0.0171 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0184 ] Header already present for mb1_t194_prod.bin
[   0.0322 ]
[   0.0337 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0351 ] Assuming zero filled SBK key
[   0.0415 ]
[   0.0434 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0449 ] Assuming zero filled SBK key
[   0.0522 ]
[   0.0538 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0643 ]
[   0.0659 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0726 ]
[   0.0740 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0757 ] RCM 0 is saved as rcm_0.rcm
[   0.0827 ] RCM 1 is saved as rcm_1.rcm
[   0.0859 ] RCM 2 is saved as rcm_2.rcm
[   0.0892 ] List of rcm files are saved in rcm_list.xml
[   0.0894 ]
[   0.0898 ] Signing RCM messages
[   0.0917 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0934 ] Assuming zero filled SBK key
[   0.1039 ]
[   0.1045 ] Copying signature to RCM mesages
[   0.1059 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1122 ]
[   0.1124 ] Boot Rom communication
[   0.1139 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.1153 ] Boot Rom communication failed
[   5.2538 ]
Error: Return value 3
Command tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
failed.
Serial
[0311.434] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0311.443] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0311.448] I> Boot-mode: Platform RCM
[0311.452] I> Chip revision : A02
[0311.455] I> Bootrom patch version : 15 (correctly patched)
[0311.460] I> ATE fuse revision : 0x200
[0311.463] I> Ram repair fuse : 0x0
[0311.467] I> Ram Code : 0x2
[0311.469] I> rst_source : 0xb
[0311.472] I> rst_level : 0x1
[0311.476] I> USB configuration success
[0313.593] I> mb2 image downloaded
[0313.634] I> Recovery boot mode 0
[0313.638] I> Boot-device: eMMC
[0313.643] I> UPHY full init done
[0313.647] I> MB1 done
[0313.652] W> Profiler not initialized
[0313.656] I> Welcome to MB2(TBoot-BPMP) Applet (version: 00.00.2018.32-mobile-2cd5f333)
[0313.664] W> Profiler not initialized
[0313.667] I> DMA Heap @ [0x40020000 - 0x40065800]
[0313.672] I> Default Heap @ [0xd486400 - 0xd48a400]
[0313.677] W> Profiler not initialized
[0313.680] W> Profiler not initialized
[0313.684] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0313.689] W> device prod register failed
[0313.693] W> Profiler not initialized
[0313.715] I> sdmmc DDR50 mode
[0313.719] I> No supported QSPI flash found
[0313.723] E> QSPI Flash: Insufficient flash size (0 MB)
[0313.728] I> QSPI Flash is not present.
[0313.779] E> Link startup dme_set failed
[0313.783] E> UFS initialization failed
[0313.786] I> UFS is not present
[0313.789] W> Profiler not initialized
[0313.797] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0313.805] I> Found 42 partitions in SDMMC_USER (instance 3)
[0313.811] W> Profiler not initialized
[0313.814] W> Profiler not initialized
[0313.818] W> Profiler not initialized
[0313.821] I> Entering 3p server
[0313.825] I> USB configuration success
[0314.778] I> Populate eeprom info
[0314.784] I> Populate eeprom info for module cvm
[0314.897] I> Rebooting : reboot-recovery
Please run tegrafuse.sh to get status of the board.
It is probably in a similar condition like:
copied tegrafuse.sh to jetson, and ran:
root@xavier:~# tegrafuse.sh
odm_lock : 0x00000000
arm_jtag_disable : 0x00000000
odm_production_mode : 0x00000000
boot_security_info : 0x00000000
odm_info : 0x00000000
root@xavier:~#
Please do
  1. Revert the patch and apply the attachment:
    0001-l4t-config-fill-missing-flash.xml-conversion-vectors.patch.zip (1.0 KB)
  2. Edit odmfuse_pkc.xml to have only two lines:
    <genericfuse MagicId="0x45535546" version="1.0.0"> </genericfuse>
  3. run fusecmd.sh
Hi DaneLLL,
  • Patched odmfuse.sh
  • Edited odumfuse_pkc.xml with just <genericfuse... lines
  • ran ./fusecmd.sh
Here’s the output:
    version 1.0.0
    [   0.0156 ] Burning fuses
    [   0.0169 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
    [   0.0187 ] Header already present for mb1_t194_prod.bin
    [   0.0359 ]
    [   0.0372 ] tegrasign_v2 --key None --getmode mode.txt
    [   0.0386 ] Assuming zero filled SBK key
    [   0.0452 ]
    [   0.0466 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
    [   0.0481 ] Assuming zero filled SBK key
    [   0.0579 ]
    [   0.0593 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
    [   0.0702 ]
    [   0.0719 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
    [   0.0783 ]
    [   0.0797 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
    [   0.0812 ] RCM 0 is saved as rcm_0.rcm
    [   0.0895 ] RCM 1 is saved as rcm_1.rcm
    [   0.0933 ] RCM 2 is saved as rcm_2.rcm
    [   0.0940 ] List of rcm files are saved in rcm_list.xml
    [   0.0942 ]
    [   0.0946 ] Signing RCM messages
    [   0.0958 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
    [   0.0972 ] Assuming zero filled SBK key
    [   0.1042 ]
    [   0.1063 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
    [   0.1137 ]
    [   0.1138 ] Boot Rom communication
    [   0.1153 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
    [   0.1166 ] BR_CID: 0x880219116459e587100000000fff0240
    [   0.1236 ] RCM version 0X190001
    [   0.1430 ] Boot Rom communication completed
    [   1.1625 ]
    [   2.1662 ] tegrarcm_v2 --isapplet
    [   2.1702 ] Applet version 01.00.0000
    [   2.2013 ]
    [   2.2041 ] Parsing fuse info as per xml file
    [   2.2088 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
    [   2.2104 ] MagicId=0x45535546 version=0x1
    [   2.2193 ]
    [   2.2206 ] tegrarcm_v2 --oem burnfuses blow_fuse_data.bin
    [   2.2223 ] Applet version 01.00.0000
    [   2.2495 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported.
    [   2.2689 ]
    [   2.2692 ] Fuse burning failed
    [   2.2694 ]
    [   2.2698 ] trying fusing with CPU binary
    [   2.2759 ] tegrasign_v2 --key None --getmode mode.txt
    [   2.2781 ] Assuming zero filled SBK key
    [   2.2852 ]
    [   2.2855 ] Parsing partition layout
    [   2.2872 ] tegraparser_v2 --pt flash.xml.tmp
    [   2.2935 ]
    [   2.2936 ] Creating list of images to be signed
    [   2.2955 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
    [   2.2970 ] MB1: Nvheader already present is mb1_t194_prod.bin
    [   2.3035 ] Header already present for mb1_t194_prod_sigheader.bin
    [   2.3132 ] MB1: Nvheader already present is mb1_t194_prod.bin
    [   2.3209 ] Header already present for mb1_t194_prod_sigheader.bin
    [   2.3296 ] adding BCH for spe_t194.bin
    [   2.3344 ] adding BCH for spe_t194.bin
    [   2.3410 ] adding BCH for nvtboot_t194.bin
    [   2.3479 ] adding BCH for nvtboot_t194.bin
    [   2.3588 ] Header already present for preboot_c10_prod_cr.bin
    [   2.3742 ] Header already present for preboot_c10_prod_cr.bin
    [   2.3847 ] Header already present for mce_c10_prod_cr.bin
    [   2.3964 ] Header already present for mce_c10_prod_cr.bin
    [   2.4027 ] adding BCH for mts_c10_prod_cr.bin
    [   2.4094 ] adding BCH for mts_c10_prod_cr.bin
    [   2.5101 ] adding BCH for cboot_t194.bin
    [   2.6153 ] adding BCH for cboot_t194.bin
    [   2.6333 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
    [   2.6551 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
    [   2.6744 ] adding BCH for tos_t194.img
    [   2.6848 ] adding BCH for tos_t194.img
    [   2.6951 ] adding BCH for eks.img
    [   2.7055 ] adding BCH for eks.img
    [   2.7083 ] adding BCH for bpmp_t194.bin
    [   2.7124 ] adding BCH for bpmp_t194.bin
    [   2.7419 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
    [   2.7744 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
    [   2.7948 ] adding BCH for camera-rtcpu-rce.img
    [   2.8143 ] adding BCH for camera-rtcpu-rce.img
    [   2.8266 ] adding BCH for adsp-fw.bin
    [   2.8394 ] adding BCH for adsp-fw.bin
    [   2.8462 ] Header already present for warmboot_t194_prod.bin
    [   2.8608 ] Header already present for warmboot_t194_prod.bin
    [   2.8656 ] Stat for RECFILE failed
    [   2.8662 ]
Serial console:
[0070.434] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2     from HW fuses.
[0070.442] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0070.448] I> Boot-mode: RCM
[0070.450] I> Chip revision : A02
[0070.453] I> Bootrom patch version : 15 (correctly patched)
[0070.459] I> ATE fuse revision : 0x200
[0070.462] I> Ram repair fuse : 0x0
[0070.465] I> Ram Code : 0x2
[0070.468] I> rst_source : 0x0
[0070.470] I> rst_level : 0x0
[0070.474] I> USB configuration success
[0072.520] I> Handling oem command 6
[0072.523] E> NV3P_SERVER: Fuse burn is not supported.
I think I was meant to generate a new fusecmd after patching, lemme test…
  • ./odmfuse.sh --noburn -j -i 0x19 -c PKC -k /storage/keys/pkc.pem -S /storage/keys/sbk.txt --KEK2 /storage/keys/kek2.txt jetson-xavier
  • tar xf fuseblob.tbz2
  • removed keys from odmfuse_pkc.xml
  • ran ./fusecmd.sh
seems different this time, in the middle of flashing it seemed to want to boot the system and the flashing fails!
Output:
version 1.0.0
[   0.0158 ] Generating RCM messages
[   0.0352 ]
[   0.0366 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0379 ] Assuming zero filled SBK key
[   0.0471 ]
[   0.0485 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0498 ] Assuming zero filled SBK key
[   0.0596 ]
[   0.0610 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0711 ]
[   0.0725 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0791 ]
[   0.0806 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0821 ] RCM 0 is saved as rcm_0.rcm
[   0.0931 ] RCM 2 is saved as rcm_2.rcm
[   0.0938 ] List of rcm files are saved in rcm_list.xml
[   0.0940 ]
[   0.0943 ] Signing RCM messages
[   0.0960 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0979 ] Assuming zero filled SBK key
[   0.1060 ]
[   0.1061 ] Copying signature to RCM mesages
[   0.1076 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1164 ]
[   0.1165 ] Boot Rom communication
[   0.1180 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.1195 ] BootRom is not running
[   5.2994 ]
[   6.3036 ] tegrarcm_v2 --isapplet
[   6.3069 ] Applet version 01.00.0000
[   6.3391 ]
[   6.3415 ] Parsing fuse info as per xml file
[   6.3429 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[   6.3443 ] MagicId=0x45535546 version=0x1
[   6.3507 ]
[   6.3522 ] tegrarcm_v2 --oem burnfuses blow_fuse_data.bin
[   6.3536 ] Applet version 01.00.0000
[   6.3772 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported.
[   6.3973 ]
[   6.3977 ] Fuse burning failed
[   6.3983 ]
[   6.3986 ] trying fusing with CPU binary
[   6.4014 ] tegrasign_v2 --key None --getmode mode.txt
[   6.4027 ] Assuming zero filled SBK key
[   6.4151 ]
[   6.4153 ] Parsing partition layout
[   6.4167 ] tegraparser_v2 --pt flash.xml.tmp
[   6.4240 ]
[   6.4242 ] Creating list of images to be signed
[   6.4257 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   6.4270 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   6.4339 ] Header already present for mb1_t194_prod_sigheader.bin
[   6.4450 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   6.4547 ] Header already present for mb1_t194_prod_sigheader.bin
[   6.4633 ] adding BCH for spe_t194.bin
[   6.4667 ] adding BCH for spe_t194.bin
[   6.4723 ] adding BCH for nvtboot_t194.bin
[   6.4794 ] adding BCH for nvtboot_t194.bin
[   6.4885 ] Header already present for preboot_c10_prod_cr.bin
[   6.5000 ] Header already present for preboot_c10_prod_cr.bin
[   6.5093 ] Header already present for mce_c10_prod_cr.bin
[   6.5207 ] Header already present for mce_c10_prod_cr.bin
[   6.5258 ] adding BCH for mts_c10_prod_cr.bin
[   6.5312 ] adding BCH for mts_c10_prod_cr.bin
[   6.6363 ] adding BCH for cboot_t194.bin
[   6.7460 ] adding BCH for cboot_t194.bin
[   6.7655 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   6.7849 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   6.7995 ] adding BCH for tos_t194.img
[   6.8147 ] adding BCH for tos_t194.img
[   6.8287 ] adding BCH for eks.img
[   6.8403 ] adding BCH for eks.img
[   6.8433 ] adding BCH for bpmp_t194.bin
[   6.8481 ] adding BCH for bpmp_t194.bin
[   6.8774 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[   6.9089 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[   6.9287 ] adding BCH for camera-rtcpu-rce.img
[   6.9486 ] adding BCH for camera-rtcpu-rce.img
[   6.9613 ] adding BCH for adsp-fw.bin
[   6.9731 ] adding BCH for adsp-fw.bin
[   6.9804 ] Header already present for warmboot_t194_prod.bin
[   6.9925 ] Header already present for warmboot_t194_prod.bin
[   6.9999 ] adding BCH for boot.img
[   7.0058 ] adding BCH for boot.img
[   7.0086 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   7.0214 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   7.0396 ]
[   7.0398 ] Filling MB1 storage info
[   7.0401 ] Generating br-bct
[   7.0414 ] Performing cfg overlay
[   7.0415 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   7.0424 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg
[   7.1000 ]
[   7.1004 ] Updating dev and MSS params in BR BCT
[   7.1008 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   7.1551 ]
[   7.1553 ] Updating bl info
[   7.1569 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   7.1633 ]
[   7.1635 ] Generating signatures
[   7.1654 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[   7.1672 ] Assuming zero filled SBK key
[   7.2073 ]
[   7.2075 ] Generating br-bct
[   7.2094 ] Performing cfg overlay
[   7.2095 ] ['/storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg']
[   7.2098 ] Updating dev and MSS params in BR BCT
[   7.2104 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   7.2730 ]
[   7.2732 ] Updating bl info
[   7.2746 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   7.2830 ]
[   7.2832 ] Updating smd info
[   7.2847 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   7.2914 ]
[   7.2920 ] Updating Odmdata
[   7.2933 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   7.2992 ]
[   7.2995 ] Get Signed section of bct
[   7.3011 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   7.3073 ]
[   7.3109 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   7.3138 ] Assuming zero filled SBK key
[   7.3240 ]
[   7.3241 ] Updating BCT with signature
[   7.3254 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   7.3311 ]
[   7.3313 ] Generating coldboot mb1-bct
[   7.3329 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   7.3346 ] MB1-BCT version: 0x1
[   7.3373 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   7.3496 ] Added Platform Config 0 data with size :- 3008
[   7.3594 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   7.3666 ] Added Platform Config 1 data with size :- 19640
[   7.3853 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   7.3944 ] Added Platform Config 2 data with size :- 24
[   7.3965 ]
[   7.3971 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[   7.3974 ] File read failed
[   7.3976 ] File read failed
[   7.3983 ] Added Platform Config 4 data with size :- 380
[   7.3984 ]
[   7.3988 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   7.3992 ] Added Platform Config 3 data with size :- 92
[   7.3994 ]
[   7.3996 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   7.3999 ] Added Platform Config 5 data with size :- 56
[   7.4000 ]
[   7.4002 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   7.4004 ] Added Platform Config 7 data with size :- 392
[   7.4007 ]
[   7.4008 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   7.4010 ] Added Platform Config 8 data with size :- 12
[   7.4012 ]
[   7.4014 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   7.4016 ] Added Platform Config 9 data with size :- 32
[   7.4018 ]
[   7.4021 ] Updating mb1-bct with firmware information
[   7.4035 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   7.4051 ] MB1-BCT version: 0x1
[   7.4118 ]
[   7.4120 ] Updating mb1-bct with storage information
[   7.4138 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   7.4156 ] MB1-BCT version: 0x1
[   7.4236 ]
[   7.4248 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[   7.4309 ]
[   7.4323 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   7.4339 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[   7.4451 ]
[   7.4472 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   7.4488 ] Assuming zero filled SBK key
[   7.4554 ]
[   7.4571 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   7.4637 ]
[   7.4641 ] Generating recovery mb1-bct
[   7.4655 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   7.4674 ] MB1-BCT version: 0x1
[   7.4703 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   7.4827 ] Added Platform Config 0 data with size :- 3008
[   7.4951 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   7.5018 ] Added Platform Config 1 data with size :- 19640
[   7.5190 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   7.5249 ] Added Platform Config 2 data with size :- 24
[   7.5251 ]
[   7.5254 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[   7.5256 ] File read failed
[   7.5258 ] File read failed
[   7.5259 ] Added Platform Config 4 data with size :- 380
[   7.5263 ]
[   7.5265 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   7.5267 ] Added Platform Config 3 data with size :- 92
[   7.5269 ]
[   7.5271 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   7.5273 ] Added Platform Config 5 data with size :- 56
[   7.5275 ]
[   7.5276 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   7.5278 ] Added Platform Config 7 data with size :- 392
[   7.5280 ]
[   7.5282 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   7.5284 ] Added Platform Config 8 data with size :- 12
[   7.5286 ]
[   7.5289 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   7.5290 ] Added Platform Config 9 data with size :- 32
[   7.5291 ]
[   7.5295 ] Updating mb1-bct with firmware information
[   7.5308 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   7.5325 ] MB1-BCT version: 0x1
[   7.5392 ]
[   7.5394 ] Updating mb1-bct with storage information
[   7.5410 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   7.5425 ] MB1-BCT version: 0x1
[   7.5512 ]
[   7.5526 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[   7.5594 ]
[   7.5608 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[   7.5624 ] adding BCH for mb1_bct_MB1.bct
[   7.5711 ]
[   7.5729 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   7.5742 ] Assuming zero filled SBK key
[   7.5832 ]
[   7.5852 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   7.5911 ]
[   7.5914 ] Generating coldboot mem-bct
[   7.5926 ] tegrabct_v2 --chip 0x19 0 --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --membct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_1.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_2.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_3.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_4.bct
[   7.5942 ] Packing sdram param for instance[0]
[   7.6481 ] Packing sdram param for instance[1]
[   7.6497 ] Packing sdram param for instance[2]
[   7.6499 ] Packing sdram param for instance[3]
[   7.6501 ] Packing sdram param for instance[4]
[   7.6505 ] Packing sdram param for instance[5]
[   7.6506 ] Packing sdram param for instance[6]
[   7.6508 ] Packing sdram param for instance[7]
[   7.6510 ] Packing sdram param for instance[8]
[   7.6512 ] Packing sdram param for instance[9]
[   7.6513 ] Packing sdram param for instance[10]
[   7.6517 ] Packing sdram param for instance[11]
[   7.6518 ] Packing sdram param for instance[12]
[   7.6521 ] Packing sdram param for instance[13]
[   7.6522 ] Packing sdram param for instance[14]
[   7.6525 ] Packing sdram param for instance[15]
[   7.6527 ]
[   7.6529 ] Getting sector size from pt
[   7.6543 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   7.6593 ]
[   7.6600 ] BlockSize read from layout is 200
[   7.6616 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_1.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_2.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_3.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_4.bct
[   7.6632 ] adding BCH for /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_1.bct
[   7.6734 ]
[   7.6748 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[   7.6832 ]
[   7.6847 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[   7.6862 ] Header already present for mem_coldboot.bct
[   7.6956 ]
[   7.6970 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   7.6986 ] Assuming zero filled SBK key
[   7.7072 ]
[   7.7091 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[   7.7155 ]
[   7.7159 ] Generating recovery mem-bct
[   7.7173 ] tegrabct_v2 --chip 0x19 0 --sdram /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1.cfg --membct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_1.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_2.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_3.bct /storage/Linux_for_Tegra/bootloader/3549/tmpv9BzVg1_4.bct
[   7.7192 ] Packing sdram param for instance[0]
[   7.7723 ] Packing sdram param for instance[1]
[   7.7740 ] Packing sdram param for instance[2]
[   7.7746 ] Packing sdram param for instance[3]
[   7.7747 ] Packing sdram param for instance[4]
[   7.7750 ] Packing sdram param for instance[5]
[   7.7752 ] Packing sdram param for instance[6]
[   7.7754 ] Packing sdram param for instance[7]
[   7.7756 ] Packing sdram param for instance[8]
[   7.7758 ] Packing sdram param for instance[9]
[   7.7759 ] Packing sdram param for instance[10]
[   7.7761 ] Packing sdram param for instance[11]
[   7.7762 ] Packing sdram param for instance[12]
[   7.7765 ] Packing sdram param for instance[13]
[   7.7766 ] Packing sdram param for instance[14]
[   7.7768 ] Packing sdram param for instance[15]
[   7.7770 ]
[   7.7785 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[   7.7875 ]
[   7.7888 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[   7.7905 ] adding BCH for mem_rcm.bct
[   7.7992 ]
[   7.8009 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   7.8024 ] Assuming zero filled SBK key
[   7.8111 ]
[   7.8144 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[   7.8231 ]
[   7.8235 ] Copying signatures
[   7.8248 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   8.0674 ]
[   8.0678 ] Sending BCTs
[   8.0694 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   8.0708 ] Applet version 01.00.0000
[   8.0970 ] Sending bct_bootrom
[   8.0998 ] [................................................] 100%
[   8.1109 ] Sending bct_mb1
[   8.1151 ] [................................................] 100%
[   8.1261 ] Sending bct_mem
[   8.1728 ] [................................................] 100%
[   8.2578 ]
[   8.2581 ] Generating blob
[   8.2596 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[   8.2673 ]
[   8.2689 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[   8.2704 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[   8.2916 ]
[   8.2938 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.2953 ] Assuming zero filled SBK key
[   8.3032 ]
[   8.3048 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   8.3151 ]
[   8.3166 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[   8.3232 ]
[   8.3247 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[   8.3290 ] adding BCH for blob_nvtboot_recovery_t194.bin
[   8.3511 ]
[   8.3527 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.3542 ] Assuming zero filled SBK key
[   8.3632 ]
[   8.3652 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   8.3752 ]
[   8.3766 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[   8.3836 ]
[   8.3848 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[   8.3863 ] Header already present for blob_preboot_c10_prod_cr.bin
[   8.3939 ]
[   8.3958 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.3979 ] Assuming zero filled SBK key
[   8.4075 ]
[   8.4093 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   8.4151 ]
[   8.4167 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[   8.4239 ]
[   8.4253 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[   8.4269 ] Header already present for blob_mce_c10_prod_cr.bin
[   8.4420 ]
[   8.4439 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.4453 ] Assuming zero filled SBK key
[   8.4565 ]
[   8.4586 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   8.4676 ]
[   8.4692 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[   8.4771 ]
[   8.4784 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[   8.4797 ] adding BCH for blob_mts_c10_prod_cr.bin
[   8.5898 ]
[   8.5915 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.5928 ] Assuming zero filled SBK key
[   8.6116 ]
[   8.6135 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   8.6756 ]
[   8.6777 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[   8.6835 ]
[   8.6849 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   8.6867 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[   8.7116 ]
[   8.7139 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   8.7154 ] Assuming zero filled SBK key
[   8.7236 ]
[   8.7252 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   8.7369 ]
[   8.7383 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[   8.7444 ]
[   8.7461 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[   8.7476 ] adding BCH for blob_bpmp_t194.bin
[   8.7810 ]
[   8.7828 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   8.7845 ] Assuming zero filled SBK key
[   8.7951 ]
[   8.7976 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[   8.8202 ]
[   8.8220 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a01.dtb
[   8.8274 ]
[   8.8304 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a01.dtb zerosbk
[   8.8327 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a01.dtb
[   8.8632 ]
[   8.8656 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a01_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   8.8673 ] Assuming zero filled SBK key
[   8.8803 ]
[   8.8823 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a01_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a01_sigheader.dtb.hash zerosbk
[   8.8954 ]
[   8.8981 ] tegrahost_v2 --chip 0x19 --align blob_tos_t194.img
[   8.9037 ]
[   8.9052 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos_t194.img zerosbk
[   8.9071 ] adding BCH for blob_tos_t194.img
[   8.9271 ]
[   8.9291 ] tegrasign_v2 --key None --list blob_tos_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   8.9308 ] Assuming zero filled SBK key
[   8.9397 ]
[   8.9413 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos_t194_sigheader.img.encrypt blob_tos_t194_sigheader.img.hash zerosbk
[   8.9513 ]
[   8.9530 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[   8.9614 ]
[   8.9630 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[   8.9649 ] adding BCH for blob_eks.img
[   8.9711 ]
[   8.9727 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   8.9742 ] Assuming zero filled SBK key
[   8.9831 ]
[   8.9850 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   8.9911 ]
[   8.9926 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[   8.9992 ]
[   9.0007 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[   9.0021 ] adding BCH for blob_spe_t194.bin
[   9.0125 ]
[   9.0143 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   9.0161 ] Assuming zero filled SBK key
[   9.0231 ]
[   9.0249 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[   9.0359 ]
[   9.0377 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   9.0392 ] number of images in blob are 13
[   9.0428 ] blobsize is 6186136
[   9.0450 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 256592
[   9.0589 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 129936
[   9.0741 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 23968
[   9.0871 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 144144
[   9.0953 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3372048
[   9.1060 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 278960
[   9.1152 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 853856
[   9.1153 ] Added binary blob_tegra194-a02-bpmp-p2888-a01_sigheader.dtb.encrypt of size 500544
[   9.1155 ] Added binary blob_tos_t194_sigheader.img.encrypt of size 250880
[   9.1159 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   9.1161 ] Added binary blob_boot.img of size 32
[   9.1165 ] Added binary blob_tegra194-p2888-0001-p2822-0000.dtb of size 274864
[   9.1166 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   9.1169 ]
[   9.1172 ] Sending bootloader and pre-requisite binaries
[   9.1186 ] tegrarcm_v2 --download blob blob.bin
[   9.1202 ] Applet version 01.00.0000
[   9.1449 ] Sending blob
[   9.1471 ] [................................................] 100%
[  10.1131 ]
[  10.1161 ] tegrarcm_v2 --boot recovery
[  10.1179 ] Applet version 01.00.0000
[  10.1511 ]
[  11.1538 ] tegrarcm_v2 --isapplet
[  11.1554 ] USB communication failed.Check if device is in recovery
[  11.1647 ]
[  11.1662 ] tegrarcm_v2 --ismb2
[  11.1679 ] USB communication failed.Check if device is in recovery
[  11.1752 ]
[  11.1764 ] tegradevflash_v2 --iscpubl
[  11.1777 ] Cannot Open USB
[  11.2029 ]
[  12.2061 ] tegrarcm_v2 --isapplet
[  12.2083 ] USB communication failed.Check if device is in recovery
[  12.2165 ]
[  12.2180 ] tegrarcm_v2 --ismb2
[  12.2197 ] USB communication failed.Check if device is in recovery
[  12.2269 ]
[  12.2281 ] tegradevflash_v2 --iscpubl
[  12.2296 ] Cannot Open USB
[  12.2513 ]
[  13.2563 ] tegrarcm_v2 --isapplet
[  13.2587 ] USB communication failed.Check if device is in recovery
[  13.2675 ]
[  13.2693 ] tegrarcm_v2 --ismb2
[  13.2707 ] USB communication failed.Check if device is in recovery
[  13.2912 ]
[  13.2928 ] tegradevflash_v2 --iscpubl
[  13.2943 ] Cannot Open USB
[  13.3155 ]
[  14.3198 ] tegrarcm_v2 --isapplet
[  14.3217 ] USB communication failed.Check if device is in recovery
[  14.3291 ]
[  14.3304 ] tegrarcm_v2 --ismb2
[  14.3319 ] USB communication failed.Check if device is in recovery
[  14.3378 ]
[  14.3392 ] tegradevflash_v2 --iscpubl
[  14.3407 ] Cannot Open USB
[  14.3611 ]
[  15.3649 ] tegrarcm_v2 --isapplet
[  15.3677 ] USB communication failed.Check if device is in recovery
[  15.3770 ]
[  15.3790 ] tegrarcm_v2 --ismb2
[  15.3805 ] USB communication failed.Check if device is in recovery
[  15.3879 ]
[  15.3893 ] tegradevflash_v2 --iscpubl
[  15.3907 ] Cannot Open USB
[  15.4111 ]
[  16.4158 ] tegrarcm_v2 --isapplet
[  16.4191 ] USB communication failed.Check if device is in recovery
[  16.4262 ]
[  16.4277 ] tegrarcm_v2 --ismb2
[  16.4295 ] USB communication failed.Check if device is in recovery
[  16.4512 ]
[  16.4525 ] tegradevflash_v2 --iscpubl
[  16.4539 ] Cannot Open USB
[  16.4806 ]
[  17.4841 ] tegrarcm_v2 --isapplet
[  17.4874 ] USB communication failed.Check if device is in recovery
[  17.4942 ]
[  17.4956 ] tegrarcm_v2 --ismb2
[  17.4969 ] USB communication failed.Check if device is in recovery
[  17.5195 ]
[  17.5209 ] tegradevflash_v2 --iscpubl
[  17.5224 ] Cannot Open USB
[  17.5431 ]
[  18.5457 ] tegrarcm_v2 --isapplet
[  18.5473 ] USB communication failed.Check if device is in recovery
[  18.5556 ]
[  18.5570 ] tegrarcm_v2 --ismb2
[  18.5587 ] USB communication failed.Check if device is in recovery
[  18.5788 ]
[  18.5802 ] tegradevflash_v2 --iscpubl
[  18.5816 ] Cannot Open USB
[  18.6032 ]
[  19.6061 ] tegrarcm_v2 --isapplet
[  19.6078 ] USB communication failed.Check if device is in recovery
[  19.6160 ]
[  19.6180 ] tegrarcm_v2 --ismb2
[  19.6197 ] USB communication failed.Check if device is in recovery
[  19.6270 ]
[  19.6282 ] tegradevflash_v2 --iscpubl
[  19.6295 ] Cannot Open USB
[  19.6512 ]
[  20.6546 ] tegrarcm_v2 --isapplet
[  20.6564 ] USB communication failed.Check if device is in recovery
[  20.6635 ]
[  20.6647 ] tegrarcm_v2 --ismb2
[  20.6662 ] USB communication failed.Check if device is in recovery
[  20.6868 ]
[  20.6884 ] tegradevflash_v2 --iscpubl
[  20.6899 ] Cannot Open USB
[  20.7116 ]
[  21.7151 ] tegrarcm_v2 --isapplet
[  21.7167 ] USB communication failed.Check if device is in recovery
[  21.7242 ]
[  21.7254 ] tegrarcm_v2 --ismb2
[  21.7269 ] USB communication failed.Check if device is in recovery
[  21.7352 ]
[  21.7366 ] tegradevflash_v2 --iscpubl
[  21.7380 ] Cannot Open USB
[  21.7594 ]
[  22.7618 ] tegrarcm_v2 --isapplet
[  22.7640 ] USB communication failed.Check if device is in recovery
[  22.7712 ]
[  22.7726 ] tegrarcm_v2 --ismb2
[  22.7744 ] USB communication failed.Check if device is in recovery
[  22.7950 ]
[  22.7965 ] tegradevflash_v2 --iscpubl
[  22.7982 ] Cannot Open USB
[  22.8166 ]
[  23.8203 ] tegrarcm_v2 --isapplet
[  23.8239 ] USB communication failed.Check if device is in recovery
[  23.8314 ]
[  23.8333 ] tegrarcm_v2 --ismb2
[  23.8347 ] USB communication failed.Check if device is in recovery
[  23.8550 ]
[  23.8563 ] tegradevflash_v2 --iscpubl
[  23.8579 ] Cannot Open USB
[  23.8816 ]
[  24.8848 ] tegrarcm_v2 --isapplet
[  24.8868 ] USB communication failed.Check if device is in recovery
[  24.8994 ]
[  24.9013 ] tegrarcm_v2 --ismb2
[  24.9030 ] USB communication failed.Check if device is in recovery
[  24.9106 ]
[  24.9121 ] tegradevflash_v2 --iscpubl
[  24.9134 ] Cannot Open USB
[  24.9352 ]
[  25.9390 ] tegrarcm_v2 --isapplet
[  25.9406 ] USB communication failed.Check if device is in recovery
[  25.9474 ]
[  25.9489 ] tegrarcm_v2 --ismb2
[  25.9504 ] USB communication failed.Check if device is in recovery
[  25.9700 ]
[  25.9713 ] tegradevflash_v2 --iscpubl
[  25.9734 ] Cannot Open USB
[  25.9951 ]
[  26.9993 ] tegrarcm_v2 --isapplet
[  27.0016 ] USB communication failed.Check if device is in recovery
[  27.0090 ]
[  27.0109 ] tegrarcm_v2 --ismb2
[  27.0123 ] USB communication failed.Check if device is in recovery
[  27.0187 ]
[  27.0201 ] tegradevflash_v2 --iscpubl
[  27.0215 ] Cannot Open USB
[  27.0431 ]
[  28.0462 ] tegrarcm_v2 --isapplet
[  28.0480 ] USB communication failed.Check if device is in recovery
[  28.0568 ]
[  28.0581 ] tegrarcm_v2 --ismb2
[  28.0596 ] USB communication failed.Check if device is in recovery
[  28.0712 ]
[  28.0728 ] tegradevflash_v2 --iscpubl
[  28.0742 ] Cannot Open USB
[  28.0796 ]
[  29.0832 ] tegrarcm_v2 --isapplet
[  29.0849 ] USB communication failed.Check if device is in recovery
[  29.0929 ]
[  29.0942 ] tegrarcm_v2 --ismb2
[  29.0956 ] USB communication failed.Check if device is in recovery
[  29.1040 ]
[  29.1053 ] tegradevflash_v2 --iscpubl
[  29.1066 ] Cannot Open USB
[  29.1282 ]
[  30.1327 ] tegrarcm_v2 --isapplet
[  30.1348 ] USB communication failed.Check if device is in recovery
[  30.1429 ]
[  30.1442 ] tegrarcm_v2 --ismb2
[  30.1455 ] USB communication failed.Check if device is in recovery
[  30.1677 ]
[  30.1693 ] tegradevflash_v2 --iscpubl
[  30.1715 ] Cannot Open USB
[  30.1791 ]
[  31.1824 ] tegrarcm_v2 --isapplet
[  31.1857 ] USB communication failed.Check if device is in recovery
[  31.1929 ]
[  31.1942 ] tegrarcm_v2 --ismb2
[  31.1958 ] USB communication failed.Check if device is in recovery
[  31.2020 ]
[  31.2035 ] tegradevflash_v2 --iscpubl
[  31.2049 ] Cannot Open USB
[  31.2271 ]
[  32.2313 ] tegrarcm_v2 --isapplet
[  32.2419 ] USB communication failed.Check if device is in recovery
[  32.2496 ]
[  32.2510 ] tegrarcm_v2 --ismb2
[  32.2529 ] USB communication failed.Check if device is in recovery
[  32.2612 ]
[  32.2628 ] tegradevflash_v2 --iscpubl
[  32.2643 ] Cannot Open USB
[  32.2713 ]
[  33.2761 ] tegrarcm_v2 --isapplet
[  33.2796 ] USB communication failed.Check if device is in recovery
[  33.2878 ]
[  33.2892 ] tegrarcm_v2 --ismb2
[  33.2907 ] USB communication failed.Check if device is in recovery
[  33.3121 ]
[  33.3136 ] tegradevflash_v2 --iscpubl
[  33.3152 ] Cannot Open USB
[  33.3233 ]
[  34.3280 ] tegrarcm_v2 --isapplet
[  34.3311 ] USB communication failed.Check if device is in recovery
[  34.3428 ]
[  34.3442 ] tegrarcm_v2 --ismb2
[  34.3457 ] USB communication failed.Check if device is in recovery
[  34.3558 ]
[  34.3573 ] tegradevflash_v2 --iscpubl
[  34.3593 ] Cannot Open USB
[  34.3672 ]
[  35.3704 ] tegrarcm_v2 --isapplet
[  35.3739 ] USB communication failed.Check if device is in recovery
[  35.3821 ]
[  35.3836 ] tegrarcm_v2 --ismb2
[  35.3850 ] USB communication failed.Check if device is in recovery
[  35.3928 ]
[  35.3942 ] tegradevflash_v2 --iscpubl
[  35.3956 ] Cannot Open USB
[  35.4036 ]
[  36.4074 ] tegrarcm_v2 --isapplet
[  36.4105 ] USB communication failed.Check if device is in recovery
[  36.4214 ]
[  36.4228 ] tegrarcm_v2 --ismb2
[  36.4242 ] USB communication failed.Check if device is in recovery
[  36.4329 ]
[  36.4351 ] tegradevflash_v2 --iscpubl
[  36.4413 ] Cannot Open USB
[  36.4508 ]
[  37.4532 ] tegrarcm_v2 --isapplet
[  37.4571 ] USB communication failed.Check if device is in recovery
[  37.4647 ]
[  37.4667 ] tegrarcm_v2 --ismb2
[  37.4686 ] USB communication failed.Check if device is in recovery
[  37.4762 ]
[  37.4775 ] tegradevflash_v2 --iscpubl
[  37.4787 ] Cannot Open USB
[  37.4996 ]
[  38.5037 ] tegrarcm_v2 --isapplet
[  38.5060 ] USB communication failed.Check if device is in recovery
[  38.5157 ]
[  38.5172 ] tegrarcm_v2 --ismb2
[  38.5186 ] USB communication failed.Check if device is in recovery
[  38.5312 ]
[  38.5327 ] tegradevflash_v2 --iscpubl
[  38.5342 ] Cannot Open USB
[  38.5431 ]
[  39.5458 ] tegrarcm_v2 --isapplet
[  39.5490 ] USB communication failed.Check if device is in recovery
[  39.5573 ]
[  39.5587 ] tegrarcm_v2 --ismb2
[  39.5602 ] USB communication failed.Check if device is in recovery
[  39.5691 ]
[  39.5704 ] tegradevflash_v2 --iscpubl
[  39.5719 ] Cannot Open USB
[  39.5842 ]
[  40.5882 ] tegrarcm_v2 --isapplet
[  40.5905 ] USB communication failed.Check if device is in recovery
[  40.5992 ]
[  40.6006 ] tegrarcm_v2 --ismb2
[  40.6021 ] USB communication failed.Check if device is in recovery
[  40.6237 ]
[  40.6253 ] tegradevflash_v2 --iscpubl
[  40.6274 ] Cannot Open USB
[  40.6354 ]
[  41.6392 ] tegrarcm_v2 --isapplet
[  41.6420 ] USB communication failed.Check if device is in recovery
[  41.6537 ]
[  41.6557 ] tegrarcm_v2 --ismb2
[  41.6573 ] USB communication failed.Check if device is in recovery
[  41.6675 ]
[  41.6693 ] tegradevflash_v2 --iscpubl
[  41.6715 ] Cannot Open USB
[  41.6794 ]
Error: None of the bootloaders are running on device. Check the UART log.
Serial:
[0666.195] I> Handling oem command 6
[0666.198] E> NV3P_SERVER: Fuse burn is not supported.
[0667.920] I> bct_bootrom image downloaded
[0667.936] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0667.944] I> Temperature = 24500
[0667.947] W> Skipping boost for clk: BPMP_CPU_NIC
[0667.951] W> Skipping boost for clk: BPMP_APB
[0667.955] W> Skipping boost for clk: AXI_CBB
[0667.959] W> Skipping boost for clk: AON_CPU_NIC
[0667.963] W> Skipping boost for clk: CAN1
[0667.967] W> Skipping boost for clk: CAN2
[0667.971] I> Boot-device: eMMC
[0667.974] I> Boot-device: eMMC
[0667.977] I> bct_mb1 image downloaded
[0667.994] I> ECC region[0]: Start:0x0, End:0x0
[0667.999] I> ECC region[1]: Start:0x0, End:0x0
[0668.003] I> ECC region[2]: Start:0x0, End:0x0
[0668.007] I> ECC region[3]: Start:0x0, End:0x0
[0668.011] I> ECC region[4]: Start:0x0, End:0x0
[0668.015] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0668.021] I> Non-ECC region[1]: Start:0x0, End:0x0
[0668.025] I> Non-ECC region[2]: Start:0x0, End:0x0
[0668.030] I> Non-ECC region[3]: Start:0x0, End:0x0
[0668.034] I> Non-ECC region[4]: Start:0x0, End:0x0
[0668.040] E> FAILED: Thermal config
[0668.048] E> FAILED: MEMIO rail config
[0668.067] I> bct_mem image downloaded
[0669.919] I> blob image downloaded
[0669.958] I> Recovery boot mode 0
[0000.084] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.093] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.098] I> Boot-mode: Coldboot
[0000.101] I> Chip revision : A02
[0000.104] I> Bootrom patch version : 15 (correctly patched)
[0000.109] I> ATE fuse revision : 0x200
[0000.113] I> Ram repair fuse : 0x0
[0000.116] I> Ram Code : 0x2
[0000.119] I> rst_source : 0xa
[0000.121] I> rst_level : 0x1
[0000.125] I> Boot-device: eMMC
[0000.140] I> sdmmc DDR50 mode
[0000.144] W> No valid slot number is found in scratch register
[0000.149] W> Return default slot: _a
[0000.153] I> Active Boot chain : 0
[0000.156] I> Boot-device: eMMC
[0000.159] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.166] I> Temperature = 25000
[0000.169] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.173] W> Skipping boost for clk: BPMP_APB
[0000.177] W> Skipping boost for clk: AXI_CBB
[0000.181] W> Skipping boost for clk: AON_CPU_NIC
[0000.185] W> Skipping boost for clk: CAN1
[0000.189] W> Skipping boost for clk: CAN2
[0000.193] I> Boot-device: eMMC
[0000.196] I> Boot-device: eMMC
[0000.205] I> Sdmmc: HS400 mode enabled
[0000.210] I> ECC region[0]: Start:0x0, End:0x0
[0000.214] I> ECC region[1]: Start:0x0, End:0x0
[0000.218] I> ECC region[2]: Start:0x0, End:0x0
[0000.222] I> ECC region[3]: Start:0x0, End:0x0
[0000.226] I> ECC region[4]: Start:0x0, End:0x0
[0000.231] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.236] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.241] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.245] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.250] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.255] E> FAILED: Thermal config
[0000.262] E> FAILED: MEMIO rail config
[0000.281] I> Boot-device: eMMC
[0000.291] I> sdmmc bdev is already initialized
[0000.358] I> MB1 done
main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.366] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-fc4604fb)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.367] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.377] I> Boot-device: eMMC
[0000.380] I> Boot_device: SDMMC_BOOT instance: 3
[0000.386] I> sdmmc-3 params source = boot args
[0000.389] I> sdmmc bdev is already initialized
[0000.393] I> sdmmc-3 params source = boot args
[0000.400] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.407] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.409] W> No valid slot number is found in scratch register
[0000.414] W> Return default slot: _a
[0000.418] I> Active Boot chain : 0
[0000.421] I> parsing oem signed section of bpmp-fw header done
[0000.427] I> bpmp-fw binary init read from storage
[0000.432] I> oem authentication of bpmp-fw header done
[0000.438] I> bpmp-fw binary done read from storage
[0000.441] I> bpmp-fw: Authentication init Done
[0000.445] I> parsing oem signed section of cpubl header done
[0000.451] I> cpubl binary init read from storage
[0000.455] I> bpmp-fw: Authentication Finalize Done
[0000.460] I> oem authentication of cpubl header done
[0000.465] I> cpubl binary done read from storage
[0000.469] I> cpubl: Authentication init Done
[0000.474] I> parsing oem signed section of rce header done
[0000.478] I> rce binary init read from storage
[0000.483] I> Relocating BR-BCT
[0000.486] I> cpubl: Authentication Finalize Done
[0000.490] I> oem authentication of rce header done
[0000.495] I> rce binary done read from storage
[0000.499] I> rce: Authentication init Done
[0000.504] I> parsing oem signed section of ape header done
[0000.508] I> ape binary init read from storage
[0000.513] I> rce: Authentication Finalize Done
[0000.517] I> oem authentication of ape header done
[0000.521] I> ape binary done read from storage
[0000.526] I> ape: Authentication init Done
[0000.531] I> parsing oem signed section of tos header done
[0000.535] I> tos binary init read from storage
[0000.539] I> ape: Authentication Finalize Done
[0000.544] I> oem authentication of tos header done
[0000.548] I> tos binary done read from storage
[0000.553] I> tos: Authentication init Done
[0000.557] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.563] I> bpmp-fw-dtb binary init read from storage
[0000.568] I> tos: Authentication Finalize Done
[0000.573] I> oem authentication of bpmp-fw-dtb header done
[0000.577] I> bpmp-fw-dtb binary done read from storage
[0000.582] I> bpmp-fw-dtb: Authentication init Done
[0000.588] I> parsing oem signed section of cpubl-dtb header done
[0000.593] I> cpubl-dtb binary init read from storage
[0000.597] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.634] I> oem authentication of cpubl-dtb header done
[0000.635] I> cpubl-dtb binary done read from storage
[0000.635] I> cpubl-dtb: Authentication init Done
[0000.637] I> parsing oem signed section of eks header done
[0000.638] I> eks binary init read from storage
[0000.638] I> cpubl-dtb: Authentication Finalize Done
[0000.639] I> oem authentication of eks header done
[0000.643] I> eks binary done read from storage
[0000.647] I> eks: Authentication init Done
[0000.651] I> eks: Authentication Finalize Done
[0000.655] I> EKB detected (length: 0x410) @ VA:0x5270a400
NOTICE:  BL31: v1.3(release):
NOTICE:  BL31: Built : 14:14:17, Mar 26 2020
keystore: 705: Starting
keystore: 753: main: EKB retrieved, size=1012
keystore: 241: decrypt_ekb: bad magic
keystore: 758: main: failed to decrypt EKB (-1). Exiting
exit called, thread 0xffffffffea86b800, name trusty_app_0_b1861eb5-e525-4227
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
  [0001.069] I> Welcome to Cboot
fmon_post initialized
[0001.069] I> Cboot Version: t194-8a9e8a5a
[0001.070] I> CPU-BL Params @ 0xf2820000
[0001.070] I>  0) Base:0x00000000 Size:0x00000000
[0001.071] I>  1) Base:0xf1100000 Size:0x00100000
[0001.076] I>  2) Base:0xf2000000 Size:0x00200000
[0001.080] I>  3) Base:0xf1200000 Size:0x00200000
[0001.085] I>  4) Base:0xf1000000 Size:0x00100000
[0001.089] I>  5) Base:0xf0f00000 Size:0x00100000clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[0001.158] I>  6) Base:0xf3800000 Size:0x00400000
[0001.163] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.167] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.172] I>  9) Base:0xf0d00000 Size:0x00100000emc_debugfs initialized
dvs_debugfs initialized
[0001.181] I> 10) Base:0xf3000000 Size:0x00800000fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.231] I> 11) Base:0x40000000 Size:0x00040000
[0001.236] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.240] I> 13) Base:0x40046000 Size:0x00002000
[0001.245] I> 14) Base:0x40048000 Size:0x00002000
[0001.249] I> 15) Base:0xac000000 Size:0x00004000
[0001.254] I> 16) Base:0x4004a000 Size:0x00002000
[0001.258] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.263] I> 18) Base:0x4004c000 Size:0x00002000
[0001.267] I> 19) Base:0xf2200000 Size:0x00600000
[0001.272] I> 20) Base:0x4004e000 Size:0x00002000
[0001.276] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.281] I> 22) Base:0x00000000 Size:0x00000000
[0001.285] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.289] I> 24) Base:0xf6000000 Size:0x02000000
[0001.294] I> 25) Base:0x40050000 Size:0x00002000
[0001.298] I> 26) Base:0x40040000 Size:0x00006000
[0001.303] I> 27) Base:0xf1800000 Size:0x00400000
[0001.307] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.312] I> 29) Base:0xf1400000 Size:0x00400000
[0001.316] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.321] I> 31) Base:0x00000000 Size:0x00000000
[0001.325] I> 32) Base:0xf8000000 Size:0x08000000
[0001.330] I> 33) Base:0x00000000 Size:0x00000000
[0001.334] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.339] I> 35) Base:0xab000000 Size:0x01000000
[0001.343] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.348] I> 37) Base:0xf2800000 Size:0x00800000
[0001.352] I> 38) Base:0x80000000 Size:0x20000000
[0001.356] I> 39) Base:0xb0000000 Size:0x08000000
[0001.361] I> 40) Base:0x00000000 Size:0x00000000
[0001.365] I> 41) Base:0x00000000 Size:0x00000000
[0001.370] I> 42) Base:0x00000000 Size:0x00000000
[0001.374] I> 43) Base:0x00000000 Size:0x00000000
[0001.379] I> 44) Base:0x00000000 Size:0x00000000
[0001.383] I> 45) Base:0x00000000 Size:0x00000000
[0001.388] GIC-SPI Target CPU: 0
[0001.391] Interrupts Init done
[0001.394] calling constructors
[0001.396] initializing heap
[0001.399] I> Heap: [0xa0690588 ... 0xab000000]
[0001.403] initializing threads
[0001.406] initializing timers
[0001.409] creating bootstrap completion thread
[0001.413] top of bootstrap2()
[0001.416] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.421] initializing platform
[0001.424] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.429] W> device prod register failed
[0001.433] I> Bl_dtb @0xaaf00000
[0001.440] E> "plugin-manager" doesn't exist, creating
[0001.441] E> "ids" doesn't exist, creating
[0001.445] E> "connection" doesn't exist, creating
[0001.449] E> "configs" doesn't exist, creating
[0001.458] I> Find /i2c@3160000's alias i2c0
[0001.458] I> Reading eeprom i2c=0 address=0x50
[0001.487] I> Device at /i2c@3160000:0x50
[0001.488] I> Reading eeprom i2c=0 address=0x56
[0001.512] I> Device at /i2c@3160000:0x56
[0001.514] I> Find /i2c@3180000's alias i2c2
[0001.514] I> Reading eeprom i2c=2 address=0x54
[0001.516] E> I2C: slave not found in slaves.
[0001.516] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.517] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.517] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instan.
[0001.526] E> eeprom: Failed to read I2C slave device
[0001.531] I> Eeprom read failed 0x3526070d
[0001.535] I> Reading eeprom i2c=2 address=0x57
[0001.539] E> I2C: slave not found in slaves.
[0001.543] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.551] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.557] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instan.
[0001.566] E> eeprom: Failed to read I2C slave device
[0001.571] I> Eeprom read failed 0x3526070d
[0001.575] I> Reading eeprom i2c=2 address=0x52
[0001.579] E> I2C: slave not found in slaves.
[0001.583] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.591] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.597] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0001.606] E> eeprom: Failed to read I2C slave device
[0001.611] I> Eeprom read failed 0x3526070d
[0001.616] I> Find /i2c@c240000's alias i2c1
[0001.619] I> Reading eeprom i2c=1 address=0x52
[0001.625] E> I2C: slave not found in slaves.
[0001.627] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.635] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.641] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0001.650] E> eeprom: Retry to read I2C slave device.
[0001.655] E> I2C: slave not found in slaves.
[0001.659] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.667] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.673] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0001.682] E> eeprom: Failed to read I2C slave device
[0001.687] I> Eeprom read failed 0x3526070d
[0001.691] I> Reading eeprom i2c=1 address=0x50
[0001.695] E> I2C: slave not found in slaves.
[0001.699] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.707] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.713] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instan.
[0001.722] E> eeprom: Retry to read I2C slave device.
[0001.727] E> I2C: slave not found in slaves.
[0001.731] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.739] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.745] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instan.
[0001.754] E> eeprom: Failed to read I2C slave device
[0001.759] I> Eeprom read failed 0x3526070d
[0001.763] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.768] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0001.779] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0001.784] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0001.795] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.803] E> "i2c@3160000" doesn't exist, creating
[0001.807] E> "module@0x50" doesn't exist, creating
[0001.812] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0001.819] E> "module@0x56" doesn't exist, creating
[0001.826] I> Adding plugin-manager/cvm
[0001.827] E> "chip-id" doesn't exist, creating
[0001.831] I> Adding plugin-manager/chip-id/A02
[0001.835] I> Plugin-manager override starting
[0001.841] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.851] I> node /plugin-manager/fragement-soft-wdt matches
[0001.862] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.868] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.887] I> Disable plugin-manager status in FDT
[0001.887] I> Plugin-manager override finished successfully
[0001.887] I> gpio framework initialized
[0001.889] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.891] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.892] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.899] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.907] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.913] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.919] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.926] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.934] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.941] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.948] I> fixed regulator driver initialized
[0001.958] I> register 'maxim' power off handle
[0001.959] I> virtual i2c enabled
[0001.959] I> registered 'maxim,max20024' pmic
[0001.963] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.969] I> Boot-device: eMMC
[0001.972] I> Boot_device: SDMMC_BOOT instance: 3
[0001.981] I> sdmmc-3 params source = boot args
[0001.981] I> sdmmc bdev is already initialized
[0001.985] I> sdmmc-3 params source = boot args
[0002.016] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.029] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.038] I> enabling 'vdd-hdmi-5v0' regulator
[0002.042] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.043] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.043] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.047] E> invalid display type
[0002.051] E> invalid display type
[0002.052] E> cannot find any other nvdisp nodes
[0002.053] E> no valid display unit config found in dtb
[0002.054] W> display init failed
[0002.054] I> Load in CBoot Boot Options partition and parse it
[0002.059] E> Cannot read beyond partition boundary for CPUBL-CFG
[0002.065] E> tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.071] W> platform_init: tegrabl_read_cbo failed with error 0xd0d0104
[0002.078] I> Hit any key to stop autoboot:     4       3       2       1
[0004.085] initializing target
[0004.085] calling apps_init()
[0004.086] starting app kernel_boot_app
[0004.105] I> found decompressor handler: lz4-legacy
[0004.106] I> decompressing BMP blob ...
[0004.111] I> Kernel type = Normal
[0004.111] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.118] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.118] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.119] I> ########## SD boot ##########
[0004.119] I> No sdcard
[0004.119] I> -0 params source =
[0004.122] E> Blockdev open: exit error
[0004.126] E> SD boot failed, err: 724238353
[0004.130] I> ########## USB boot ##########
[0004.139] W> No valid slot number is found in scratch register
[0004.139] W> Return default slot: _a
[0004.155] I> USB Firmware Version: 60.06 release
[0004.211] I> regulator of usb2-0 already enabled
[0004.218] I> regulator of usb2-1 already enabled
[0004.225] I> regulator of usb2-2 already enabled
[0004.234] I> enabling 'vdd-5v-sata' regulator
[0005.239] E> failed to initialize xhci controller
[0005.240] E> Error in init of XUSB host driver, err: 79790026
[0005.240] E> Failed to initialize device 5-0
[0005.240] E> USB boot failed, err: 2037973030
[0005.241] I> ########## Fixed storage boot ##########
[0005.241] I> Already published: 00010003
[0005.241] I> Look for boot partition
[0005.245] I> Fallback: assuming 0th partition is boot partition
[0005.251] I> Detect filesystem
[0005.278] I> Loading extlinux.conf ...
[0005.278] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.321] I> L4T boot options
[0005.321] I> [1]: "primary kernel"
[0005.321] I> [2]: "backup kernel"
[0005.322] I> Enter choice:
[0008.323] I> Continuing with default option: 1
[0008.323] I> Loading kernel sig file from rootfs ...
[0008.323] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.342] I> Loading kernel binary from rootfs ...
[0008.342] I> rootfs path: /sdmmc_user/boot/Image
[0008.565] I> Validate kernel ...
[0008.565] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0008.907] I> No kernel-dtb binary path
[0008.908] I> Loading kernel-dtb binary from partition ...
[0008.908] W> No valid slot number is found in scratch register
[0008.908] W> Return default slot: _a
[0008.909] I> A/B: bin_type (38) slot 0
[0008.909] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0008.918] I> Validate kernel-dtb ...
[0008.919] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0008.924] I> Loading ramdisk from rootfs ...
[0008.925] I> rootfs path: /sdmmc_user/boot/initrd
[0009.166] I> Kernel hdr @0xa42b0000
[0009.167] I> Kernel dtb @0x90000000
[0009.167] I> decompressor handler not found
[0009.167] I> Copying kernel image (34191376 bytes) from 0xa42b0000 to 0x80080000 ... [0009.174] I> Doe
[0009.176] I> Updated bpmp info to DTB
[0009.177] I> Ramdisk: Base: 0x92000000; Size: 0x24ccb85
[0009.177] I> Updated initrd info to DTB
[0009.178] W> WARN: Fail to override "console=none" in commandline
[0009.179] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.187] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.194] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.201] W> No valid slot number is found in scratch register
[0009.207] W> Return default slot: _a
[0009.210] I> Active slot suffix:
[0009.213] I> add_boot_slot_suffix: slot_suffix =
[0009.218] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8
[0009.252] I> Updated bootarg info to DTB
[0009.255] W> MAC addr invalid!
[0009.258] E> Failed to get WIFI MAC address
[0009.262] W> MAC addr invalid!
[0009.265] E> Failed to get Bluetooth MAC address
[0009.270] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:e5:8d:78
[0009.276] E> "plugin-manager" doesn't exist, creating
[0009.281] I> Adding /chosen/plugin-manager/cvm
[0009.285] E> "chip-id" doesn't exist, creating
[0009.289] I> Adding /chosen/plugin-manager/chip-id
[0009.294] E> "configs" doesn't exist, creating
[0009.298] I> Adding /chosen/plugin-manager/configs
[0009.303] E> "ids" doesn't exist, creating
[0009.307] I> Adding /chosen/plugin-manager/ids
[0009.311] E> "odm-data" doesn't exist, creating
[0009.315] I> Adding /chosen/plugin-manager/odm-data
[0009.324] E> "memory" doesn't exist, creating
[0009.325] I> [0] START: 0x80000000, END: 0xac000000
[0009.329] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.334] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.338] I> dram_block larger than 80000000
[0009.343] I> [3] START: 0x100000000, END: 0x880000000
[0009.347] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.353] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.359] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.366] I> Updated memory info to DTB
[0009.369] E> add_disp_param: failed to get display params for du=0
[0009.375] E> "reset" doesn't exist, creating
[0009.380] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.384] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0009.388] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.393] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0009.398] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.403] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0009.408] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.412] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0009.417] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.422] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0009.427] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.432] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0009.436] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.441] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0009.446] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.451] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0009.457] E> "misc-data" doesn't exist, creating
[0009.460] I> Boot-device: eMMC
[0009.463] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.468] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.474] W> Unknown storage device
[0009.477] I> Add serial number:1420720030541 as DT property
[0009.484] I> Plugin-manager override starting
[0009.487] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.494] I> node /plugin-manager/fragement-soft-wdt matches
[0009.501] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.506] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.516] I> Disable plugin-manager status in FDT
[0009.517] I> Plugin-manager override finished successfully
[0009.520] I> tegrabl_load_kernel_and_dtb: Done
[0009.524] E> tegrabl_display_clear: display is not initialized
[0009.529] W> Boot logo display failed...
[0009.533] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-1935) (gcc version 7.3.1 20180425 [l9
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x00000B
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x00000B
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x00000B
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x00000B
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc7ffc51000 s61592 r8192 d32616 u102400
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8194032
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,110
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29064(88%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Memory: 31893160K/33296384K available (15230K kernel code, 2926K rwdata, 6620K rodata, )
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f60000   ( 15232 KB)
[    0.000000]     .rodata : 0xffffff8008f60000 - 0xffffff80095e0000   (  6656 KB)
[    0.000000]       .init : 0xffffff80095e0000 - 0xffffff8009e40000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e40000 - 0xffffff800a11b808   (  2927 KB)
[    0.000000]        .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf20000000   (   512 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc800000000   ( 32768 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idles
[    0.000009] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.009031] Console: colour dummy device 80x25
[    0.015145] console [tty0] enabled
[    0.015607] kmemleak: Kernel memory leak detector disabled
[    0.021202] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMI)
[    0.031523] pid_max: default: 32768 minimum: 301
[    0.037365] Security Framework initialized
[    0.040764] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.047005] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.057219] ftrace: allocating 47001 entries in 184 pages
[    0.536907] sched-energy: Sched-energy-costs installed from DT
[    0.537478] ASID allocator initialised with 65536 entries
[    0.581832] tegra-id: chipid=21917.
[    0.581952] tegra-id: opt_subrevision=0.
[    0.582070] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.582250] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/..i
[    0.582658] DTB Build time: Dec  9 2019 22:55:56
[    0.633631] CPU1: Booted secondary processor [4e0f0040]
[    0.665963] CPU2: Booted secondary processor [4e0f0040]
[    0.698206] CPU3: Booted secondary processor [4e0f0040]
[    0.730790] CPU4: Booted secondary processor [4e0f0040]
[    0.763051] CPU5: Booted secondary processor [4e0f0040]
[    0.795298] CPU6: Booted secondary processor [4e0f0040]
[    0.827612] CPU7: Booted secondary processor [4e0f0040]
[    0.828267] Brought up 8 CPUs
[    0.829518] SMP: Total of 8 processors activated.
[    0.829657] CPU features: detected feature: Privileged Access Never
[    0.829817] CPU features: detected feature: LSE atomic instructions
[    0.829976] CPU features: detected feature: User Access Override
[    0.830127] CPU features: detected feature: 32-bit EL0 Support
[    0.833116] CPU: All CPU(s) started at EL2
[    0.833348] alternatives: patching kernel code
[    0.845644] devtmpfs: initialized
[    0.933297] Initilizing CustomIPI irq domain
[    0.933909] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417851s
[    0.934182] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.954516] pinctrl core: initialized pinctrl subsystem
[    0.955134] OS set in device tree is not L4T.
[    0.955693] regulator-dummy: no parameters
[    0.956171] Initializing plugin-manager
[    0.956372] Plugin module not found
[    0.956577] Plugin-manager status disabled
[    0.958484] NET: Registered protocol family 16
[    0.961263] pstore: using zlib compression
[    0.962768] console [pstore-1] enabled
[    0.962897] pstore: Registered ramoops as persistent store backend
[    0.963061] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[    0.983921] cpuidle: using governor menu
[    0.985474] bpmp: waiting for handshake
[    0.985647] bpmp: handshake completed
[    0.985769] bpmp: synchronizing channels
[    0.985886] bpmp: channels synchronized
[    0.986005] bpmp: mail init ok
[    0.990087] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.990530] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.990787] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.990930] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.991091] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.991253] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.991412] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.991642] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped re!
[    0.991983] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.998307] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    1.005558] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    1.017500] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[    1.020104] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    1.029777] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    1.036520] Registering BPMP clocks...
[    1.039026] tegra_bpmp_clk_init: clock init ok (400 clks)
[    1.045183] tegra_powergate_init: DONE
[    1.048274] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/..i
[    1.067220] DTB Build time: Dec  9 2019 22:55:56
[    1.075998] Tegra reboot handler registered.
[    1.086400] iommu: Adding device 14180000.pcie to group 0
[    1.087537] iommu: Adding device 14100000.pcie to group 1
[    1.088617] iommu: Adding device 14140000.pcie to group 2
[    1.093249] iommu: Adding device 141a0000.pcie to group 3
[    1.099773] iommu: Adding device 2490000.ether_qos to group 4
[    1.104323] iommu: Adding device 3100000.serial to group 5
[    1.109564] iommu: Adding device 3110000.serial to group 6
[    1.114859] iommu: Adding device 3140000.serial to group 7
[    1.120424] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.127129] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    1.132658] tegra-pmc: ### PMC reset source: TEGRA_VFSENSOR
[    1.138365] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    1.144496] tegra-pmc: ### PMC reset status reg: 0x29
[    1.149744] tegra-pmc: PMC Prod config success
[    1.154368] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    1.161327] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    1.167510] iommu: Adding device 3460000.sdhci to group 8
[    1.173635] iommu: Adding device 3400000.sdhci to group 9
[    1.178868] iommu: Adding device 2450000.ufshci to group 10
[    1.184566] iommu: Adding device 3210000.spi to group 11
[    1.190106] iommu: Adding device c260000.spi to group 12
[    1.196299] iommu: Adding device 3160000.i2c to group 13
[    1.200945] iommu: Adding device c240000.i2c to group 14
[    1.206510] iommu: Adding device 3180000.i2c to group 15
[    1.211899] iommu: Adding device 3190000.i2c to group 16
[    1.217434] iommu: Adding device 31b0000.i2c to group 17
[    1.222761] iommu: Adding device 31c0000.i2c to group 18
[    1.228211] iommu: Adding device c250000.i2c to group 19
[    1.233535] iommu: Adding device 31e0000.i2c to group 20
[    1.239887] iommu: Adding device sound to group 21
[    1.243977] iommu: Adding device 3510000.hda to group 22
[    1.249594] iommu: Adding device bc00000.rtcpu to group 23
[    1.256940] iommu: Adding device 13e10000.host1x to group 24
[    1.260458] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[    1.266590] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[    1.272545] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[    1.278447] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[    1.284632] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[    1.290714] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[    1.297062] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[    1.303205] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[    1.309372] iommu: Adding device 15340000.vic to group 33
[    1.314400] iommu: Adding device 15380000.nvjpg to group 34
[    1.319855] iommu: Adding device 15500000.tsec to group 35
[    1.325456] iommu: Adding device 15100000.tsecb to group 36
[    1.331275] iommu: Adding device 15480000.nvdec to group 37
[    1.336652] iommu: Adding device 15140000.nvdec1 to group 38
[    1.342548] iommu: Adding device 154c0000.nvenc to group 39
[    1.347767] iommu: Adding device 15a80000.nvenc1 to group 40
[    1.353972] iommu: Adding device 15880000.nvdla0 to group 41
[    1.359449] iommu: Adding device 158c0000.nvdla1 to group 42
[    1.365242] iommu: Adding device 15200000.nvdisplay to group 43
[    1.375384] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    1.377889] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    1.385375] iommu: Adding device 15210000.nvdisplay to group 44
[    1.390602] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    1.397515] iommu: Adding device 15220000.nvdisplay to group 45
[    1.403101] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[    1.412835] iommu: Adding device 15c10000.vi to group 46
[    1.415142] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    1.421468] iommu: Adding device 14800000.isp to group 47
[    1.427987] iommu: Adding device 16000000.pva0 to group 48
[    1.432832] iommu: Adding device 16800000.pva1 to group 49
[    1.437994] iommu: Adding device 15810000.se to group 50
[    1.443516] iommu: Adding device 15820000.se to group 51
[    1.448843] iommu: Adding device 15830000.se to group 52
[    1.454190] iommu: Adding device 15840000.se to group 53
[    1.459347] iommu: Adding device c1a0000.aon to group 54
[    1.466785] iommu: Adding device d000000.bpmp to group 55
[    1.470366] bpmp: ping status is 0
[    1.473401] bpmp d000000.bpmp: firmware tag is c1b4e372932429f2737cf722e1219e71
[    1.484976] bpmp d000000.bpmp: probe ok
[    1.486899] tegra-reset 0.bpmp_reset: registered 186 resets.
[    1.490418] iommu: Adding device smmu_test to group 56
[    1.496790] mc: mapped MMIO address: 0xffffff800a580000 -> 0x2c10000
[    1.501803] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c20000
[    1.508080] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c30000
[    1.514532] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c40000
[    1.520659] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[    1.527050] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2b80000
[    1.533464] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b90000
[    1.540164] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2ba0000
[    1.546739] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2bb0000
[    1.552941] mc: mapped MMIO address: 0xffffff800b070000 -> 0x1700000
[    1.559685] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1710000
[    1.566169] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1720000
[    1.572540] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1730000
[    1.578664] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1740000
[    1.585043] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1750000
[    1.591443] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1760000
[    1.597828] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1770000
[    1.604583] mc-err: mcerr ops are set to t19x
[    1.616867] iommu: Adding device 2600000.dma to group 57
[    1.624366] GPIO line 490 (pcie-reg-enable) hogged as output/high
[    1.624557] GPIO line 289 (pcie-reg-enable) hogged as output/high
[    1.626403] GPIO line 339 (wifi-enable) hogged as output/high
[    1.632246] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    1.650131] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    1.650667] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    1.658237] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    1.661199] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    1.668976] iommu: Adding device 3550000.xudc to group 58
[    1.674453] iommu: Adding device 3610000.xhci to group 59
[    1.681951] arm64_ras arm64_ras: probed
[    1.683034] ras_fhi_enable: FHI 477 enabled on CPU0
[    1.687573] ras_fhi_enable: FHI 478 enabled on CPU1
[    1.692261] ras_fhi_enable: FHI 479 enabled on CPU2
[    1.697337] ras_fhi_enable: FHI 480 enabled on CPU3
[    1.702300] ras_fhi_enable: FHI 481 enabled on CPU4
[    1.707041] ras_fhi_enable: FHI 482 enabled on CPU5
[    1.712185] ras_fhi_enable: FHI 483 enabled on CPU6
[    1.716951] ras_fhi_enable: FHI 484 enabled on CPU7
[    1.722109] carmel_ras_enable: RAS enabled on cpu0
[    1.727303] carmel_ras_enable: RAS enabled on cpu1
[    1.731921] carmel_ras_enable: RAS enabled on cpu2
[    1.737185] carmel_ras_enable: RAS enabled on cpu3
[    1.742172] carmel_ras_enable: RAS enabled on cpu4
[    1.747030] carmel_ras_enable: RAS enabled on cpu5
[    1.751655] carmel_ras_enable: RAS enabled on cpu6
[    1.756523] carmel_ras_enable: RAS enabled on cpu7
[    1.761243] carmel_ras carmel_ras: probed
[    1.766869] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[    1.773801] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[    1.782173] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[    1.790127] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[    1.797634] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[    1.804555] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    1.814587] vdd-3v3-cvb: 3300 mV
[    1.815178] vdd-1v8-cvb: 1800 mV
[    1.817825] vdd-1v8-sd: 1800 mV
[    1.821527] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    1.825384] vdd-epb-1v0: 1000 mV
[    1.829011] vdd-sdmmc1-sw: 3300 mV
[    1.832571] avdd-cam-2v8: 2800 mV
[    1.836186] vdd-sata-1v5: 1500 mV
[    1.839326] vdd-1v8-slt: 1800 mV
[    1.842697] vdd-3v3-slt: 3300 mV
[    1.846194] vdd-fan: 5000 mV
[    1.849418] vdd-hdmi-5v0: 5000 mV
[    1.853103] vdd_sys_en: 1200 mV
[    1.856156] vdd-5v-sata: 5000 mV
[    1.859570] vdd-ac-bat: 5000 mV
[    1.862589] vdd-5v-sata: supplied by vdd-ac-bat
[    1.900272] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.905719] eventlib_kernel: keventlib is initialized, test id: 0
[    1.906256] SCSI subsystem initialized
[    1.907014] usbcore: registered new interface driver usbfs
[    1.907217] usbcore: registered new interface driver hub
[    1.907532] usbcore: registered new device driver usb
[    1.922965] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0,e
( I don’t think it was supposed to boot )
I ran directly:
root@ubuntu:/storage/Linux_for_Tegra# ./odmfuse.sh -j -i 0x19 -c PKC -k /storage/keys/pkc.pem -S /storage/keys/sbk.txt --KEK2 /storage/keys/kek2.txt jetson-xavier
copying soft_fuses(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0070 ] Generating RCM messages
[   0.0084 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0098 ] Header already present for /storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0222 ]
[   0.0240 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0255 ] Assuming zero filled SBK key
[   0.0346 ]
[   0.0366 ] tegrasign_v2 --key None --file /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0383 ] Assuming zero filled SBK key
[   0.0504 ]
[   0.0519 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0622 ]
[   0.0638 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0702 ]
[   0.0718 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /storage/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0734 ] RCM 0 is saved as rcm_0.rcm
[   0.0808 ] RCM 1 is saved as rcm_1.rcm
[   0.0842 ] RCM 2 is saved as rcm_2.rcm
[   0.0881 ] List of rcm files are saved in rcm_list.xml
[   0.0882 ]
[   0.0886 ] Signing RCM messages
[   0.0898 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0915 ] Assuming zero filled SBK key
[   0.0983 ]
[   0.0985 ] Copying signature to RCM mesages
[   0.0999 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1064 ]
[   0.1066 ] Boot Rom communication
[   0.1083 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.1099 ] RCM version 0X190001
[   0.1140 ] Boot Rom communication completed
[   1.1415 ]
[   2.1455 ] tegrarcm_v2 --isapplet
[   2.1490 ] Applet version 01.00.0000
[   2.1742 ]
[   2.1756 ] tegrarcm_v2 --ismb2
[   2.2054 ]
[   2.2074 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2142 ]
[   2.2155 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2168 ] adding BCH for nvtboot_applet_t194.bin
[   2.2304 ]
[   2.2320 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2332 ] Assuming zero filled SBK key
[   2.2422 ]
[   2.2446 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2542 ]
[   2.2556 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2571 ] Applet version 01.00.0000
[   2.2812 ] Sending mb2
[   2.2826 ] [................................................] 100%
[   2.3102 ]
[   2.3117 ] tegrarcm_v2 --boot recovery
[   2.3132 ] Applet version 01.00.0000
[   2.3502 ]
[   3.3546 ] tegrarcm_v2 --isapplet
[   3.3862 ]
[   3.3877 ] tegrarcm_v2 --ismb2
[   3.3892 ] MB2 Applet version 01.00.0000
[   3.4183 ]
[   3.4198 ] tegrarcm_v2 --ismb2
[   3.4214 ] MB2 Applet version 01.00.0000
[   3.4503 ]
[   3.4520 ] Retrieving EEPROM data
[   3.4524 ] tegrarcm_v2 --oem platformdetails eeprom cvm /storage/Linux_for_Tegra/bootloader/cvm.bin
[   3.4550 ] MB2 Applet version 01.00.0000
[   3.4860 ] Saved platform info in /storage/Linux_for_Tegra/bootloader/cvm.bin
[   3.5360 ]
[   3.5364 ] Rebooting to recovery mode
[   3.5378 ] tegrarcm_v2 --ismb2
[   3.5395 ] MB2 Applet version 01.00.0000
[   3.5653 ]
[   3.5655 ] Rebooting to recovery mode
[   3.5669 ] tegrarcm_v2 --reboot recovery
[   3.5683 ] MB2 Applet version 01.00.0000
[   3.6106 ]
Board ID(2888) version(400) sku(0004) revision(K.0)
copying sdram_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying sdram_config1(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying misc_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying scr_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying pmc_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying pmic_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying br_cmd_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying prod_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying misc_cold_boot_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying device_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying uphy_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying gpioint_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
Existing mb2_bootloader(/storage/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/storage/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/storage/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/storage/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/storage/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Existing bpmp_fw(/storage/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpmp_fw_dtb(/storage/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing tlk(/storage/Linux_for_Tegra/bootloader/tos_t194.img) reused.
Existing eks(/storage/Linux_for_Tegra/bootloader/eks.img) reused.
Existing spe_fw(/storage/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing mb1file(/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/storage/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing tegraboot(/storage/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/storage/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
Existing scefile(/storage/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/storage/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing wb0boot(/storage/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/storage/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing bl(/storage/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing applet(/storage/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
*** Calculating HASH from keyfile /storage/keys/pkc.pem ... done
PKC HASH: 0x69d2fba5a24026824e63dacf591eb721c03749381229b81f4bb8691619cd0088
*** Generating fuse configuration ... done.
done.
*** Start fusing  ...
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; tlk tos_t194.img; eks eks.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --bl nvtboot_recovery_cpu_t194.bin --odmdata 0x9190000 --chip 0x19 --applet mb1_t194_prod.bin  --cmd "burnfuses odmfuse_pkc.xml" --skipuid
version 1.0.0
[   0.0137 ] Burning fuses
[   0.0138 ] Generating RCM messages
[   0.0152 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0166 ] Header already present for mb1_t194_prod.bin
[   0.0329 ]
[   0.0344 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0358 ] Assuming zero filled SBK key
[   0.0456 ]
[   0.0472 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0486 ] Assuming zero filled SBK key
[   0.0577 ]
[   0.0594 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0699 ]
[   0.0718 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0791 ]
[   0.0804 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0818 ] RCM 0 is saved as rcm_0.rcm
[   0.0898 ] RCM 1 is saved as rcm_1.rcm
[   0.0938 ] RCM 2 is saved as rcm_2.rcm
[   0.0941 ] List of rcm files are saved in rcm_list.xml
[   0.0943 ]
[   0.0945 ] Signing RCM messages
[   0.0959 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0975 ] Assuming zero filled SBK key
[   0.1057 ]
[   0.1060 ] Copying signature to RCM mesages
[   0.1077 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1136 ]
[   0.1138 ] Boot Rom communication
[   0.1154 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.1170 ] Boot Rom communication failed
[   5.1500 ]
Error: Return value 3
Command tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
failed.
Serial:
[0074.254] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0074.263] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0074.268] I> Boot-mode: Platform RCM
[0074.272] I> Chip revision : A02
[0074.275] I> Bootrom patch version : 15 (correctly patched)
[0074.280] I> ATE fuse revision : 0x200
[0074.283] I> Ram repair fuse : 0x0
[0074.286] I> Ram Code : 0x2
[0074.289] I> rst_source : 0xb
[0074.292] I> rst_level : 0x1
[0074.295] I> USB configuration success
[0076.415] I> mb2 image downloaded
[0076.458] I> Recovery boot mode 0
[0076.462] I> Boot-device: eMMC
[0076.467] I> UPHY full init done
[0076.471] I> MB1 done
[0076.476] W> Profiler not initialized
[0076.480] I> Welcome to MB2(TBoot-BPMP) Applet (version: 00.00.2018.32-mobile-2cd5f333)
[0076.488] W> Profiler not initialized
[0076.491] I> DMA Heap @ [0x40020000 - 0x40065800]
[0076.496] I> Default Heap @ [0xd486400 - 0xd48a400]
[0076.501] W> Profiler not initialized
[0076.504] W> Profiler not initialized
[0076.508] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0076.513] W> device prod register failed
[0076.517] W> Profiler not initialized
[0076.541] I> sdmmc DDR50 mode
[0076.545] I> No supported QSPI flash found
[0076.549] E> QSPI Flash: Insufficient flash size (0 MB)
[0076.554] I> QSPI Flash is not present.
[0076.606] E> Link startup dme_set failed
[0076.609] E> UFS initialization failed
[0076.613] I> UFS is not present
[0076.616] W> Profiler not initialized
[0076.624] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0076.632] I> Found 42 partitions in SDMMC_USER (instance 3)
[0076.638] W> Profiler not initialized
[0076.641] W> Profiler not initialized
[0076.645] W> Profiler not initialized
[0076.648] I> Entering 3p server
[0076.651] I> USB configuration success
[0077.606] I> Populate eeprom info
[0077.612] I> Populate eeprom info for module cvm
[0077.718] I> Rebooting : reboot-recovery
Could you check if Xavier is in recovery mode? Looks like the device is not found.
Yes, was definately in recovery mode, that’s the strange thing, during flashing it attempts to boot after a few seconds, thats why you get those usb communication errors.
Please run sudo tegrafuse.sh to share the status. Probably the fuse is done?
root@xavier:~# /tmp/tegrafuse.sh
odm_lock : 0x00000000
arm_jtag_disable : 0x00000000
odm_production_mode : 0x00000000
boot_security_info : 0x00000000
odm_info : 0x00000000
root@xavier:~#
I’ll try to record my screen to show what’s going on…
Screen recording - https://www.dropbox.com/s/oe4dl5zsg4cdid7/Screen%20Recording%202020-03-31%20at%2011.03.23.mov?dl=0
Step 2 is not right. Please run with out the steps.
For information, when you run sudo ./odmfuse.sh --no-burn, do you see board information being printed? Or it is empty like:
Board ID() version() sku() revision()
it’s empty, just ran again:
root@ubuntu:/storage/Linux_for_Tegra# ./odmfuse.sh --noburn -j -i 0x19 -c PKC -k /storage/keys/pkc.pem -
copying pmic_config(/storage/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg)... done.
copying bpmp_fw_dtb(/storage/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a01.dtb)... done.
done.
done.
*** Start preparing fuse configuration ...
*** done.
I prefixed the environment variables mentioned later in the guide for ./flash.sh and it seemed to work:
root@ubuntu:/storage/Linux_for_Tegra# BOARDID=2888 FAB=400 BOARDSKU=0001 BOARDREV=H.0 ./odmfuse.sh --nob
urn -j -i 0x19 -c PKC -k /storage/keys/pkc.pem -S /storage/keys/sbk.txt --KEK2 /storage/keys/kek2.txt je
tson-xavier
Board ID(2888) version(400) sku(0001) revision(H.0)
done.
done.
*** done.
root@ubuntu:/storage/Linux_for_Tegra# tar xf fuseblob.tbz2
root@ubuntu:/storage/Linux_for_Tegra# cd bootloader/
root@ubuntu:/storage/Linux_for_Tegra/bootloader# ./fusecmd.sh
version 1.0.0
[   0.0152 ] Burning fuses
[   0.0153 ] Generating RCM messages
[   0.0172 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0186 ] Header already present for mb1_t194_prod.bin
[   0.0342 ]
[   0.0357 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0372 ] Assuming zero filled SBK key
[   0.0466 ]
[   0.0483 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0498 ] Assuming zero filled SBK key
[   0.0581 ]
[   0.0703 ]
[   0.0723 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0781 ]
[   0.0795 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0810 ] RCM 0 is saved as rcm_0.rcm
[   0.0885 ] RCM 1 is saved as rcm_1.rcm
[   0.0914 ] RCM 2 is saved as rcm_2.rcm
[   0.0950 ] List of rcm files are saved in rcm_list.xml
[   0.0952 ]
[   0.0954 ] Signing RCM messages
[   0.0968 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0981 ] Assuming zero filled SBK key
[   0.1137 ]
[   0.1139 ] Copying signature to RCM mesages
[   0.1155 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1241 ]
[   0.1244 ] Boot Rom communication
[   0.1259 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.1276 ] BR_CID: 0x880219116459e587100000000fff0240
[   0.1344 ] RCM version 0X190001
[   0.1544 ] Boot Rom communication completed
[   1.1791 ]
[   2.1824 ] tegrarcm_v2 --isapplet
[   2.1863 ] Applet version 01.00.0000
[   2.2186 ]
[   2.2216 ] Parsing fuse info as per xml file
[   2.2234 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[   2.2252 ] MagicId=0x45535546 version=0x1
[   2.2295 ] node: name=SecureBootKey size=16
[   2.2346 ]   value=0x20e3f97f4c3678081fea84963298fb61
[   2.2360 ] node: name=Kek2 size=16
[   2.2364 ]   value=0x60ca57edf25f2fbf14e9f79c4dcad332
[   2.2369 ] node: name=PublicKeyHash size=32
[   2.2371 ]   value=0x8800cd191669b84b1fb82912384937c021b71e59cfda634e822640a2a5fbd269
[   2.2374 ] node: name=BootSecurityInfo size=4
[   2.2378 ]   value=0x5
[   2.2384 ]
[   2.2402 ] tegrarcm_v2 --oem burnfuses blow_fuse_data.bin
[   2.2423 ] Applet version 01.00.0000
[   2.2692 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported.
[   2.2870 ]
[   2.2873 ] Fuse burning failed
[   2.2874 ]
[   2.2879 ] trying fusing with CPU binary
[   2.2904 ] tegrasign_v2 --key None --getmode mode.txt
[   2.2918 ] Assuming zero filled SBK key
[   2.2981 ]
[   2.2984 ] Parsing partition layout
[   2.2997 ] tegraparser_v2 --pt flash.xml.tmp
[   2.3061 ]
[   2.3063 ] Creating list of images to be signed
[   2.3078 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   2.3091 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.3150 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.3225 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.3364 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.3469 ] adding BCH for spe_t194.bin
[   2.3501 ] adding BCH for spe_t194.bin
[   2.3557 ] adding BCH for nvtboot_t194.bin
[   2.3620 ] adding BCH for nvtboot_t194.bin
[   2.3727 ] Header already present for preboot_c10_prod_cr.bin
[   2.3840 ] Header already present for preboot_c10_prod_cr.bin
[   2.3959 ] Header already present for mce_c10_prod_cr.bin
[   2.4050 ] Header already present for mce_c10_prod_cr.bin
[   2.4144 ] adding BCH for mts_c10_prod_cr.bin
[   2.4189 ] adding BCH for mts_c10_prod_cr.bin
[   2.5204 ] adding BCH for cboot_t194.bin
[   2.6261 ] adding BCH for cboot_t194.bin
[   2.6447 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.6705 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.6854 ] adding BCH for tos_t194.img
[   2.6984 ] adding BCH for tos_t194.img
[   2.7091 ] adding BCH for eks.img
[   2.7195 ] adding BCH for eks.img
[   2.7225 ] adding BCH for bpmp_t194.bin
[   2.7309 ] adding BCH for bpmp_t194.bin
[   2.7564 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.7875 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.8086 ] adding BCH for camera-rtcpu-rce.img
[   2.8288 ] adding BCH for camera-rtcpu-rce.img
[   2.8412 ] adding BCH for adsp-fw.bin
[   2.8527 ] adding BCH for adsp-fw.bin
[   2.8592 ] Header already present for warmboot_t194_prod.bin
[   2.8693 ] Header already present for warmboot_t194_prod.bin
[   2.8783 ] adding BCH for boot.img
[   2.8840 ] adding BCH for boot.img
[   2.8872 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.9005 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.9196 ]
[   2.9197 ] Filling MB1 storage info
[   2.9201 ] Generating br-bct
[   2.9216 ] Performing cfg overlay
[   2.9217 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   2.9227 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg
[   2.9652 ]
[   2.9657 ] Updating dev and MSS params in BR BCT
[   2.9662 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.0262 ]
[   3.0264 ] Updating bl info
[   3.0280 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   3.0413 ]
[   3.0414 ] Generating signatures
[   3.0431 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[   3.0446 ] Assuming zero filled SBK key
[   3.0821 ]
[   3.0827 ] Generating br-bct
[   3.0850 ] Performing cfg overlay
[   3.0853 ] ['/storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg']
[   3.0856 ] Updating dev and MSS params in BR BCT
[   3.0861 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.1423 ]
[   3.1425 ] Updating bl info
[   3.1441 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   3.1545 ]
[   3.1548 ] Updating smd info
[   3.1563 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   3.1621 ]
[   3.1623 ] Updating Odmdata
[   3.1635 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   3.1701 ]
[   3.1702 ] Get Signed section of bct
[   3.1718 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   3.1783 ]
[   3.1814 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   3.1833 ] Assuming zero filled SBK key
[   3.1901 ]
[   3.1903 ] Updating BCT with signature
[   3.1916 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   3.1967 ]
[   3.1968 ] Generating coldboot mb1-bct
[   3.1984 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.2001 ] MB1-BCT version: 0x1
[   3.2045 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.2230 ] Added Platform Config 0 data with size :- 3008
[   3.2289 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.2401 ] Added Platform Config 1 data with size :- 19640
[   3.2571 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.2571 ] Added Platform Config 2 data with size :- 24
[   3.2573 ]
[   3.2575 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.2576 ] Added Platform Config 4 data with size :- 348
[   3.2578 ]
[   3.2579 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.2584 ] Added Platform Config 3 data with size :- 92
[   3.2585 ]
[   3.2588 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.2589 ] Added Platform Config 5 data with size :- 56
[   3.2591 ]
[   3.2593 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.2594 ] Added Platform Config 7 data with size :- 392
[   3.2596 ]
[   3.2598 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.2600 ] Added Platform Config 8 data with size :- 12
[   3.2602 ]
[   3.2604 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.2606 ] Added Platform Config 9 data with size :- 32
[   3.2608 ]
[   3.2612 ] Updating mb1-bct with firmware information
[   3.2627 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.2642 ] MB1-BCT version: 0x1
[   3.2706 ]
[   3.2709 ] Updating mb1-bct with storage information
[   3.2724 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.2743 ] MB1-BCT version: 0x1
[   3.2824 ]
[   3.2844 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[   3.2923 ]
[   3.2938 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   3.2955 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[   3.3061 ]
[   3.3079 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.3099 ] Assuming zero filled SBK key
[   3.3181 ]
[   3.3201 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   3.3266 ]
[   3.3269 ] Generating recovery mb1-bct
[   3.3283 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.3299 ] MB1-BCT version: 0x1
[   3.3327 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.3434 ] Added Platform Config 0 data with size :- 3008
[   3.3511 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.3610 ] Added Platform Config 1 data with size :- 19640
[   3.3823 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.3921 ] Added Platform Config 2 data with size :- 24
[   3.3926 ]
[   3.3930 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.3932 ] Added Platform Config 4 data with size :- 348
[   3.3934 ]
[   3.3935 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.3936 ] Added Platform Config 3 data with size :- 92
[   3.3937 ]
[   3.3938 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.3938 ] Added Platform Config 5 data with size :- 56
[   3.3938 ]
[   3.3939 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.3939 ] Added Platform Config 7 data with size :- 392
[   3.3939 ]
[   3.3940 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.3940 ] Added Platform Config 8 data with size :- 12
[   3.3941 ]
[   3.3941 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.3942 ] Added Platform Config 9 data with size :- 32
[   3.3943 ]
[   3.3947 ] Updating mb1-bct with firmware information
[   3.3961 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.3976 ] MB1-BCT version: 0x1
[   3.4066 ]
[   3.4067 ] Updating mb1-bct with storage information
[   3.4086 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.4103 ] MB1-BCT version: 0x1
[   3.4181 ]
[   3.4200 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[   3.4262 ]
[   3.4276 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[   3.4289 ] adding BCH for mb1_bct_MB1.bct
[   3.4386 ]
[   3.4403 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.4418 ] Assuming zero filled SBK key
[   3.4498 ]
[   3.4520 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   3.4586 ]
[   3.4589 ] Generating coldboot mem-bct
[   3.4602 ] tegrabct_v2 --chip 0x19 0 --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --membct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_1.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_2.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_3.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_4.bct
[   3.4618 ] Packing sdram param for instance[0]
[   3.5164 ] Packing sdram param for instance[1]
[   3.5178 ] Packing sdram param for instance[2]
[   3.5182 ] Packing sdram param for instance[3]
[   3.5184 ] Packing sdram param for instance[4]
[   3.5187 ] Packing sdram param for instance[5]
[   3.5188 ] Packing sdram param for instance[6]
[   3.5191 ] Packing sdram param for instance[7]
[   3.5193 ] Packing sdram param for instance[8]
[   3.5194 ] Packing sdram param for instance[9]
[   3.5196 ] Packing sdram param for instance[10]
[   3.5198 ] Packing sdram param for instance[11]
[   3.5199 ] Packing sdram param for instance[12]
[   3.5201 ] Packing sdram param for instance[13]
[   3.5203 ] Packing sdram param for instance[14]
[   3.5205 ] Packing sdram param for instance[15]
[   3.5208 ]
[   3.5210 ] Getting sector size from pt
[   3.5225 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   3.5350 ]
[   3.5353 ] BlockSize read from layout is 200
[   3.5369 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_1.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_2.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_3.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_4.bct
[   3.5386 ] adding BCH for /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_1.bct
[   3.5498 ]
[   3.5518 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[   3.5596 ]
[   3.5609 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[   3.5623 ] Header already present for mem_coldboot.bct
[   3.5689 ]
[   3.5708 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.5722 ] Assuming zero filled SBK key
[   3.5819 ]
[   3.5843 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[   3.5933 ]
[   3.5937 ] Generating recovery mem-bct
[   3.5950 ] tegrabct_v2 --chip 0x19 0 --sdram /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1.cfg --membct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_1.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_2.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_3.bct /storage/Linux_for_Tegra/bootloader/9253/tmpeR6sAw1_4.bct
[   3.5966 ] Packing sdram param for instance[0]
[   3.6488 ] Packing sdram param for instance[1]
[   3.6557 ] Packing sdram param for instance[2]
[   3.6561 ] Packing sdram param for instance[3]
[   3.6563 ] Packing sdram param for instance[4]
[   3.6567 ] Packing sdram param for instance[5]
[   3.6569 ] Packing sdram param for instance[6]
[   3.6572 ] Packing sdram param for instance[7]
[   3.6577 ] Packing sdram param for instance[8]
[   3.6580 ] Packing sdram param for instance[9]
[   3.6582 ] Packing sdram param for instance[10]
[   3.6584 ] Packing sdram param for instance[11]
[   3.6586 ] Packing sdram param for instance[12]
[   3.6588 ] Packing sdram param for instance[13]
[   3.6590 ] Packing sdram param for instance[14]
[   3.6592 ] Packing sdram param for instance[15]
[   3.6594 ]
[   3.6613 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[   3.6665 ]
[   3.6683 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[   3.6699 ] adding BCH for mem_rcm.bct
[   3.6781 ]
[   3.6800 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.6815 ] Assuming zero filled SBK key
[   3.6928 ]
[   3.6950 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[   3.7026 ]
[   3.7030 ] Copying signatures
[   3.7045 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   3.9365 ]
[   3.9368 ] Sending BCTs
[   3.9383 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   3.9398 ] Applet version 01.00.0000
[   3.9645 ] Sending bct_bootrom
[   3.9671 ] [................................................] 100%
[   3.9805 ] Sending bct_mb1
[   3.9841 ] [................................................] 100%
[   3.9964 ] Sending bct_mem
[   4.0413 ] [................................................] 100%
[   4.1277 ]
[   4.1281 ] Generating blob
[   4.1296 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[   4.1382 ]
[   4.1396 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[   4.1411 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[   4.1586 ]
[   4.1606 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.1623 ] Assuming zero filled SBK key
[   4.1749 ]
[   4.1767 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   4.1911 ]
[   4.1929 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[   4.1987 ]
[   4.2005 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[   4.2021 ] adding BCH for blob_nvtboot_recovery_t194.bin
[   4.2199 ]
[   4.2220 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2235 ] Assuming zero filled SBK key
[   4.2302 ]
[   4.2338 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   4.2466 ]
[   4.2481 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[   4.2544 ]
[   4.2559 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[   4.2572 ] Header already present for blob_preboot_c10_prod_cr.bin
[   4.2645 ]
[   4.2664 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2683 ] Assuming zero filled SBK key
[   4.2814 ]
[   4.2831 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   4.2938 ]
[   4.2955 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[   4.3023 ]
[   4.3040 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[   4.3056 ] Header already present for blob_mce_c10_prod_cr.bin
[   4.3182 ]
[   4.3202 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.3219 ] Assuming zero filled SBK key
[   4.3301 ]
[   4.3322 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   4.3421 ]
[   4.3436 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[   4.3501 ]
[   4.3516 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[   4.3530 ] adding BCH for blob_mts_c10_prod_cr.bin
[   4.4577 ]
[   4.4594 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.4608 ] Assuming zero filled SBK key
[   4.4742 ]
[   4.4763 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   4.5343 ]
[   4.5370 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[   4.5422 ]
[   4.5443 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   4.5460 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[   4.5702 ]
[   4.5722 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.5736 ] Assuming zero filled SBK key
[   4.5828 ]
[   4.5848 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   4.5943 ]
[   4.5962 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[   4.6027 ]
[   4.6043 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[   4.6058 ] adding BCH for blob_bpmp_t194.bin
[   4.6391 ]
[   4.6409 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.6424 ] Assuming zero filled SBK key
[   4.6506 ]
[   4.6524 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[   4.6742 ]
[   4.6765 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[   4.6821 ]
[   4.6838 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   4.6857 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[   4.7181 ]
[   4.7205 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.7220 ] Assuming zero filled SBK key
[   4.7343 ]
[   4.7410 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   4.7582 ]
[   4.7601 ] tegrahost_v2 --chip 0x19 --align blob_tos_t194.img
[   4.7655 ]
[   4.7674 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos_t194.img zerosbk
[   4.7693 ] adding BCH for blob_tos_t194.img
[   4.7861 ]
[   4.7877 ] tegrasign_v2 --key None --list blob_tos_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.7891 ] Assuming zero filled SBK key
[   4.7982 ]
[   4.8010 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos_t194_sigheader.img.encrypt blob_tos_t194_sigheader.img.hash zerosbk
[   4.8103 ]
[   4.8119 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[   4.8185 ]
[   4.8201 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[   4.8216 ] adding BCH for blob_eks.img
[   4.8306 ]
[   4.8328 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.8349 ] Assuming zero filled SBK key
[   4.8425 ]
[   4.8444 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   4.8506 ]
[   4.8524 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[   4.8602 ]
[   4.8619 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[   4.8642 ] adding BCH for blob_spe_t194.bin
[   4.8786 ]
[   4.8805 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.8820 ] Assuming zero filled SBK key
[   4.8902 ]
[   4.8926 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[   4.9022 ]
[   4.9041 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   4.9057 ] number of images in blob are 13
[   4.9098 ] blobsize is 6186264
[   4.9121 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 256592
[   4.9283 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 129936
[   4.9410 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 23968
[   4.9486 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 144144
[   4.9489 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3372048
[   4.9491 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 278960
[   4.9492 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 853856
[   4.9494 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 500672
[   4.9496 ] Added binary blob_tos_t194_sigheader.img.encrypt of size 250880
[   4.9499 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   4.9500 ] Added binary blob_boot.img of size 32
[   4.9503 ] Added binary blob_tegra194-p2888-0001-p2822-0000.dtb of size 274864
[   4.9507 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   4.9509 ]
[   4.9513 ] Sending bootloader and pre-requisite binaries
[   4.9528 ] tegrarcm_v2 --download blob blob.bin
[   4.9545 ] Applet version 01.00.0000
[   4.9800 ] Sending blob
[   4.9814 ] [................................................] 100%
[   5.9515 ]
[   5.9529 ] tegrarcm_v2 --boot recovery
[   5.9547 ] Applet version 01.00.0000
[   5.9904 ]
[   6.9931 ] tegrarcm_v2 --isapplet
[   7.4814 ]
[   7.4834 ] tegrarcm_v2 --ismb2
[   7.5141 ]
[   7.5156 ] tegradevflash_v2 --iscpubl
[   7.5175 ] Bootloader version 01.00.0000
[   7.5280 ] Bootloader version 01.00.0000
[   7.5376 ]
[   7.5380 ] tegradevflash_v2 --oem burnfuses blow_fuse_data.bin
[   7.5394 ] Bootloader version 01.00.0000
[   7.5492 ] Fusing burning successful
[   7.7018 ]
[   7.7036 ] tegradevflash_v2 --reboot recovery
[   7.7053 ] Bootloader version 01.00.0000
Serial:
[1381.050] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[1381.058] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[1381.064] I> Boot-mode: RCM
[1381.066] I> Chip revision : A02
[1381.069] I> Bootrom patch version : 15 (correctly patched)
[1381.074] I> ATE fuse revision : 0x200
[1381.078] I> Ram repair fuse : 0x0
[1381.081] I> Ram Code : 0x2
[1381.084] I> rst_source : 0x0
[1381.086] I> rst_level : 0x0
[1381.090] I> USB configuration success
[1383.143] I> Handling oem command 6
[1383.147] E> NV3P_SERVER: Fuse burn is not supported.
[1384.845] I> bct_bootrom image downloaded
[1384.860] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[1384.868] I> Temperature = 36000
[1384.871] W> Skipping boost for clk: BPMP_CPU_NIC
[1384.875] W> Skipping boost for clk: BPMP_APB
[1384.879] W> Skipping boost for clk: AXI_CBB
[1384.883] W> Skipping boost for clk: AON_CPU_NIC
[1384.888] W> Skipping boost for clk: CAN1
[1384.891] W> Skipping boost for clk: CAN2
[1384.896] I> Boot-device: eMMC
[1384.898] I> Boot-device: eMMC
[1384.901] I> bct_mb1 image downloaded
[1384.920] I> ECC region[0]: Start:0x0, End:0x0
[1384.925] I> ECC region[1]: Start:0x0, End:0x0
[1384.929] I> ECC region[2]: Start:0x0, End:0x0
[1384.933] I> ECC region[3]: Start:0x0, End:0x0
[1384.937] I> ECC region[4]: Start:0x0, End:0x0
[1384.941] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[1384.947] I> Non-ECC region[1]: Start:0x0, End:0x0
[1384.951] I> Non-ECC region[2]: Start:0x0, End:0x0
[1384.956] I> Non-ECC region[3]: Start:0x0, End:0x0
[1384.960] I> Non-ECC region[4]: Start:0x0, End:0x0
[1384.967] E> FAILED: Thermal config
[1384.974] E> FAILED: MEMIO rail config
[1384.993] I> bct_mem image downloaded
[1386.812] I> blob image downloaded
[1386.854] I> Recovery boot mode 0
[1386.918] I> MB1 done
main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [1386.928] I> Welcome to MB2(TBoot-BPMP) Recovery (version: 00.00.2018.32-mobile-fdcb35a7)
[1386.929] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[1386.930] I> Default Heap @ [0xd486400 - 0xd48a400]
[1386.931] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[1386.937] W> device prod register failed
[1386.941] I> parsing oem signed section of bpmp-fw header done
[1386.949] I> bpmp-fw binary copied from blob
[1386.951] I> oem authentication of bpmp-fw header done
[1386.955] I> bpmp-fw: Authentication init Done
[1386.960] I> parsing oem signed section of cpubl header done
[1386.966] I> cpubl binary copied from blob
[1386.969] I> bpmp-fw: Authentication Finalize Done
[1386.974] I> oem authentication of cpubl header done
[1386.979] I> cpubl: Authentication init Done
[1386.983] I> parsing oem signed section of tos header done
[1386.989] I> tos binary copied from blob
[1386.992] I> Relocating BR-BCT
[1386.995] I> cpubl: Authentication Finalize Done
[1386.999] I> oem authentication of tos header done
[1387.004] I> tos: Authentication init Done
[1387.008] I> parsing oem signed section of bpmp-fw-dtb header done
[1387.015] I> bpmp-fw-dtb binary copied from blob
[1387.018] I> tos: Authentication Finalize Done
[1387.024] I> oem authentication of bpmp-fw-dtb header done
[1387.028] I> bpmp-fw-dtb: Authentication init Done
[1387.033] I> parsing oem signed section of cpubl-dtb header done
[1387.039] I> cpubl-dtb binary copied from blob
[1387.043] I> bpmp-fw-dtb: Authentication Finalize Done
[1387.183] I> oem authentication of cpubl-dtb header done
[1387.184] I> cpubl-dtb: Authentication init Done
[1387.184] I> parsing oem signed section of eks header done
[1387.185] I> eks binary copied from blob
[1387.186] I> cpubl-dtb: Authentication Finalize Done
[1387.186] I> oem authentication of eks header done
[1387.187] I> eks: Authentication init Done
[1387.190] I> eks: Authentication Finalize Done
[1387.195] I> EKB detected (length: 0x410) @ VA:0x526fb600
NOTICE:  BL31: v1.3(release):
NOTICE:  BL31: Built : 14:14:17, Mar 26 2020
keystore: 705: Starting
keystore: 753: main: EKB retrieved, size=1024
keystore: 241: decrypt_ekb: bad magic
keystore: 758: main: failed to decrypt EKB (-1). Exiting
exit called, thread 0xffffffffea86b800, name trusty_app_0_b1861eb5-e525-4227
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy initialized
safereg initialized
  mrq initialized
[1387.604] I> Welcome to TBoot-CPU Recovery
fmon_post initialized
[1387.604] I> Heap: [0xa4000000 ... 0xaa000000
[1387.607] I> gpio framework initialized
[1387.619] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
clk_dt_late initialized
machine_check initialized
[1387.626] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[1387.631] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
emc_debugfs initialized
[1387.704] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539dvs_debugf   d
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] [1387.715] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[1387.764] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[1387.770] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[1387.781] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[1387.788] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[1387.792] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[1387.801] I> fixed regulator driver initialized
[1387.822] I> CPU: Nvidia Carmel
[1387.822] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[1387.822] I> chip revision : A02
[1387.823] I> Boot-device: eMMC
[1387.823] I> Boot_device: SDMMC_BOOT instance: 3
[1388.297] I> sdmmc-3 params source = boot args
[1388.298] I> sdmmc bdev is already initialized
[1388.298] I> sdmmc-3 params source = boot args
[1388.325] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[1388.337] I> Found 42 partitions in SDMMC_USER (instance 3)
[1388.338] I> Recovery boot_type: 0
[1388.338] I> Entering 3p server
[1388.338] I> USB configuration success
[1388.425] I> Generic fusing path
[1388.426] I> Fuse Blob found
[1388.426] I> Burning fuses
[1388.433] E> FUSE: Invalid value fuse_word:0.
[1388.438] E> FUSE: Invalid value fuse_word:0.
[1388.452] E> FUSE: Invalid value fuse_word:0.
[1388.456] I> fuse read is 7ff9e320
[1388.457] I> Fuse (43) burnt successfully with val 0x7ff9e320
[1388.457] I> fuse : SecureBootKey burnt successfully
[1388.460] E> FUSE: Invalid value fuse_word:0.
[1388.474] E> FUSE: Invalid value fuse_word:0.
[1388.492] I> fuse read is ed57ca60
[1388.492] I> Fuse (41) burnt successfully with val 0xed57ca60
[1388.493] I> fuse : Kek2 burnt successfully
[1388.500] E> FUSE: Invalid value fuse_word:0.
[1388.505] E> FUSE: Invalid value fuse_word:0.
[1388.509] E> FUSE: Invalid value fuse_word:0.
[1388.524] E> FUSE: Invalid value fuse_word:0.
[1388.529] E> FUSE: Invalid value fuse_word:0.
[1388.543] E> FUSE: Invalid value fuse_word:0.
[1388.547] I> fuse read is 19cd0088
[1388.547] I> Fuse (42) burnt successfully with val 0x19cd0088
[1388.548] I> fuse : PublicKeyHash burnt successfully
[1388.555] E> FUSE: Invalid value fuse_word:0.
[1388.559] I> fuse read is 5
[1388.559] I> Fuse (0) burnt successfully with val 0x00000005
[1388.560] I> fuse : BootSecurityInfo burnt successfully
[1388.560] I> Fuse Blob found
[1388.560] I> Successfully Burnt Fuses as per fuse info
[1388.561] I> Burning fuses successful
[1388.590] I> Rebooting : reboot-recovery
Shutdown state requested 1
Rebooting system ...
it was stuck in in ‘Rebooting…’ for a few mins so powered off and on again, but now I can’t get it to boot, and there’s no serial output :(
attempting to flash again with BOARDID=2888 FAB=400 BOARDSKU=0001 BOARDREV=H.0 ./flash.sh -u /sto rage/keys/pkc.pem -v /storage/keys/sbk.txt jetson-xavier mmcblk0p1
managed to flash successfully and there was serial output, it also attempted to restart and hung, after a few mins powered off and on but still no serial output and can not ssh on.
