I am trying to create a Linked list in Cuda Fortran, but when I am trying to call a device function from the kernel, I am getting a compilation error. Could someone please explain to me why …?
file :p5.f95
MODULE ListModule
IMPLICIT NONE
TYPE ListElem
REAL :: value;
TYPE(ListElem), POINTER :: next;
END TYPE ListElem
CONTAINS
ATTRIBUTES(DEVICE) FUNCTION InsertList(head, elem)
IMPLICIT NONE
type( ListElem ), pointer :: head, elem
type( ListElem ), pointer :: InsertList
elem%next => head
InsertList => elem
END FUNCTION InsertList
END MODULE
MODULE Test
CONTAINS
ATTRIBUTES(GLOBAL) SUBROUTINE KERNEL()
USE ListModule
IMPLICIT NONE
type( ListElem ), pointer :: newElem, h
integer :: i,N = 4
INTEGER(KIND=4),ALLOCATABLE::ND(:)
nullify( head )
allocate( newElem )
newElem%value=1
PRINT*,newElem%value
head => InsertList(head, newElem)
END SUBROUTINE
END MODULE Test
PROGRAM LinkedList
USE TEST
USE CUDAFOR
integer :: N
CALL KERNEL<<<1,1>>>()
N=cudaDeviceSynchronize()
END PROGRAM LinkedList
compilation command:pgf95 -cuda -gpu=rdc p5.f95
Error:
nvvmCompileProgram error 9: NVVM_ERROR_COMPILATION.
Error: /tmp/pgcudaforNnQ1wgcS2LZ.gpu (27, 26): parse use of undefined value '%sym_insertlist_p_356'
ptxas /tmp/pgcudaforxnQf5cb9zEu.ptx, line 1; fatal : Missing .version directive at start of file '/tmp/pgcudaforxnQf5cb9zEu.ptx'
ptxas fatal : Ptx assembly aborted due to errors
NVFORTRAN-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (p5.f95: 1)
NVFORTRAN/x86-64 Linux 21.7-0: compilation aborted
