Unable to capture data packets using Wireshark from mellanox card
I am using 40Gb Mellanox card. Capturing the data packets with DPDK.
Using testpmd+pdump successfully captured the pkts from 40Gb.
However replicate the same using Wireshark+testpmd, am not able to capture the data packets. Msg displayed is NO PACKETS from the mellanox interface.
Do I need to use any specific settings to use this combination ?
Working on
Ubuntu 18
DPDK 19
Wireshark 3
Mellnox mlx5 40G capacity
Katie
To capture packets with DPDK, you have to use a special tool and not wireshark that capture packets going through the standard IP stack only
Please see the following link:
https://doc.dpdk.org/guides/howto/packet_capture_framework.html
In addition, there’s some wireshark forum that asked for support of dpdk device capturing and this is the link:
https://ask.wireshark.org/question/6559/capturing-on-dpdk-interface/
Marc
