I’m trying to compile Caffe, when I ran the cmake command … in Caffe’s build directory, it even introduced me that it could not detect the GPU.
After that, I ran the make -j “$ (nproc)” command and got the following error:
nvcc fatal: Unsupported gpu architecture ‘compute_20’
I’ve encountered other errors too, when I squeeze the nvidia-smi command it returns me the following:
Failed to initialize NVML: Driver / library version mismatch
I have 8 Nvidia Tesla V100 32Gb cards, I also looked at the nvidia-persistenced and what turned me on was the following:
Mar 18 13:48:00 ubuntu nvidia-persistenced [5838]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/ dev / nvidia *) exist, and that user has read and write permissions for those files. ( I have already checked the permissions of the files and apparently it is OK. )
Mar 18 13:48:00 ubuntu nvidia-persistenced [5838]: PID file unlocked.
Mar 18 13:48:00 ubuntu nvidia-persistenced [5837]: nvidia-persistenced failed to initialize. Check syslog for more details.
Mar 18 13:48:00 ubuntu kernel: NVRM: API mismatch: the client has the version 418.43, but
NVRM: this kernel module has version 418.39. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
My operating system is:
Ubuntu 16.04.06
Cuda 10.1
Could someone give me a hand?
cc 2.0 isn’t supported anymore since cuda 9. Change your makefile to use at least cc 3.0 or the cc of your gpus:
compute_20->compute_30
You installed driver 418.39 over 418.43 or the other way round, probably using the .deb package for one and the .run installer for the other. Leads to a broken system. Ubuntu install instructions:
Don’t use the .run installers, use --uninstall to uninstall them
purge anthing nvidia/cuda
add the ubuntu graphics staging ppa [url]https://launchpad.net/~mamarley/+archive/ubuntu/staging[/url]
install the driver from that (sudo apt install nvidia-418)
download the cuda .deb
add the repo to your system (first three steps from install instructions on download page)
don’t install cuda
instead, run sudo apt install cuda-toolkit-10-1
Normally, one would not use the staging ppa but the normal ppa https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
but this currently does not have the needed 418 driver for Ubuntu 16.04 needed for cuda 10.1.
add the ubuntu graphics staging ppa https://launchpad.net/~mamarley/+archive/ubuntu/staging
don’t install cuda
Normally, one would not use the staging ppa but the normal ppa Proprietary GPU Drivers : “Graphics Drivers” team
Can you help me to change my makefile?
Open “Makefile” in a text editor, search&replace, search: compute_20, replace with: compute_30, replace all, save.
Not much to it.
For Caffe, it’s even easier. It has a Makefile.config where you set the compute options with an explanation what to comment out:
https://github.com/BVLC/caffe/blob/master/Makefile.config.example
CUDA architecture setting: going with all of them.
For CUDA < 6.0, comment the *_50 through *_61 lines for compatibility.
For CUDA < 8.0, comment the *_60 and *_61 lines for compatibility.
For CUDA >= 9.0, comment the *_20 and *_21 lines for compatibility.
OK, I will do this and when I finish giving you feedback, thank you.
Not much to it.
In my Makefile there was no such option, only in the Makefile that is as an example and even changing in it still appears …
Could you tell me where this Makefile is?
Read my follow up post, you have to comment out the lines in “Makefile.config”.
As you asked, I made these settings, circled the commands again and the return was:
root@ubuntu:/softwares_nvidia/caffe/build# make -j"$(nproc)"
[ 1%] Running C++/Python protocol buffer compiler on /softwares_nvidia/caffe/src/caffe/proto/caffe.proto
Scanning dependencies of target proto
[ 1%] Building CXX object src/caffe/CMakeFiles/proto.dir// /include/caffe/proto/caffe.pb.cc.o
[ 1%] Linking CXX static library …/…/lib/libproto.a
[ 1%] Built target proto
[ 1%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/util/cuda_compile_1_generated_math_functions.cu.o
[ 1%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/cuda_compile_1_generated_data_transformer.cu.o
[ 1%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_absval_layer.cu.o
[ 2%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_base_data_layer.cu.o
[ 2%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_batch_norm_layer.cu.o
[ 2%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_batch_reindex_layer.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_bias_layer.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_bnll_layer.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_concat_layer.cu.o
[ 5%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_contrastive_loss_layer.cu.o
[ 5%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_conv_layer.cu.o
[ 6%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_crop_layer.cu.o
[ 6%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_batch_norm_layer.cu.o
[ 6%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_conv_layer.cu.o
[ 8%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_lcn_layer.cu.o
[ 8%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_lrn_layer.cu.o
[ 8%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_pooling_layer.cu.o
[ 9%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_relu_layer.cu.o
[ 9%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_sigmoid_layer.cu.o
[ 9%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_softmax_layer.cu.o
[ 10%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_cudnn_tanh_layer.cu.o
[ 10%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_deconv_layer.cu.o
[ 12%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_detectnet_transform_layer.cu.o
[ 12%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_dropout_layer.cu.o
[ 12%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_eltwise_layer.cu.o
[ 12%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_embed_layer.cu.o
[ 13%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_elu_layer.cu.o
[ 13%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_euclidean_loss_layer.cu.o
[ 15%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_filter_layer.cu.o
[ 15%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_exp_layer.cu.o
[ 16%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_inner_product_layer.cu.o
[ 16%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_hdf5_data_layer.cu.o
[ 17%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_hdf5_output_layer.cu.o
[ 17%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_lrn_layer.cu.o
[ 17%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_log_layer.cu.o
[ 19%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_mvn_layer.cu.o
[ 19%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_im2col_layer.cu.o
[ 19%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_pooling_layer.cu.o
[ 19%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_power_layer.cu.o
[ 20%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_relu_layer.cu.o
[ 21%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_reduction_layer.cu.o
[ 21%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_prelu_layer.cu.o
[ 21%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_scale_layer.cu.o
[ 21%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_sigmoid_cross_entropy_loss_layer.cu.o
[ 23%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_sigmoid_layer.cu.o
[ 23%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_silence_layer.cu.o
[ 23%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_slice_layer.cu.o
[ 24%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_softmax_layer.cu.o
[ 24%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_split_layer.cu.o
[ 26%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_tanh_layer.cu.o
[ 26%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_threshold_layer.cu.o
[ 26%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_softmax_loss_layer.cu.o
[ 26%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_adadelta_solver.cu.o
[ 27%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/layers/cuda_compile_1_generated_tile_layer.cu.o
[ 27%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_adagrad_solver.cu.o
[ 28%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_adam_solver.cu.o
[ 28%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_rmsprop_solver.cu.o
[ 28%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_nesterov_solver.cu.o
[ 30%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/solvers/cuda_compile_1_generated_sgd_solver.cu.o
[ 30%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile_1.dir/util/cuda_compile_1_generated_im2col.cu.o
In file included from /softwares_nvidia/caffe/src/caffe/util/math_functions.cu:1:0:
/usr/local/cuda/include/math_functions.h:54:2: warning: warning “math_functions.h is an internal header file and must not be used directly. This file will be removed in a future CUDA release. Please use cuda_runtime_api.h or cuda_runtime.h instead.” [-Wcpp]
Scanning dependencies of target caffe
[ 31%] Building CXX object src/caffe/CMakeFiles/caffe.dir/blob.cpp.o
[ 31%] Building CXX object src/caffe/CMakeFiles/caffe.dir/common.cpp.o
[ 32%] Building CXX object src/caffe/CMakeFiles/caffe.dir/data_reader.cpp.o
[ 32%] Building CXX object src/caffe/CMakeFiles/caffe.dir/data_transformer.cpp.o
[ 32%] Building CXX object src/caffe/CMakeFiles/caffe.dir/internal_thread.cpp.o
[ 34%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layer.cpp.o
[ 34%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layer_factory.cpp.o
[ 34%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/absval_layer.cpp.o
[ 35%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/accuracy_layer.cpp.o
[ 35%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/argmax_layer.cpp.o
[ 36%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/base_conv_layer.cpp.o
[ 36%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/base_data_layer.cpp.o
[ 36%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/batch_norm_layer.cpp.o
[ 38%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/batch_reindex_layer.cpp.o
[ 38%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/bias_layer.cpp.o
[ 39%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/concat_layer.cpp.o
[ 39%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/bnll_layer.cpp.o
[ 39%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/conv_layer.cpp.o
[ 41%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/crop_layer.cpp.o
[ 41%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/contrastive_loss_layer.cpp.o
[ 41%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_lrn_layer.cpp.o
[ 42%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_conv_layer.cpp.o
[ 42%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_batch_norm_layer.cpp.o
[ 42%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_lcn_layer.cpp.o
[ 43%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_pooling_layer.cpp.o
[ 43%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_relu_layer.cpp.o
[ 43%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_sigmoid_layer.cpp.o
[ 43%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_tanh_layer.cpp.o
[ 45%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_softmax_layer.cpp.o
[ 45%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/data_layer.cpp.o
[ 46%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/detectnet_transform_layer.cpp.o
[ 46%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/deconv_layer.cpp.o
[ 47%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/dropout_layer.cpp.o
[ 47%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/eltwise_layer.cpp.o
[ 47%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/dummy_data_layer.cpp.o
[ 47%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/euclidean_loss_layer.cpp.o
[ 49%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/elu_layer.cpp.o
[ 50%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/exp_layer.cpp.o
[ 50%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/embed_layer.cpp.o
[ 50%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/filter_layer.cpp.o
[ 50%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/flatten_layer.cpp.o
[ 52%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/hdf5_data_layer.cpp.o
[ 52%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/hdf5_output_layer.cpp.o
[ 53%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/hinge_loss_layer.cpp.o
[ 53%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/image_data_layer.cpp.o
[ 53%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/im2col_layer.cpp.o
[ 54%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/infogain_loss_layer.cpp.o
[ 54%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/inner_product_layer.cpp.o
[ 56%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/l1_loss_layer.cpp.o
[ 56%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/input_layer.cpp.o
[ 56%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/log_layer.cpp.o
[ 56%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/lrn_layer.cpp.o
[ 57%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/loss_layer.cpp.o
[ 57%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/memory_data_layer.cpp.o
[ 58%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/multinomial_logistic_loss_layer.cpp.o
[ 58%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/mvn_layer.cpp.o
[ 60%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/pooling_layer.cpp.o
[ 60%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/neuron_layer.cpp.o
[ 60%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/power_layer.cpp.o
[ 60%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/prelu_layer.cpp.o
[ 61%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/relu_layer.cpp.o
[ 61%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/reduction_layer.cpp.o
[ 61%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/scale_layer.cpp.o
[ 63%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/reshape_layer.cpp.o
[ 63%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/sigmoid_cross_entropy_loss_layer.cpp.o
[ 64%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/sigmoid_layer.cpp.o
[ 64%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/silence_layer.cpp.o
[ 64%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/slice_layer.cpp.o
[ 65%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/softmax_layer.cpp.o
[ 65%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/softmax_loss_layer.cpp.o
[ 65%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/split_layer.cpp.o
[ 67%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/spp_layer.cpp.o
[ 67%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/tanh_layer.cpp.o
[ 68%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/threshold_layer.cpp.o
[ 68%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/tile_layer.cpp.o
[ 68%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solver.cpp.o
[ 69%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/window_data_layer.cpp.o
[ 69%] Building CXX object src/caffe/CMakeFiles/caffe.dir/parallel.cpp.o
[ 69%] Building CXX object src/caffe/CMakeFiles/caffe.dir/net.cpp.o
[ 71%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/adadelta_solver.cpp.o
[ 71%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/adagrad_solver.cpp.o
[ 72%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/adam_solver.cpp.o
[ 72%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/rmsprop_solver.cpp.o
[ 72%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/nesterov_solver.cpp.o
[ 73%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/sgd_solver.cpp.o
[ 73%] Building CXX object src/caffe/CMakeFiles/caffe.dir/syncedmem.cpp.o
[ 73%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/benchmark.cpp.o
[ 75%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/blocking_queue.cpp.o
[ 75%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/cudnn.cpp.o
[ 75%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/db.cpp.o
[ 76%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/db_leveldb.cpp.o
[ 76%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/db_lmdb.cpp.o
[ 78%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/detectnet_coverage_rectangular.cpp.o
[ 78%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/gpu_memory.cpp.o
[ 78%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/hdf5.cpp.o
[ 79%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/im2col.cpp.o
[ 79%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/insert_splits.cpp.o
[ 79%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/io.cpp.o
[ 80%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/math_functions.cpp.o
[ 80%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/signal_handler.cpp.o
[ 80%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/upgrade_proto.cpp.o
[ 82%] Linking CXX shared library …/…/lib/libcaffe-nv.so
[ 82%] Built target caffe
Scanning dependencies of target device_query
Scanning dependencies of target caffe.bin
Scanning dependencies of target upgrade_solver_proto_text
Scanning dependencies of target test_net
Scanning dependencies of target train_net
Scanning dependencies of target compute_image_mean
Scanning dependencies of target convert_imageset
Scanning dependencies of target upgrade_net_proto_binary
Scanning dependencies of target upgrade_net_proto_text
Scanning dependencies of target extract_features
Scanning dependencies of target finetune_net
Scanning dependencies of target net_speed_benchmark
Scanning dependencies of target convert_cifar_data
Scanning dependencies of target convert_mnist_data
Scanning dependencies of target pycaffe
Scanning dependencies of target classification
Scanning dependencies of target convert_mnist_siamese_data
[ 82%] Building CXX object tools/CMakeFiles/device_query.dir/device_query.cpp.o
[ 82%] Building CXX object examples/CMakeFiles/convert_cifar_data.dir/cifar10/convert_cifar_data.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/compute_image_mean.dir/compute_image_mean.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/test_net.dir/test_net.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/upgrade_solver_proto_text.dir/upgrade_solver_proto_text.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/caffe.bin.dir/caffe.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/train_net.dir/train_net.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/finetune_net.dir/finetune_net.cpp.o
[ 83%] Building CXX object tools/CMakeFiles/upgrade_net_proto_text.dir/upgrade_net_proto_text.cpp.o
[ 84%] Building CXX object tools/CMakeFiles/upgrade_net_proto_binary.dir/upgrade_net_proto_binary.cpp.o
[ 84%] Building CXX object tools/CMakeFiles/extract_features.dir/extract_features.cpp.o
[ 84%] Building CXX object tools/CMakeFiles/net_speed_benchmark.dir/net_speed_benchmark.cpp.o
[ 86%] Building CXX object examples/CMakeFiles/convert_mnist_siamese_data.dir/siamese/convert_mnist_siamese_data.cpp.o
[ 86%] Building CXX object examples/CMakeFiles/convert_mnist_data.dir/mnist/convert_mnist_data.cpp.o
[ 86%] Building CXX object examples/CMakeFiles/classification.dir/cpp_classification/classification.cpp.o
[ 86%] Building CXX object tools/CMakeFiles/convert_imageset.dir/convert_imageset.cpp.o
[ 87%] Building CXX object python/CMakeFiles/pycaffe.dir/caffe/_caffe.cpp.o
[ 89%] Linking CXX executable device_query
[ 89%] Built target device_query
[ 89%] Linking CXX executable mnist/convert_mnist_data
[ 89%] Linking CXX executable siamese/convert_mnist_siamese_data
[ 90%] Linking CXX executable cifar10/convert_cifar_data
[ 90%] Linking CXX executable compute_image_mean
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTget_dataset_ndims' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTmake_dataset_double’
…/lib/libcaffe-nv.so.0.15.14: undefined .reference. /tolib /libcaffeH5LTmake_dataset_int-'nv.so.0.15.14 :. .undefined/ libreference/ libcaffeto- nv.so.0.15.14:
H5LTget_dataset_ndimsundefined’
reference. .to/ lib/H5LTread_dataset_floatlibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTmake_dataset_doubleundefined’
reference. .to/ lib/H5LTmake_dataset_floatlibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTmake_dataset_intundefined’
reference. .to/ lib/H5LTread_dataset_doublelibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTread_dataset_floatundefined’
reference. .to/ lib/H5LTmake_dataset_stringlibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTmake_dataset_floatundefined’
reference. .to/ lib/H5LTread_dataset_intlibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTread_dataset_doubleundefined’
reference. .to/ lib/H5LTfind_datasetlibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTmake_dataset_stringundefined’
reference. .to/ lib/H5LTget_dataset_infolibcaffe'- nv.so.0.15.14.:. /undefinedlib /referencelibcaffe -tonv.so.0.15.14 :
H5LTread_dataset_intundefined’
reference. .to/ lib/H5LTread_dataset_stringlibcaffe'- nv.so.0.15.14: undefined reference to
H5LTfind_dataset’
…/lib/libcaffe-nv.so.0.15.14: undefined reference collect2: error: ld returned 1 exit status
to H5LTget_dataset_info' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTread_dataset_string’
examples/CMakeFiles/convert_mnist_siamese_data.dir/build.make:120: recipe for target ‘examples/siamese/convert_mnist_siamese_data’ failed
make[2]: *** [examples/siamese/convert_mnist_siamese_data] Error 1
examples/CMakeFiles/convert_mnist_data.dir/build.make:120: recipe for target ‘examples/mnist/convert_mnist_data’ failed
make[2]: *** [examples/mnist/convert_mnist_data] Error 1
CMakeFiles/Makefile2:958: recipe for target ‘examples/CMakeFiles/convert_mnist_data.dir/all’ failed
make[1]: *** [examples/CMakeFiles/convert_mnist_data.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
CMakeFiles/Makefile2:1034: recipe for target ‘examples/CMakeFiles/convert_mnist_siamese_data.dir/all’ failed
make[1]: *** [examples/CMakeFiles/convert_mnist_siamese_data.dir/all] Error 2
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTmake_dataset_int' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTread_dataset_float’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTmake_dataset_float' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTread_dataset_double’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTmake_dataset_string' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTread_dataset_int’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTfind_dataset' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTget_dataset_info’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_string' collect2: error: ld returned 1 exit status examples/CMakeFiles/convert_cifar_data.dir/build.make:120: recipe for target 'examples/cifar10/convert_cifar_data' failed make[2]: *** [examples/cifar10/convert_cifar_data] Error 1 CMakeFiles/Makefile2:920: recipe for target 'examples/CMakeFiles/convert_cifar_data.dir/all' failed make[1]: *** [examples/CMakeFiles/convert_cifar_data.dir/all] Error 2 ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTget_dataset_ndims’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTmake_dataset_double' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTmake_dataset_int’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_float' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTmake_dataset_float’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_double' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTmake_dataset_string’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_int' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTfind_dataset’
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTget_dataset_info' ../lib/libcaffe-nv.so.0.15.14: undefined reference to
tools/CMakeFiles/compute_image_mean.dir/build.make:120: recipe for target ‘tools/compute_image_mean’ failed
make[2]: *** [tools/compute_image_mean] Error 1
CMakeFiles/Makefile2:630: recipe for target ‘tools/CMakeFiles/compute_image_mean.dir/all’ failed
make[1]: *** [tools/CMakeFiles/compute_image_mean.dir/all] Error 2
[ 91%] Linking CXX executable convert_imageset
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_string' collect2: error: ld returned 1 exit status tools/CMakeFiles/convert_imageset.dir/build.make:120: recipe for target 'tools/convert_imageset' failed make[2]: *** [tools/convert_imageset] Error 1 CMakeFiles/Makefile2:668: recipe for target 'tools/CMakeFiles/convert_imageset.dir/all' failed make[1]: *** [tools/CMakeFiles/convert_imageset.dir/all] Error 2 [ 93%] Linking CXX executable test_net [ 93%] Linking CXX executable net_speed_benchmark [ 94%] Linking CXX executable upgrade_net_proto_text [ 95%] Linking CXX executable upgrade_solver_proto_text [ 97%] Linking CXX executable finetune_net [ 97%] Linking CXX executable upgrade_net_proto_binary [ 97%] Linking CXX executable train_net [ 97%] Built target test_net [ 97%] Built target net_speed_benchmark [ 97%] Built target finetune_net [ 97%] Built target train_net ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTfind_dataset’
tools/CMakeFiles/upgrade_net_proto_text.dir/build.make:120: recipe for target ‘tools/upgrade_net_proto_text’ failed
make[2]: *** [tools/upgrade_net_proto_text] Error 1
CMakeFiles/Makefile2:744: recipe for target ‘tools/CMakeFiles/upgrade_net_proto_text.dir/all’ failed
make[1]: *** [tools/CMakeFiles/upgrade_net_proto_text.dir/all] Error 2
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_string' collect2: error: ld returned 1 exit status tools/CMakeFiles/upgrade_solver_proto_text.dir/build.make:120: recipe for target 'tools/upgrade_solver_proto_text' failed make[2]: *** [tools/upgrade_solver_proto_text] Error 1 CMakeFiles/Makefile2:440: recipe for target 'tools/CMakeFiles/upgrade_solver_proto_text.dir/all' failed make[1]: *** [tools/CMakeFiles/upgrade_solver_proto_text.dir/all] Error 2 ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTfind_dataset’
tools/CMakeFiles/upgrade_net_proto_binary.dir/build.make:120: recipe for target ‘tools/upgrade_net_proto_binary’ failed
make[2]: *** [tools/upgrade_net_proto_binary] Error 1
CMakeFiles/Makefile2:706: recipe for target ‘tools/CMakeFiles/upgrade_net_proto_binary.dir/all’ failed
make[1]: *** [tools/CMakeFiles/upgrade_net_proto_binary.dir/all] Error 2
[ 98%] Linking CXX executable extract_features
…/lib/libcaffe-nv.so.0.15.14: undefined reference to H5LTread_dataset_string' collect2: error: ld returned 1 exit status tools/CMakeFiles/extract_features.dir/build.make:120: recipe for target 'tools/extract_features' failed make[2]: *** [tools/extract_features] Error 1 CMakeFiles/Makefile2:782: recipe for target 'tools/CMakeFiles/extract_features.dir/all' failed make[1]: *** [tools/CMakeFiles/extract_features.dir/all] Error 2 [ 98%] Linking CXX executable cpp_classification/classification ../lib/libcaffe-nv.so.0.15.14: undefined reference to
H5LTfind_dataset’
examples/CMakeFiles/classification.dir/build.make:120: recipe for target ‘examples/cpp_classification/classification’ failed
make[2]: *** [examples/cpp_classification/classification] Error 1
CMakeFiles/Makefile2:996: recipe for target ‘examples/CMakeFiles/classification.dir/all’ failed
make[1]: *** [examples/CMakeFiles/classification.dir/all] Error 2
[100%] Linking CXX executable caffe
…/lib/libcaffe-nv.so.0.15.14: undefined reference to `H5LTread_dataset_string’
tools/CMakeFiles/caffe.bin.dir/build.make:120: recipe for target ‘tools/caffe’ failed
make[2]: *** [tools/caffe] Error 1
CMakeFiles/Makefile2:516: recipe for target ‘tools/CMakeFiles/caffe.bin.dir/all’ failed
make[1]: *** [tools/CMakeFiles/caffe.bin.dir/all] Error 2
[100%] Linking CXX shared library …/lib/_caffe.so
Creating symlink /softwares_nvidia/caffe/python/caffe/_caffe.so → /softwares_nvidia/caffe/build/lib/_caffe.so
[100%] Built target pycaffe
Makefile:129: recipe for target ‘all’ failed
make: *** [all] Error 2
H5LTfind_dataset’
H5LTfind_dataset’
H5LTfind_dataset’
H5LTfind_dataset’
H5LTfind_dataset’
To resolved this problem i need to:
edit “caffe/cmake/Dependencies.cmake”, at line 29
— list(APPEND Caffe_LINKER_LIBS ${HDF5_LIBRARIES})
+++ list(APPEND Caffe_LINKER_LIBS ${HDF5_LIBRARIES} ${HDF5_HL_LIBRARIES})
After installing everything, I tried to log in the graphical interface and I can not.
When I enter the password it tries to login but it returns to the login screen, could you help me?
