Hi all, I have 2 quaetions:
1)I am unable to compile my .cu files in command line with nvcc command.
Error is: nvcc fatal: cannot find compiler ‘cl.exe’
With Visual Studio 2013 I am able to build projects.
- How can I measure execution time of my program? Can I measure execution time of certain function, or piece of code (like tic-toc in Matlab)?
Thanks a lot.
i can help with the first, probably you have to add the enviroment varibles: http://www.computerhope.com/issues/ch000549.htm
Talking about the second question, you can use:
cudaEventCreate(&start);
cudaEventCreate(&stop);
Please tell me which environmental variable I have to change and what should I write in that variable
If you want to time C code, you can just use something like this (I use this exact syntax):
#include <time.h>
#include <stdio.h>
#define START clock_t t1; t1=clock();
#define END {long int final=clock()-t1; printf("Took %li ticks (%f seconds)", final, ((float)final)/CLOCKS_PER_SEC);}
Just put START and END in your code.
