I’m trying to compile kernel-4.9 using Linux_for_Tegra, but when try to download the Kernel Source Code in tag R32.6.1 using the source_sync.sh it fails:
$./source_sync.sh -k tegra-l4t-r32.6.1
Downloading default kernel/kernel-4.9 source...
Cloning into '/opt/jetpack/Linux_for_Tegra/sources/kernel/kernel-4.9'...
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection timed out
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection timed out
/opt/jetpack/Linux_for_Tegra/sources/kernel/kernel-4.9 source sync failed!
Downloading default kernel/nvgpu source...
Cloning into '/opt/jetpack/Linux_for_Tegra/sources/kernel/nvgpu'...
/opt/jetpack/Linux_for_Tegra/sources/kernel/nvgpu source sync failed!
Downloading default kernel/nvidia source...
Cloning into '/opt/jetpack/Linux_for_Tegra/sources/kernel/nvidia'...
/opt/jetpack/Linux_for_Tegra/sources/kernel/nvidia source sync failed!
$ ping nv-tegra.nvidia.com
PING nv-tegra-prod.hwinf-scm-aws.nvidia.com (34.216.216.36) 56(84) bytes of data.
^C
--- nv-tegra-prod.hwinf-scm-aws.nvidia.com ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4075ms
This script was working well until last tuesday November, 16th.
Is this service up?
Can anyone support me?
Regards
