Hello, I’m learning to program with CUDA and specifically I’m learning how to use a 2D CUDA array (cudaArray_t
) and how to use it with a texture object (cudaTextureObject_t
I create a simple problem to understand these concepts: fill an output buffer in the device with a texture object that uses a 2D array filled with ones.
I have a problem with tex2D<float>(input, x, y)
in the kernel code. Sometimes it returns zero instead of one. So the output buffer doesn’t contain all ones. I do not know why tex2D<float>(input, x, y)
has this behavior. I think there is something wrong with the coordinates I pass to text2D, or the configuration of the cudaTextureDesc
I pass to the texture object. What am I missing?
This is the source file called test-array-texture.cu
// This is a test file to larn CUDA Array and Texture Object.
#include <stdio.h>
#include <stdlib.h>
// HandleError, HANDLE_ERROR, HandleNull, HANDLE_NULL are utilies to handle
// errors on CUDA calls and malloc calls.
static void HandleError(cudaError_t err, const char *file, int line) {
if (err != cudaSuccess) {
printf("%s in %s at line %d\n", cudaGetErrorString( err ), file, line );
exit( EXIT_FAILURE );
#define HANDLE_ERROR(err) (HandleError( err, __FILE__, __LINE__ ))
static void HandleNull(void *ptr, const char *file, int line) {
if (ptr == NULL) {
printf("Host memory failed in %s at line %d\n", file, line);
exit(EXIT_FAILURE);
#define HANDLE_NULL(a) (HandleNull(a, __FILE__, __LINE__))
// Square dimension of the matrix.
const size_t DIM = 32;
__global__ void set_value_kernel(float *output, cudaTextureObject_t input) {
// Map from threadIdx/BlockIdx to cell position.
int x = threadIdx.x + blockIdx.x * blockDim.x;
int y = threadIdx.y + blockIdx.y * blockDim.y;
int offset = x + y * blockDim.x * gridDim.x;
float value = tex2D<float>(input, x, y);
//printf("%d, %d, %d = %2.1f\n", x, y, offset, value);
output[offset] = value;
void init_input_array(cudaArray_t dev_input) {
// Input is a 2D array but is linear on host memory.
float *input = (float *)malloc(DIM * DIM * sizeof(float));
HANDLE_NULL(input);
// Set host array values.
for (int i = 0; i < DIM * DIM; i++)
input[i] = 1.f;
// Copy host array to device array.
HANDLE_ERROR(cudaMemcpy2DToArray(dev_input,
0, 0, // Offsets (not used).
input,
DIM * sizeof(float), // Width in bytes plus padding (no padding).
DIM * sizeof(float), // Width in bytes.
DIM, // Number of rows (not bytes).
cudaMemcpyHostToDevice));
free(input);
int main() {
// Allocate a CUDA 2D array on the device. This array is used to create a
// texture object that is used as input in the kernel.
cudaChannelFormatDesc fmt_desc;
memset(&fmt_desc, 0, sizeof(cudaChannelFormatDesc));
fmt_desc.f = cudaChannelFormatKindFloat;
fmt_desc.x = 32;
fmt_desc.y = 32;
cudaArray_t dev_input;
HANDLE_ERROR(cudaMallocArray(&dev_input, &fmt_desc, DIM, DIM, cudaArraySurfaceLoadStore));
init_input_array(dev_input); // Initialise the array with default values.
// Create the resource description of the texture.
cudaResourceDesc res_desc;
memset(&res_desc, 0, sizeof(cudaResourceDesc));
res_desc.resType = cudaResourceTypeArray;
res_desc.res.array.array = dev_input;
// Create the texture description (with default options).
cudaTextureDesc tex_desc;
memset(&tex_desc, 0, sizeof(cudaTextureDesc));
// Finally create the texture object.
cudaTextureObject_t input_tex;
HANDLE_ERROR(cudaCreateTextureObject(&input_tex, &res_desc, &tex_desc, NULL));
// Allocate a linear output buffer in the device. It is used as 2D array.
float *dev_output;
HANDLE_ERROR(cudaMalloc((void **)&dev_output, DIM * DIM * sizeof(float)));
// Launch the kernel with 8x8 blocks of 8x8 thread for each block.
dim3 blocks(DIM / 4, DIM / 4);
dim3 threads(8, 8);
set_value_kernel<<<blocks, threads>>>(dev_output, input_tex);
// Allocate a linear output buffer in the host. It is used as 2D array.
float *output = (float *)calloc(DIM * DIM, sizeof(float));
HANDLE_NULL(output);
// Copy output buffer from device to host.
HANDLE_ERROR(cudaMemcpy(output, dev_output, DIM * DIM * sizeof(float),
cudaMemcpyDeviceToHost));
// Print output.
for (int row = 0; row < DIM; row++) {
for (int column = 0; column < DIM; column++) {
printf("%5.0f ", output[column + row * DIM]);
puts("");
// Free allocated memory.
HANDLE_ERROR(cudaFree(dev_output));
HANDLE_ERROR(cudaDestroyTextureObject(input_tex));
HANDLE_ERROR(cudaFreeArray(dev_input));
free(output);
return EXIT_SUCCESS;
I’m using an NVIDIA GeForce GTX 1050 Ti (compute capability 6.1) and these are the steps to build and run the code:
$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Wed_Nov_22_10:17:15_PST_2023
Cuda compilation tools, release 12.3, V12.3.107
Build cuda_12.3.r12.3/compiler.33567101_0
$ nvcc -Werror all-warnings test-array-texture.cu --output-file test-array-texture
$ ./test-array-texture
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Thanks in advance for the help!
