Unable to creat project folder
when i click the icon “Publish the current design …” , it show me always " unable to creat project folder" . I can run the omniverser viewer (presenter). I dont know what i should do to render in the viewer. Could someone help me?
Hi @atelier-li ,
If this is about how to use the SketchUp connector I think you can refer to the first link but did you setup your nucleus server(local or otherwise) correctly ? If not I think you’ll need to setup nucleus first before you can port file and open it up in usd composer or view.
https://docs.omniverse.nvidia.com/connect/latest/sketchup/manual.html
https://docs.omniverse.nvidia.com/nucleus/latest/workstation/installation.html
@atelier-li can you take a screenshot of the Nucleus tab of your OV Launcher and post it here? also, are you trying to save locally or…?
