• Hardware Platform (Jetson / GPU) Gpu: 1050Ti
• DeepStream Version; 6.1
• JetPack Version (valid for Jetson only): None
• TensorRT Version: 8.4.3.1
• NVIDIA GPU Driver Version (valid for GPU only) CUDA12: Driver: 525.60.13
• Issue Type( questions, new requirements, bugs): bug
**• How to reproduce the issue ?
I build deepstream python from deeptream-triton docker
FROM nvcr.io/nvidia/deepstream:6.1.1-triton
# To get video driver libraries at runtime (libnvidia-encode.so/libnvcuvid.so)
ENV NVIDIA_DRIVER_CAPABILITIES $NVIDIA_DRIVER_CAPABILITIES,video
ARG DEBIAN_FRONTEND=noninteractive
# Install pkg config to find ffmpeg
RUN apt-get update -qq && apt-get install -y autoconf \
automake \
build-essential \
git-core \
libass-dev \
libfreetype6-dev \
libgnutls28-dev \
libmp3lame-dev \
libsdl2-dev \
libtool \
libva-dev \
libvdpau-dev \
libvorbis-dev \
libxcb1-dev \
libxcb-shm0-dev \
libxcb-xfixes0-dev \
meson \
ninja-build \
pkg-config \
texinfo \
wget \
yasm \
zlib1g-dev \
libc6-dev \
unzip \
libnuma1 \
libnuma-dev
# For decode, install ffmpeg https://pytorch.org/audio/main/hw_acceleration_tutorial.html
WORKDIR /usr/lib/x86_64-linux-gnu
RUN ln -sf libnvcuvid.so.1 libnvcuvid.so
# Install https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings
WORKDIR /opt/
RUN git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
WORKDIR /opt/deepstream_python_apps
RUN apt install -y python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev \
python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \
libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
RUN git submodule update --init
RUN apt-get install -y apt-transport-https ca-certificates -y
RUN update-ca-certificates
WORKDIR /opt/deepstream_python_apps/3rdparty/pybind11
RUN python3 setup.py install
WORKDIR /opt/deepstream_python_apps/3rdparty/gst-python/
RUN ./autogen.sh && make && make install
WORKDIR /opt/deepstream_python_apps/bindings/build/
RUN cmake .. && make && pip3 install *.whl
WORKDIR /workspace/
Then I run
python deepstream_ssd_parser.py bikes.mp4
Which create error:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating NvStreamMux
Creating Nvinferserver
Creating Nvvidconv
Creating OSD (nvosd)
Creating Queue
Creating Converter 2 (nvvidconv2)
Creating capsfilter
Creating Encoder
Unable to create Encoder
If the following error is encountered:
/usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Preload the offending library:
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
File "deepstream_ssd_parser.py", line 456, in <module>
sys.exit(main(sys.argv))
File "deepstream_ssd_parser.py", line 361, in main
encoder.set_property("bitrate", 2000000)
AttributeError: 'NoneType' object has no attribute 'set_property'
I don’t’ find any libgomp.so.1
in /usr/lib/aarch64-linux-gnu/
but I found libgomp.so
in /usr/lib/gcc/x86_64-linux-gnu/9/
so I export:
export LD_PRELOAD=/usr/lib/gcc/x86_64-linux-gnu/9/libgomp.so
What should I do to fix this error?
