having installed TADP 4.0r1 without reported errors on a 64 bit Windows 7 PC running Visual Studio 2010 (SP1) steps 1 to 4 work as documented but after entering a valid package name the Finish button remains ghosted and it is impossible to either enter or select anything in the Min Target box, which remains blank.
Consequently it is not possible to create any new projects.
I’ve tried uninstalling and reinstalling TADP, and retried with a suitable device (an original Shield) connected over USB, but it seems this makes no difference.
I’m trying this to try and work out why existing solutions don’t allow the projects inside them to be built, without having to work with all 122 projects in our default solution. It’s not something I’d need to do otherwise - but I feel the discrepancy between the docs and my experience is worth noting here.
Guess that might be relevant: (from the Nsight Tegra.log)
2016-04-27 11:30:45.6786|INFO|Nvidia.PentaK.Utilities.RedirProcess|7-exited: code 0, finished in 63 ms
2016-04-27 11:30:45.6786|INFO|Nvidia.PentaK.Utilities.RedirProcess|8-launch: D:\NVPACK1R4\android-sdk-windows\tools\android.bat "list targets" [D:\NVPACK1R4\android-sdk-windows\tools]
2016-04-27 11:30:46.1187|INFO|Nvidia.PentaK.Utilities.RedirProcess|8-stdout:
ERROR: SWT folder 'lib\x86_64' does not exist.
Please set ANDROID_SWT to point to the folder containing swt.jar for your platform.
2016-04-27 11:30:46.1187|INFO|Nvidia.PentaK.Utilities.RedirProcess|8-stderr:
Picked up _JAVA_OPTIONS: -Xmx512M
2016-04-27 11:30:46.1187|INFO|Nvidia.PentaK.Utilities.RedirProcess|8-exited: code 0, finished in 436 ms
Solved. I had to tick Eclipse and ADT in the Codeworks Component Manager. Guess Eclipse is not required, but ADT. But ADT get’s only included automatically if you include Eclipse. Maybe you should change that behaviour and include ADT always, even if Eclipse is not included?
