Unable to create ROS2 node, please check that namespace is valid
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
4090
cuda12.3
Topic Description
Detailed Description
I use isaac sim4.5, follow the tutorial (ROS2 Joint Control: Extension Python Scripting β€” Isaac Sim Documentation) to import the robot arm and create an Action Graph, but when I click the run button, I get the following error:
2025-03-10 05:56:41 [Error] [omni.graph.core.plugin] /graph/ros2_publish_joint_state: [/graph] Unable to create ROS2 node, please check that namespace is valid
2025-03-10 05:56:41 [Error] [omni.graph.core.plugin] /graph/ros2_subscribe_joint_state: [/graph] Unable to create ROS2 node, please check that namespace is valid
Steps to Reproduce
  1. Import robotic arm
  2. Follow the tutorial to create an action graph
  3. click β€œplay” button
Error Messages
Screenshots or Videos
@54baizeyu Did you add a targetPrim path for the node Articulation Controller?
For the robot /panda, could you please check if you have articulation root (property tab β†’ physics)?
I tried on my end and it works fine.
Hello, I have the exact same problem following this tutorial, and my target prim has an articulation root, would you have any other idea why it would not work ?
Hi @zhengwang and @54baizeyu, I just resolved this problem. The ros2 bridge was not working when i used the PIP installation but it works when I use the Workstation install.
@zhengwang @le.lay.louis Sorry for late reply, i solved the problem by reinstall the ubuntu system, I think there is some kind of conflict between the pip version and the workstation version. Since 4.5.0, I have encountered a lot of errors that did not appear before. These errors disappeared after I reinstalled the system.
