Hi Harry,
I saw the other forum posts,
and unfortunately TDR is disabled, and memcheck is off…
I will sample this page every few weeks to check if the issue was fixed, if it’s ok with you.
Matan
Hi Harry,
Matan
Hi Matan
Our dev also cannot repo it, so maybe we should check the log on your computer.
Quit NSight monitor if it’s running
Set NVLOG_CONFIG_FILE= Path Of Attached NvLogConfigCustomer.txt
Edit the attach NvLogConfigCustomer.txt of the first line, path to NVLOG.txt
Relaunch NSight monitor
Start debugging to repro the issue
Quit debugging
Sent us the NVLOG.txt
NvLogConfigCustomer.txt is attached.
NvLogConfigCustomer.txt (272 Bytes)
Hi Matan,
This issue has been fixed in our internal build and the fix will be in the next version of nsight, it’s sw preemption and TDR issue, the workaround solution is debugging on your second gpu and disable the software preemption.
