I have similar problem with this. I ran tlt-converter
on Jetson Nano with using this command:
tlt-converter resnet18_detector.etlt \
-k $KEY \
-c calibration.bin \
-o output_cov/Sigmoid,output_bbox/BiasAdd \
-d 3,384,1248 \
-i nchw \
-m 64 \
-t int8 \
-e resnet18_detector.trt \
-b 4
This created a .trt
engine, that I put in samples folder. I changed my config file to:
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8)
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# enable-dbscan(Default=false), interval(Primary mode only, Default=0)
# custom-lib-path
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-engine-file=../../../../samples/models/Primary_Detector_pc/resnet18_detector.trt
labelfile-path=../../../../samples/models/Primary_Detector_pc/labels.txt
int8-calib-file=../../../../samples/models/Primary_Detector_pc/calibration.bin
batch-size=1
process-mode=1
model-color-format=0
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
[class-attrs-all]
threshold=0.2
eps=0.2
group-threshold=1
When I ran the model using:
./deepstream-test3-app \
file:///home/dlinano/deepstream_sdk_v4.0.2_jetson/samples/streams/sample.mp4
it generates:
** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Now playing: file:///home/dlinano/deepstream_sdk_v4.0.2_jetson/samples/streams/sample.mp4,
Opening in BLOCKING MODE
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is ON
[NvDCF] Initialized
0:00:08.120127810 10912 0x55a3e5aef0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:log(): INVALID_ARGUMENT: Can not find binding of given name
0:00:08.120201820 10912 0x55a3e5aef0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:checkEngineParams(): Could not find output layer 'conv2d_bbox' in engine
0:00:08.120232341 10912 0x55a3e5aef0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:log(): INVALID_ARGUMENT: Can not find binding of given name
0:00:08.120268695 10912 0x55a3e5aef0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:checkEngineParams(): Could not find output layer 'conv2d_cov/Sigmoid' in engine
