Unable to detect e-CAM30_CUNANO on Jetson Nano
I am using e-CAM30_CUNANO camera for jetson nano
On connecting to the nano and running cheese . I am getting “no cameras found”
On saving log, I could see “tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10” .
I am facing same issue with Raspberry Pi Camera Module v2 with CSI camera connector as well
Please find below the log file
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3561) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Aug 12 21:16:23 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb7000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb3000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29392(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562168K/4159488K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 122184K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001742] Console: colour dummy device 80x25
[ 0.001762] console [tty0] enabled
[ 0.001779] kmemleak: Kernel memory leak detector disabled
[ 0.001799] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001814] pid_max: default: 32768 minimum: 301
[ 0.002264] Security Framework initialized
[ 0.002487] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002495] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003668] ftrace: allocating 46938 entries in 184 pages
[ 0.174957] sched-energy: CPU device node has no sched-energy-costs
[ 0.174992] ASID allocator initialised with 65536 entries
[ 0.212199] tegra-id: chipid=22117.
[ 0.212245] tegra-id: opt_subrevision=0.
[ 0.212263] Tegra Speedo/IDDQ fuse revision 4
[ 0.212268] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212272] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.212279] Tegra: CPU Speedo Value 2014, SoC Speedo Value 1921, GPU Speedo Value 2017
[ 0.212282] Tegra: CPU IDDQ Value 1748, SoC IDDQ Value 1956, GPU IDDQ Value 2365
[ 0.212299] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.212314] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.212322] DTB Build time: Aug 12 2019 21:21:24
[ 0.261065] CPU1: Booted secondary processor [411fd071]
[ 0.292984] CPU2: Booted secondary processor [411fd071]
[ 0.324980] CPU3: Booted secondary processor [411fd071]
[ 0.325074] Brought up 4 CPUs
[ 0.325082] SMP: Total of 4 processors activated.
[ 0.325091] CPU features: detected feature: 32-bit EL0 Support
[ 0.325358] CPU: All CPU(s) started at EL2
[ 0.325376] alternatives: patching kernel code
[ 0.333861] devtmpfs: initialized
[ 0.372036] Initilizing CustomIPI irq domain
[ 0.372445] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.372470] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.383929] pinctrl core: initialized pinctrl subsystem
[ 0.384632] OS set in device tree is not L4T.
[ 0.385090] regulator-dummy: no parameters
[ 0.385383] Initializing plugin-manager
[ 0.385499] Plugin module not found
[ 0.385728] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.386300] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.387153] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.387564] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.387974] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.388360] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.392887] NET: Registered protocol family 16
[ 0.394395] pstore: using zlib compression
[ 0.394431] console [pstore-1] enabled
[ 0.394437] pstore: Registered ramoops as persistent store backend
[ 0.394442] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405080] cpuidle: using governor menu
[ 0.409548] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.411341] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.411364] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413701] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.416361] tegra_powergate_init: DONE
[ 0.416379] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.416386] DTB Build time: Aug 12 2019 21:21:24
[ 0.418289] Tegra reboot handler registered.
[ 0.422872] iommu: Adding device tegra-carveouts to group 0
[ 0.423003] platform tegra-carveouts: domain=ffffffc0f9ba23d8 allocates as[0]=ffffffc0f94040a8
[ 0.423368] iommu: Adding device smmu_test to group 1
[ 0.423414] platform smmu_test: domain=ffffffc0f9ba2618 allocates as[0]=ffffffc0f9404110
[ 0.424254] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.424312] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.424368] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.424377] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.424402] mc-err: mcerr ops are set to t21x
[ 0.434086] iommu: Adding device 70090000.xusb to group 2
[ 0.434380] iommu: Adding device 70006000.serial to group 3
[ 0.434461] platform 70006000.serial: domain=ffffffc0f94bc618 allocates as[0]=ffffffc0f9404178
[ 0.434900] iommu: Adding device 70006040.serial to group 4
[ 0.435165] iommu: Adding device 70006200.serial to group 5
[ 0.435391] iommu: Adding device sound to group 6
[ 0.435438] platform sound: domain=ffffffc0f94bcb58 allocates as[0]=ffffffc0f94041e0
[ 0.436022] iommu: Adding device 7000d400.spi to group 7
[ 0.436275] iommu: Adding device 7000d600.spi to group 8
[ 0.436563] iommu: Adding device 70410000.spi to group 9
[ 0.436857] iommu: Adding device 50000000.host1x to group 10
[ 0.437161] iommu: Adding device 54080000.vi to group 11
[ 0.437546] iommu: Adding device 54600000.isp to group 12
[ 0.437805] iommu: Adding device 54680000.isp to group 13
[ 0.438116] iommu: Adding device tegradc.0 to group 14
[ 0.438174] platform tegradc.0: domain=ffffffc0f94c9a98 allocates as[0]=ffffffc0f9404248
[ 0.442349] platform tegradc.0: IOVA linear map 0x0000000092cb7000(800000)
[ 0.442740] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.443082] iommu: Adding device tegradc.1 to group 15
[ 0.443126] platform tegradc.1: domain=ffffffc0f94c9cd8 allocates as[0]=ffffffc0f94042b0
[ 0.447288] platform tegradc.1: IOVA linear map 0x0000000092cb7000(800000)
[ 0.447680] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.447920] iommu: Adding device 54340000.vic to group 16
[ 0.448124] iommu: Adding device 544c0000.nvenc to group 17
[ 0.448326] iommu: Adding device 54500000.tsec to group 18
[ 0.448544] iommu: Adding device 54100000.tsecb to group 19
[ 0.448737] iommu: Adding device 54480000.nvdec to group 20
[ 0.448955] iommu: Adding device 54380000.nvjpg to group 21
[ 0.450019] iommu: Adding device 546c0000.i2c to group 22
[ 0.450351] iommu: Adding device 57000000.gpu to group 23
[ 0.450407] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[0]=ffffffc0f9404318
[ 0.450444] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[1]=ffffffc0f9404380
[ 0.450485] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[2]=ffffffc0f94043e8
[ 0.450522] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[3]=ffffffc0f9404450
[ 0.451424] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.451435] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.451448] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.451453] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.451458] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.501168] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.501177] tegra-pmc: Clear bootloader IO dpd settings
[ 0.501200] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.501265] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.501555] iommu: Adding device 70012000.se to group 24
[ 0.502334] iommu: Adding device 7000c000.i2c to group 25
[ 0.502588] iommu: Adding device 7000c400.i2c to group 26
[ 0.502838] iommu: Adding device 7000c500.i2c to group 27
[ 0.503078] iommu: Adding device 7000c700.i2c to group 28
[ 0.503375] iommu: Adding device 7000d000.i2c to group 29
[ 0.503624] iommu: Adding device 7000d100.i2c to group 30
[ 0.503917] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.503973] platform sdhci-tegra.0: domain=ffffffc0f9560e58 allocates as[0]=ffffffc0f94044b8
[ 0.504816] iommu: Adding device 700d0000.xudc to group 32
[ 0.508232] vdd-ac-bat: 5000 mV
[ 0.508595] vdd-5v0-sys: 5000 mV
[ 0.509584] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.509656] vdd-5v0-hdmi: 5000 mV
[ 0.510060] vdd-1v8-sys: 1800 mV
[ 0.510450] vdd-fan: supplied by vdd-5v0-sys
[ 0.510486] vdd-fan: 5000 mV
[ 0.510871] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.510927] vdd-usb-vbus: 5000 mV
[ 0.511469] vdd-usb-vbus2: 5000 mV
[ 0.545942] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548514] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.549643] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549662] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.550064] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.557778] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558130] SCSI subsystem initialized
[ 0.558373] libata version 3.00 loaded.
[ 0.558662] usbcore: registered new interface driver usbfs
[ 0.558710] usbcore: registered new interface driver hub
[ 0.558785] usbcore: registered new device driver usb
[ 0.562681] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.569159] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.569794] random: fast init done
[ 0.570009] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.573079] vdd-ddr-1v1: 1150 mV
[ 0.577079] vdd-pre-reg-1v35: 1350 mV
[ 0.581148] vdd-1v8: 1800 mV
[ 0.585076] avdd-sys-1v2: 1200 mV
[ 0.589074] vdd-pex-1v0: 1050 mV
[ 0.589617] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.590098] max77620-ldo3: at 3100 mV
[ 0.593078] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.593611] max77620-ldo5: at 3100 mV
[ 0.594115] max77620-ldo6: at 2800 mV
[ 0.597079] avdd-1v05-pll: 1050 mV
[ 0.601077] avdd-io-hdmi-dp: 1050 mV
[ 0.602155] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.602460] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.603797] max77620 4-003c: max77620 probe successful
[ 0.606655] media: Linux media interface: v0.10
[ 0.606711] Linux video capture interface: v2.00
[ 0.607637] pps_core: LinuxPPS API ver. 1 registered
[ 0.607642] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.607668] PTP clock support registered
[ 0.611505] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.617931] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.618859] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619493] Bluetooth: Core ver 2.22
[ 0.619544] NET: Registered protocol family 31
[ 0.619548] Bluetooth: HCI device and connection manager initialized
[ 0.619561] Bluetooth: HCI socket layer initialized
[ 0.619569] Bluetooth: L2CAP socket layer initialized
[ 0.619596] Bluetooth: SCO socket layer initialized
[ 0.621344] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621359] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.621404] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.621417] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624663] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.625822] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.625887] vdd-3v3-sys: 3300 mV
[ 0.626159] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629141] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629648] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629685] vdd-3v3-sd: 3300 mV
[ 0.630459] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630501] avdd-io-edp-1v05: 1050 mV
[ 0.630948] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.631012] vdd-usb-hub-en: 5000 mV
[ 0.632448] camchar: rtcpu character device driver loaded
[ 0.633329] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.634776] clocksource: Switched to clocksource arch_sys_counter
[ 0.675684] VFS: Disk quotas dquot_6.6.0
[ 0.675813] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676311] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676773] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676792] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.677024] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.677029] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.677045] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677074] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677080] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677094] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677103] nvmap_page_pool_init: Total RAM pages: 1009326
[ 0.677109] nvmap_page_pool_init: nvmap page pool size: 126165 pages (492 MB)
[ 0.677211] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677730] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678722] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.686857] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687322] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687568] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687773] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.687945] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688238] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688242] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.688675] NET: Registered protocol family 2
[ 0.689688] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.689901] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690441] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.690604] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690685] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691166] NET: Registered protocol family 1
[ 0.691910] RPC: Registered named UNIX socket transport module.
[ 0.691917] RPC: Registered udp transport module.
[ 0.691921] RPC: Registered tcp transport module.
[ 0.691925] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.691939] PCI: CLS 0 bytes, default 64
[ 0.692169] Trying to unpack rootfs image as initramfs…
[ 0.928883] Freeing initrd memory: 5432K
[ 0.938971] host1x 50000000.host1x: initialized
[ 0.940857] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.944106] audit: initializing netlink subsys (disabled)
[ 0.944196] audit: type=2000 audit(0.795:1): initialized
[ 0.944938] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.954995] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.956498] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.957303] 9p: Installing v9fs 9p2000 file system support
[ 0.960860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.961014] io scheduler noop registered
[ 0.961309] io scheduler cfq registered (default)
[ 0.964021] gic 702f9000.agic: GIC IRQ controller registered
[ 0.967022] iommu: Adding device 702ef000.adsp to group 33
[ 0.973662] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.973846] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.974420] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7208c13
[ 0.974428] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.976551] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.976651] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.976745] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.976934] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.977018] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.977132] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.977220] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.977308] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.977395] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.977481] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.982963] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.984745] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.986650] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.988014] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.988380] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.989597] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.989835] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.990074] Adding domain tsec-pd to PM domain host1x-pd
[ 0.992385] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.993276] tsec 54500000.tsec: initialized
[ 0.994983] tsec 54100000.tsecb: initialized
[ 0.995742] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.999287] nvdec 54480000.nvdec: initialized
[ 1.000362] Adding domain vic03-pd to PM domain host1x-pd
[ 1.000560] Adding domain msenc-pd to PM domain host1x-pd
[ 1.000722] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.004828] falcon 54340000.vic: initialized
[ 1.006146] falcon 544c0000.nvenc: initialized
[ 1.007516] falcon 54380000.nvjpg: initialized
[ 1.012130] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.012281] display board info: id 0x0, fab 0x0
[ 1.012347] generic_infoframe_type: 0x87
[ 1.012476] tegradc tegradc.0: DT parsed successfully
[ 1.012522] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.013032] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.016029] tegradc tegradc.0: probed
[ 1.020470] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.024851] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.025584] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.025911] kfuse 7000fc00.kfuse: initialized
[ 1.027644] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.029178] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.031584] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.031602] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.032178] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.033498] vdd-gpu: applied init 1000000uV constraint
[ 1.033507] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.033925] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.039229] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.039407] No Device Node present for smmu client: serial8250 !!
[ 1.039426] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.039484] iommu: Adding device serial8250 to group 35
[ 1.043254] console [ttyS0] disabled
[ 1.043491] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.043718] console [ttyS0] enabled
[ 1.044757] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.045067] serial-tegra 70006200.serial: RX in PIO mode
[ 1.045160] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.046188] [drm] Initialized
[ 1.049590] Console: switching to colour frame buffer device 240x67
[ 1.049726] tegradc tegradc.0: fb registered
[ 1.057191] brd: module loaded
[ 1.059961] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.060022] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.060593] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.060606] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.063430] loop: module loaded
[ 1.063538] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.063661] tegra_profiler: auth: init
[ 1.065089] THERMAL EST: found 2 subdevs
[ 1.065098] THERMAL EST num_resources: 0
[ 1.065103] [THERMAL EST subdev 0]
[ 1.065110] [THERMAL EST subdev 1]
[ 1.065575] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.065580] THERMAL EST: thz register success.
[ 1.065741] THERMAL EST: end of probe, return err: 0
[ 1.067081] hisi_sas: driver version v1.6
[ 1.071357] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.072622] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.072633] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.076132] libphy: Fixed MDIO Bus: probed
[ 1.076915] tun: Universal TUN/TAP device driver, 1.6
[ 1.076920] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.077936] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.077942] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.078012] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.078016] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.078075] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.078079] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.078128] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.078133] Copyright© 1999 - 2017 Intel Corporation.
[ 1.079299] PPP generic driver version 2.4.2
[ 1.079519] PPP BSD Compression module registered
[ 1.079524] PPP Deflate Compression module registered
[ 1.079566] PPP MPPE Compression module registered
[ 1.079574] NET: Registered protocol family 24
[ 1.079651] usbcore: registered new interface driver r8152
[ 1.079696] usbcore: registered new interface driver asix
[ 1.079760] usbcore: registered new interface driver ax88179_178a
[ 1.079800] usbcore: registered new interface driver cdc_ether
[ 1.079840] usbcore: registered new interface driver net1080
[ 1.079875] usbcore: registered new interface driver cdc_subset
[ 1.079923] usbcore: registered new interface driver zaurus
[ 1.079983] usbcore: registered new interface driver cdc_ncm
[ 1.080155] VFIO - User Level meta-driver version: 0.3
[ 1.081491] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.081518] ehci-pci: EHCI PCI platform driver
[ 1.081568] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.081584] ohci-pci: OHCI PCI platform driver
[ 1.081635] ohci-platform: OHCI generic platform driver
[ 1.084529] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.085139] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.086329] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9667800 id
[ 1.086570] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.086577] Extcon AUX1(HDMI) enable
[ 1.087745] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.088057] tegradc tegradc.1: No lt-data, using default setting
[ 1.088132] tegradc tegradc.1: No hpd-gpio in DT
[ 1.088294] tegradc tegradc.1: DT parsed successfully
[ 1.088359] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.089275] usbcore: registered new interface driver uas
[ 1.089355] usbcore: registered new interface driver usb-storage
[ 1.089476] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.089551] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.089580] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.089911] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.090503] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.090547] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.090837] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.090843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.090848] usb usb1: Product: xHCI Host Controller
[ 1.090852] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.090855] usb usb1: SerialNumber: 70090000.xusb
[ 1.091368] usbcore: registered new interface driver usbserial
[ 1.091728] hub 1-0:1.0: USB hub found
[ 1.091777] hub 1-0:1.0: 5 ports detected
[ 1.092418] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.092429] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.092522] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.092606] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.092610] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.092614] usb usb2: Product: xHCI Host Controller
[ 1.092617] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.092621] usb usb2: SerialNumber: 70090000.xusb
[ 1.093085] hub 2-0:1.0: USB hub found
[ 1.093148] hub 2-0:1.0: 4 ports detected
[ 1.095158] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.096658] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.096676] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.096694] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.096724] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.096749] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.097446] mousedev: PS/2 mouse device common for all mice
[ 1.097549] usbcore: registered new interface driver xpad
[ 1.100378] tegradc tegradc.1: probed
[ 1.124216] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.126998] tegradc tegradc.1: fb registered
[ 1.130246] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.130254] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.130263] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.130276] tegradc tegradc.1: blank - powerdown
[ 1.130297] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.130302] Extcon DP: HPD disabled
[ 1.130306] hpd: hpd_switch 0
[ 1.130310] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.130319] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.130325] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.194899] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.218402] tegradc tegradc.0: blank - powerdown
[ 1.228091] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.230839] rtc rtc1: alarm rtc device
[ 1.230861] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.230901] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.231667] i2c /dev entries driver
[ 1.234115] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.257453] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.257534] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.257565] imx219 6-0010: board setup failed
[ 1.257664] imx219: probe of 6-0010 failed with error -121
[ 1.258706] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.261525] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.261531] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.262030] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.262051] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.262061] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.262188] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.262198] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.262204] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.262343] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.262353] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.262358] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.262546] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.262715] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.262720] Extcon AUX1(HDMI) disable
[ 1.263544] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.263604] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.263632] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.263649] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.263658] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.264675] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.264695] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.264887] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.264914] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.265363] parse_throttle_dt_data: Num cap clks = 6
[ 1.265369] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.265383] parse_throttle_dt_data: clk=gpu type=4
[ 1.265411] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.265434] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.265461] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.265464] parse_throttle_dt_data: clk=emc type=3
[ 1.265852] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.265999] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.266162] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.267116] FAN dev name: pwm-fan
[ 1.267170] FAN:gpio request success.
[ 1.267245] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.267574] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.267759] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.267769] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.267860] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.267865] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.267869] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.267873] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.267877] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.267881] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.267885] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.267888] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.267892] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.267896] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.268555] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.268972] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.269957] device-mapper: uevent: version 1.0.3
[ 1.270547] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.276030] tegra210-cpufreq cpufreq: probe()…completed
[ 1.276841] sdhci: Secure Digital Host Controller Interface driver
[ 1.276842] sdhci: Copyright© Pierre Ossman
[ 1.276844] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.277363] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.277748] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.277876] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.287745] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.288300] hidraw: raw HID events driver © Jiri Kosina
[ 1.289419] usbcore: registered new interface driver usbhid
[ 1.289420] usbhid: USB HID core driver
[ 1.290822] tegradc tegradc.0: unblank
[ 1.292259] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.292496] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.294404] nvpmodel: initialized successfully
[ 1.295486] usbcore: registered new interface driver snd-usb-audio
[ 1.295550] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.295554] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.295572] iommu: Adding device snd-soc-dummy to group 36
[ 1.305050] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.311953] OPE platform probe
[ 1.312042] OPE platform probe successful
[ 1.312067] OPE platform probe
[ 1.312146] OPE platform probe successful
[ 1.323003] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.335475] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.335532] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.336529] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.336535] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.337254] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.337392] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.337521] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.337656] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.337788] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.337917] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.338045] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.338174] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.338303] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.338429] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.350178] u32 classifier
[ 1.350180] Actions configured
[ 1.350253] Initializing XFRM netlink socket
[ 1.351007] NET: Registered protocol family 10
[ 1.351693] NET: Registered protocol family 17
[ 1.351705] NET: Registered protocol family 15
[ 1.351782] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.351865] Bluetooth: RFCOMM socket layer initialized
[ 1.351874] Bluetooth: RFCOMM ver 1.11
[ 1.351879] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.351883] Bluetooth: HIDP socket layer initialized
[ 1.351901] 9pnet: Installing 9P2000 support
[ 1.351948] Key type dns_resolver registered
[ 1.354888] Registered cp15_barrier emulation handler
[ 1.354902] Registered setend emulation handler
[ 1.356093] registered taskstats version 1
[ 1.356634] Adding domain ve2-pd to PM domain host1x-pd
[ 1.356886] Adding domain ve-pd to PM domain host1x-pd
[ 1.359059] isp 54600000.isp: initialized
[ 1.360041] isp 54680000.isp: initialized
[ 1.370275] last reset is due to software reset
[ 1.370279] KERNEL: PMC reset status reg: 0x3
[ 1.370353] BL: PMC reset status reg: 0x3
[ 1.370355] BL: PMIC poweroff Event Recorder: 0x0
[ 1.371190] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.371193] Extcon AUX1(HDMI) enable
[ 1.371907] clk_cbus_recalc_rate: no gbus parent
[ 1.371912] clk_cbus_round_rate: no gbus parent
[ 1.371913] clk_cbus_round_rate: no gbus parent
[ 1.371920] clk_cbus_recalc_rate: no gbus parent
[ 1.372018] clk_cbus_recalc_rate: no gbus parent
[ 1.372020] clk_cbus_round_rate: no gbus parent
[ 1.372022] clk_cbus_round_rate: no gbus parent
[ 1.372025] clk_cbus_recalc_rate: no gbus parent
[ 1.372243] tegradc tegradc.0: sync windows ret = 250
[ 1.372692] tegra_dvfs: GPU-cap: registered
[ 1.372747] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.372749] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.372751] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.374220] tegra_dvfs: vdd-gpu-vts: registered
[ 1.374987] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.375704] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.376268] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.393040] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.393043] Extcon HDMI: HPD enabled
[ 1.393057] tegradc tegradc.0: hdmi: plugged
[ 1.407925] tegra_rtc 7000e000.rtc: setting system clock to 2019-09-21 00:56:16 UTC (1569027376)
[ 1.408968] vi 54080000.vi: vi_probe: ++
[ 1.412180] vi 54080000.vi: initialized
[ 1.414200] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.415745] Disable partitions left on by BL
[ 1.415749] disb
[ 1.415799] bwmgr: missing cdev-type property
[ 1.415905] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.415911] DRAM derating cdev registered.
[ 1.416982] vdd-fan: disabling
[ 1.416985] vdd-usb-vbus: disabling
[ 1.416988] vdd-usb-vbus2: disabling
[ 1.416998] avdd-io-edp-1v05: disabling
[ 1.417099] ALSA device list:
[ 1.417102] #0: tegra-hda at 0x70038000 irq 83
[ 1.417105] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.418800] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.420287] Freeing unused kernel memory: 8576K
[ 1.436788] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.438675] L4T-INITRD Build DATE: Sat Sep 21 00:56:16 UTC 2019
[ 1.443354] Root device found: mmcblk0p1
[ 1.453994] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.453999] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.454002] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.454005] usb 1-2: Manufacturer: Generic
[ 1.455801] hub 1-2:1.0: USB hub found
[ 1.456875] hub 1-2:1.0: 4 ports detected
[ 1.528754] mmc0: hw tuning done …
[ 1.528791] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 1.529203] mmcblk0: mmc0:aaaa SC128 119 GiB
[ 1.535676] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 1.648055] Found dev node: /dev/mmcblk0p1
[ 1.690459] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.691245] Rootfs mounted over mmcblk0p1
[ 1.718743] Switching from initrd to actual rootfs
[ 1.746791] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 1.772495] usb 1-2.1: New USB device found, idVendor=413c, idProduct=2107
[ 1.772502] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.772535] usb 1-2.1: Product: Dell USB Entry Keyboard
[ 1.772538] usb 1-2.1: Manufacturer: DELL
[ 1.776654] input: DELL Dell USB Entry Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:413C:2107.0001/input/input2
[ 1.835130] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-70090000.xusb-2.1/input0
[ 1.840794] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.914787] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[ 1.938018] ip_tables: © 2000-2006 Netfilter Core Team
[ 1.939033] usb 1-2.2: New USB device found, idVendor=0461, idProduct=4e22
[ 1.939037] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.939040] usb 1-2.2: Product: USB Optical Mouse
[ 1.939043] usb 1-2.2: Manufacturer: PixArt
[ 1.942266] input: PixArt USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:0461:4E22.0002/input/input3
[ 1.942555] hid-generic 0003:0461:4E22.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-70090000.xusb-2.2/input0
[ 1.950428] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.973855] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.974607] systemd[1]: Detected architecture arm64.
[ 2.000235] systemd[1]: Set hostname to .
[ 2.084878] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.084888] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.221693] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.221724] systemd[1]: Reached target Swap.
[ 2.221929] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.223642] systemd[1]: Created slice System Slice.
[ 2.223705] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.223873] systemd[1]: Listening on Syslog Socket.
[ 2.224005] systemd[1]: Listening on udev Kernel Socket.
[ 2.224156] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.254864] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.256887] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.296151] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.363139] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.363150] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.363154] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.363158] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.363163] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.363187] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.363250] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.363413] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.363533] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.363557] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.363588] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.363608] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.363742] pci 0000:01:00.0: supports D1 D2
[ 2.363745] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.374873] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.374905] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.374926] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.374934] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.374952] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.374969] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.374977] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.374981] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.374986] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.375276] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.375280] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.375286] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.375368] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.375541] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.375557] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.391385] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.391476] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:20:30 from device tree
[ 2.391989] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.392005] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.426185] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.509836] systemd-journald[1975]: Received request to flush runtime journal from PID 1
[ 3.337845] using random self ethernet address
[ 3.347608] using random host ethernet address
[ 3.536055] random: crng init done
[ 3.539487] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.000631] Mass Storage Function, version: 2009/09/11
[ 4.000638] LUN: removable file: (no medium)
[ 4.008840] using random self ethernet address
[ 4.013873] using random host ethernet address
[ 4.052954] rndis0: HOST MAC 7e:ad:e6:08:59:94
[ 4.053120] rndis0: MAC 7e:ad:e6:08:59:95
[ 4.058123] usb0: HOST MAC 7e:ad:e6:08:59:96
[ 4.058155] usb0: MAC 7e:ad:e6:08:59:97
[ 4.058184] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.063525] l4tbr0: port 1(rndis0) entered blocking state
[ 4.063530] l4tbr0: port 1(rndis0) entered disabled state
[ 4.063701] device rndis0 entered promiscuous mode
[ 4.074732] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.087486] l4tbr0: port 2(usb0) entered blocking state
[ 4.087491] l4tbr0: port 2(usb0) entered disabled state
[ 4.088092] device usb0 entered promiscuous mode
[ 4.094216] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.191037] zram: Added device: zram0
[ 5.193271] zram: Added device: zram1
[ 5.197152] zram: Added device: zram2
[ 5.200053] zram: Added device: zram3
[ 5.241442] zram0: detected capacity change from 0 to 518569984
[ 5.253531] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.253539] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.402815] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.404121] eth0: 0xffffff800d50d000, 00:04:4b:e6:20:30, IRQ 405
[ 5.420477] Adding 506412k swap on /dev/zram0. Priority:5 extents:1 across:506412k SS
[ 5.424458] zram1: detected capacity change from 0 to 518569984
[ 5.437906] Adding 506412k swap on /dev/zram1. Priority:5 extents:1 across:506412k SS
[ 5.444027] zram2: detected capacity change from 0 to 518569984
[ 5.454693] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.486998] Adding 506412k swap on /dev/zram2. Priority:5 extents:1 across:506412k SS
[ 5.491963] zram3: detected capacity change from 0 to 518569984
[ 5.506385] Adding 506412k swap on /dev/zram3. Priority:5 extents:1 across:506412k SS
[ 5.579898] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.614287] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.614294] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.614298] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.614301] usb 2-1: Manufacturer: Generic
[ 5.619148] hub 2-1:1.0: USB hub found
[ 5.620616] hub 2-1:1.0: 4 ports detected
[ 5.778805] usb 2-1: usb_suspend_both: status 0
[ 5.778979] usb usb2: usb_suspend_both: status 0
[ 6.939180] tegradc tegradc.0: blank - powerdown
[ 7.003474] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 7.003476] Extcon AUX1(HDMI) disable
[ 7.023990] tegradc tegradc.0: unblank
[ 7.036174] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 7.036258] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 7.037278] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 7.037286] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 7.073034] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 7.073037] Extcon AUX1(HDMI) enable
[ 7.078958] tegradc tegradc.0: unblank
[ 7.079248] tegradc tegradc.1: blank - powerdown
[ 7.925623] fuse init (API version 7.26)
[ 9.558794] r8168: eth0: link up
[ 9.558850] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.131858] tegradc tegradc.0: blank - powerdown
[ 21.187579] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 21.187582] Extcon AUX1(HDMI) disable
[ 21.207978] tegradc tegradc.1: blank - powerdown
[ 21.352418] tegradc tegradc.0: blank - powerdown
[ 21.352440] tegradc tegradc.0: unblank
[ 21.358780] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 21.358881] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 21.359893] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 21.359901] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 21.395922] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 21.395924] Extcon AUX1(HDMI) enable
[ 21.402227] tegradc tegradc.0: unblank
[ 21.402240] tegradc tegradc.1: blank - powerdown
[ 24.575767] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 24.575779] Bluetooth: BNEP socket layer initialized
[ 25.012086] tegradc tegradc.0: unblank
[ 25.012243] tegradc tegradc.1: blank - powerdown
[ 1436.494767] tegradc tegradc.0: blank - powerdown
[ 1436.556820] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1436.556823] Extcon AUX1(HDMI) disable
[ 1446.457430] extcon-disp-state extcon:disp-state: cable 40 state 0
[ 1446.457475] Extcon HDMI: HPD disabled
[ 1446.457847] tegradc tegradc.0: hdmi: unplugged
[ 1446.479123] tegradc tegradc.0: blank - powerdown
[ 1446.479136] tegradc tegradc.0: unblank
[ 1446.479165] tegradc tegradc.0: unblank
[ 1446.479174] tegradc tegradc.1: blank - powerdown
[ 1447.505711] Host read timeout at address 5458045c
[ 1447.511269] tegradc tegradc.0: blank - powerdown
[ 1447.511294] tegradc tegradc.0: unblank
[ 1447.527938] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1447.528059] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1447.529081] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1447.529089] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1447.564267] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1447.564270] Extcon AUX1(HDMI) enable
[ 1447.564462] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1447.564466] Extcon HDMI: HPD enabled
[ 1447.564571] tegradc tegradc.0: hdmi: plugged
[ 1447.600971] tegradc tegradc.0: blank - powerdown
[ 1447.665602] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1447.665605] Extcon AUX1(HDMI) disable
[ 1447.683329] tegradc tegradc.0: unblank
[ 1447.695531] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1447.695629] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1447.696656] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1447.696663] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1447.733363] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1447.733366] Extcon AUX1(HDMI) enable
[ 1447.733560] tegradc tegradc.0: unblank
[ 1447.733850] tegradc tegradc.1: blank - powerdown
[ 1447.794725] tegradc tegradc.0: unblank
[ 1447.794887] tegradc tegradc.1: blank - powerdown
Hi vgsharsha20,
Can you please confirm whether you have used e-con shared e-CAM30_CUNANO SD Card image to boot the Jetson Nano with e-CAM30_CUNANO camera connected setup?
Because from the logs shared by you , we came to know your jetson nano device is not updated with our e-CAM30_CUNANO camera binaries.
